vramor Posted August 5, 2016 Posted August 5, 2016 Is any possibility to run at least 2 DVBViewer instances to receive programs with two different tuners, one DVB-C and other DVB-T for example? Thanks in advance. Quote
Tjod Posted August 5, 2016 Posted August 5, 2016 Mostly you need only one DVBViewer instance.You can watch a DVB-C program and have a DVB-T in picture in picture or recording at the same time in one DVBViewer instance. If you need two DVBViewer windows to watch two channel on two monitors you should start by installing the Recording Service. So that it can handle the hardware. Because it is better if only one program is responsible for all hardware. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
