rco133 Posted August 5, 2016 Posted August 5, 2016 Hi. I have just upgraded my PC to a X99 chipset board. My old system with a Z68 chipset, I have been using for years without any issues what so ever. I have three TV tuners attached. 2 x CT-3650 (without any CI), and 1 x CT-4400v2. These thee tuners has been running in RS 1.33 without a single discontinuty. And now, all of the suddon, after getting this nes ASUS X99-A / USB3.1 board, I am getting discontinuty errors like never before. I just have no clue what can be causing this. Cable wise I have not changed a single thing, so I am pretty sure it has nothing to do with my cable signal. I have tried USB2 and USB3 ports, and I just keep getting those errors. It is really annoying since I spent quite a few bucks on this new PC, and I was kinda expecting everything to just run smoothly. I am also using the exact same drivers as before. support.zip file has been attached. Any help will be most appreciated. Thanks in advance. rco133.
rco133 Posted August 14, 2016 Author Posted August 14, 2016 Hi. I would not say that the issue has been resolved, but this is what I have found out since I made the post. It turned out that the errors only happened on the two CT-3650 tuners. I don't know why, and I have not figured out a solution. I guess for whatever reason, the USB chip in the CT-3650, just doesn't work 100% with the USB chips on my new X99 board. Doesn't matter if I use the Intel USB ports or the ASMedia ports. Errors will occur. I have a laptop with 3 CT2-4400 USB Sticks connected. The solution was to move two of those to my new PC, and connect the two CT-3650 devices to the laptop. The new PC seems to run without any problems with the three CT2-4400 tuners, and the laptop also seems to be happy with the two CT-3650 devices. At least I haven't seen any discontinuties on either of the two Pc's since the change was made. Why still remains unanswered, and I guess it will never be answered. The CT-3650 devices are 6-7 years old, so maybe there just is some incombatibility with the USB chipsets on the new MB. Who knows. rco133
