DVBViewer starts with 0% of signal through RecSvr
Przemek211
Hello, my Sat card doesn't start well after opening device in DVBViewer through Recording Service. Oftenly, it shows 0%. I need to jump by few channels or restart application for few times to get it work. If I'll close and start DVBViewer, my problem is getting back.
There is not a problem, if I use my satcard directly through the DVBViewer - everytime it starts well.
As I remember, it was working well when I had configure it, but then it stopped.
I've updated DVBViewer&RecSvr to the newest revisions, but it didn't help.
Edited by Przemek211
So, really no one even try to help me. Sad.
Enable the RTSP Server in the RS an run the RS Wizard in the DVBViewer.
http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer
Is it working then? If not start the DVBViewer via "DVBViewer Pro (Debug Mode)" in the start menu and reproduce the problem an post a new support.zip
There are some messengers in the log which I don't know. Maybe more login will help.
02.08.16 21:21:25.110 TWSocketThread OnError 10057
02.08.16 21:21:25.110 TWSocketThread FWSocketSessionClosed Error 10057
  • Like 1
Wow, it works! It works! Thank you very much, danke schon!
I didn't use RS Wizard tool before, I was using RS as "unicast network device" and that was the mistake.
I've noticed small issue, but I guess you can help me :)
When I wake up my PC from sleep mode, it starts with 0% of signal. I can see that DVBViewer refreshes itself (shows miniepg of the channel). It's enough to change a one channel or restart filters and it works good then.
It's affect only my SatCard, DVB-t card has no problem (It works through RTSP server too).
So, I could guess the problem is made because of my satcard. However, when I decided to use Recording Service (in June), it was starting my satcard very well, except longer time without use (e.g. night), what I described here: http://www.DVBViewer.tv/forum/topic/58413-satcard-doesnt-wake-up-well-after-longer-time/#entry448637
I think you can give me a solution, like you could do that with earlier, much bigger problem :)
///Of course, i've ticked "restart after sleep mode" option in device list of Recording Service.
