Settings about multi satellites (DiSEqC...)
wad34
Hello everyone,
On DVBViewer I have the channels on Astra 19.2 works well, but when I put a channel from Hotbird 13.0 or Astra 28.2 / 23.5 channel is blackscreen.... signal is 98% but power is at 0% (power is at 85% for Astra 19.2)
my LNB is OK, I live in a building with a great professional satellite dish
i think the problem come from DiSEqC, isnt it ?
reception setting for Astra 19.2:
LNB Type: Universal (LOF 9750 / LOF2 10600 / LOF SW 11700)
DiSEqC: Pos B / Opt B
reception settings for Hotbird 13.0:
DiSEqC: Pos A / Opt B
whats wrong with my settings ? thank you for help
Edited by wad34
Nothing, if they match your configuration.
Hiw are you LNBs connected? Which Multiswitch ist used for it?
Here with a normal 9/x multiswitch I have to use Pos B / Opt A for the second satellite.
Edited by Clemens123
