Hansrh 3 Posted September 17, 2016 Share Posted September 17, 2016 As I try to download the Logopack Update I'm asked for login and password - but my logindetails are not accepted :-( Any solution ? Quote Link to post
Joshua06 10 Posted September 17, 2016 Share Posted September 17, 2016 http://www.DVBViewer.com/en/index.php?page=lost Quote Link to post
Tjod 298 Posted September 17, 2016 Share Posted September 17, 2016 You need the eMail address and license password used to install the DVBViewer (not the Data used for the forum) You can run the KeyTool in the DVBViewer folder if you don't find the eMail you got after buying the DVBViewer. Quote Link to post
Hansrh 3 Posted September 17, 2016 Author Share Posted September 17, 2016 Thank's for your reply Tjod but I have already tried that but it always results in the login-box to immediately popup again asking for my login details Quote Link to post
Tjod 298 Posted September 17, 2016 Share Posted September 17, 2016 Which web browser are you using or are you using the "DVBViewer Pro Downloader"? If it is a older IE are you using copy and passed (this can cause problems because of a bug in browser versions) 1 Quote Link to post
Hansrh 3 Posted September 17, 2016 Author Share Posted September 17, 2016 I found out what caused the problem - Internet Download Manager . Once I disabled it the download worked just fine. Quote Link to post
