rofu Posted September 20, 2016 Posted September 20, 2016 I've 2 Terratec S7 tuners. Both is working. I've tested them one by one. I'm only able to record on program at the same time. If I'm watching a live program and a recording start, my live program freeze. If a recording takes place and a new one starts than I end up with many small file pies for the new recording. They are useless. In the web configuration I can see the status of the 2 two tuners. Everything seems okay. Any suggestion Quote
Gioxy Posted September 20, 2016 Posted September 20, 2016 And how the 2 Terratec S7 are linked to the dish(es)? Quote
rofu Posted September 20, 2016 Author Posted September 20, 2016 And how the 2 Terratec S7 are linked to the dish(es)? Dual Head LNB Quote
Gioxy Posted September 20, 2016 Posted September 20, 2016 "Dual Head LNB" usually mean that you can receive 2 sat position (one by one, depending on DiSEqC) but don't tell nothing about how the LNB is cabled with your 2 cards...: How many output (and then cable) have got your LNB, four, two or only one? Is it a "traditional" LNB or SCR one? And in the case of one output, how do you split the cable between the 2 cards? Quote
rofu Posted September 21, 2016 Author Posted September 21, 2016 "Dual Head LNB" usually mean that you can receive 2 sat position (one by one, depending on DiSEqC) but don't tell nothing about how the LNB is cabled with your 2 cards...: How many output (and then cable) have got your LNB, four, two or only one? Is it a "traditional" LNB or SCR one? And in the case of one output, how do you split the cable between the 2 cards? It takes in one sat position and have 2 cable output. I'm using one cable to each tuner. I have tested that both tuner are working. (I can look at tv from them one at a time) Quote
Griga Posted September 21, 2016 Posted September 21, 2016 http://www.DVBViewer.tv/forum/topic/29120-enable-DVBViewer-to-manage-multiple-tuners-at-one-time/?p=451097 Usually two or more active tuners at the same time are no problem.(...) However, there are users who encountered problems with two tuners of the same type (from the same manufacturer) due to driver issues preventing the usage of both tuners at the same time. Quote
