hsv Posted September 28, 2016 Posted September 28, 2016 Hi Suddenly, from Monday to Tuesday my TV Server stop working. The windows Server has completed a "windows update" during the night. The Server is a Windows Server 2008 R2 I have now updated:both TV tuner cards from Digital Devices (DVB-C)Updated to 5.6.4 for DVBViewer from 5.5.2Updated to 1.33.1 from 1.32 DVBViewer Recording ServiceUpdated codec from Shark007 advanced to 6.5.1 from 5.x.xDigital devices has a debugging tool and it looks like i get a signal in. Also my DVBviwer write the correct station, I do not know if it is based on my selection or to the feed. But no sound or video stream are coming through. Any suggestions about how to debug solutions more or a solution to find the reason will be appreciated:-) Regards Henning Quote
hsv Posted September 28, 2016 Author Posted September 28, 2016 (edited) Hi I have now tried to generate som recordings at the same time and get this result: See attached picture Can anybody help me translating the last column Regards Henning Edited September 28, 2016 by hsv Quote
Tjod Posted September 28, 2016 Posted September 28, 2016 If you change the driver, you should re detect the hardware in the RS. And start with recordings. Only if they work you should try playback. Maybe the Windows update causes problems with added BDA support. Quote
hsv Posted September 28, 2016 Author Posted September 28, 2016 (edited) Hi Thanks for your suggestions. Yes I saw that they were red so I pressed scanned, and corrected the settings, see attached picture. I restarted the services after this. But stil no stream and sound, but it tells all information in the statusbar of DVBViewer about the program. Could be, but what stands BDA for? Edited September 28, 2016 by hsv Quote
Tjod Posted September 28, 2016 Posted September 28, 2016 If recording works the driver should be OK. BDA stand for Broadcast Driver Architecture a standard for TV card driver. But Microsoft has remoulded the support for that from many server systems. So you mostly has to tinker around to get it to work by copping file from a non server Windows in your System. If recording works post a support.zip Quote
hsv Posted September 28, 2016 Author Posted September 28, 2016 Hi I found in the event viewer that there was some errors on first of my tune cards. So I contacted Digital Devices Support to find out what error "Device 300:20000 Tune failure DVBT filter 1" meant And after a little time he found out that the first TV-Tuner card was defect. In the support process he showed how to use a program from DVBViewer called TransEdit This wonderful program can see what comes in on the TV-Card and this way you can see if it works. Under settings you can select which cards you will test. This way we could see that Tuner card 1 was defect and 2 was ok. I have now modified and only selected card nr 2 and now I have TV again. I have now order a new card from Digital Devices. Quote
Tjod Posted September 28, 2016 Posted September 28, 2016 If a TV card had worked with the DVBViewer/RS under Windows Server 2008 R2 you some one had added BDA support manually on the PC. Quote
hsv Posted September 28, 2016 Author Posted September 28, 2016 The support guy dit a test for DBA with a test program on the server. I did not catch what it was but with this he could see that DBA worked. But thanks for you help and support:-) Quote
hsv Posted September 28, 2016 Author Posted September 28, 2016 I have just found out that the program is called DxDiag. It produce a text file and in this you can a lot of information. And I can see this that shows that DBA is working: BDA Transport Information Renderers:BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514 BDA CP/CA Filters:Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17514Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17514PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17514XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17514 Quote
