Force DVBViewer to handle recordings
Przemek211
Hello, I use RecSvr only because you've stopped to support DVBServer. So is it possible to let DVBViewer handling the recordings? :original:
Options -> Recording Service -> Send timers to the service off.
Then you should disable there "Connect to timer list" and "Ignore local recordings list" as well. If you disable "Connect to recordings list" (list of recordings in the RS) is up to you.
