trrt3 Posted October 11, 2016 Posted October 11, 2016 (edited) Hi, sorry if my english is bad and poor. I have test to record on 3 pc's. And on all i have problem. suddenly I have a lot of 'discont.' in the record status, hundreds, thousands(more than 24000 in one hour) of, and this makes the recording unwatchable. can you help me to solve this or understand why ? thanks Edited October 11, 2016 by trrt3 1 Quote
Tjod Posted October 11, 2016 Posted October 11, 2016 Mostly it is a reception problem. It can be caused by the antenna position, a lose/defekt connector, a bad antenna cable, interferences in the PC (if it happen in multiple PCs not licitly), defect of the DVB hardware or a driver problem. Quote
trrt3 Posted October 11, 2016 Author Posted October 11, 2016 hi, thank you for the answer. On receipt I am 98% and when I watch live TV I have no such problems. possible problem with dvb hardware, i have Evolveo Venus usb. Quote
Tjod Posted October 11, 2016 Posted October 11, 2016 The signal strength displayed in the DVBViewer is worthless with most DVB drivers (every one should ignore it completely). If you get discontinuities it is mostly a reception problem. Quote
trrt3 Posted October 11, 2016 Author Posted October 11, 2016 Ok if it's a reception problem, i don't know why, it's the same antenna on my TV and on TV 0 problem Quote
Gioxy Posted October 12, 2016 Posted October 12, 2016 How the same antenna is shared between TV and Evolveo Venus? Can you test inverting cables? Anyhow, consider that a USB receiver can't be as sensible as a TV set... In any case try to check discontinuity problems with Transedit (you can download it in Members Area), with TV on and TV off... Quote
