bccrew Posted January 4, 2017 Posted January 4, 2017 (edited) Hello, When I want to perform a channel scan and I want to change the frequency range to a smaller range, I have noticed that the start range value always changes back when manually changing the end value. I have made a video about this behaviour. At the moment it's kinda annoying that I always have to change the Start value again. I want to scan from value 50 till 75 and when I change the end value to 75 the start value changes back to 7 instead of leaving it at 50. Thanks for fixing! movie: https://www.dropbox.com/s/2vlluo3gypk6htc/2017-01-04%2022.15.02.mp4?dl=0 Edited January 4, 2017 by bccrew Quote
Griga Posted January 5, 2017 Posted January 5, 2017 Your video doesn't play here, but I know what you mean. It happens because DVBViewer takes care that the start position is always less or equal than the end position. Switching the auto-correction off would fix the issue, but allow impossible input. It had to be corrected later (e.g. when scanning starts) without becoming visible. Dunno if this is really better You can avoid the issue by first entering the end position and then the start position. Or by using the up-down buttons. Quote
bccrew Posted January 5, 2017 Author Posted January 5, 2017 Allright I just thought it was a small cosmetic bug hehe No worries. Quote
