There is no sound on only two channels.
jampeer
Hello.
I use Google Translate, because they do not speak English.
Help solve the problem of the lack of sound on channels Futbol1HD and Futbol2HD Xtpa TV package with satellite 9E.
On all other channels of the sound package is, there is only on these two channels.
No manipulation of codecs and render not pomogayut.Stranno that the problem only on the two channels.
If someone takes these channels please tell me your configuration.
Here are my settings:
[/url]">http:// [/url]">http://http://uploads.ru/B1EXC.jpg'>B1EXC.jpg
To test try DVB Dream, here with a sound that's all right.
What's my mistake?
Thank you.
Edited by jampeer
While on one of the channel, with the problem open Settings > Filters > DVB Source
and look in the second line what the audio format is. And in the fourth line Audio State: ... what is shown there?
And attach a support.zip
If I understand you correctly that here:
I should add that sometimes the sound breaks at the fraction of a second.
Edited by jampeer
Settings -> Options -> DirectX -> DVBViewer Filter -> TV/Radio Pre-Format Detection -> Audio will help.
Or try the Microsoft Audio Decoder for AAC (DirectX ->Renderer/Decoder -> Audio -> AAC Audio Decoder).
Thank you.
Tried, negative
When you select Microsoft Audio Decoder sound is lost on all channels package.
Tell me why the program does not see the other codecs? How are they correctly set?
It is strange that the sound works with the LAV Audio Decoder .
Edited by jampeer
:oops: The problem was solved by setting MainConcept ААС Decoder !Thank you.
  • 2 months later...
Hello.
Please tell me which video codec you need to use to view the HEVC.
When using LAV Video Dekoder, the channel shows the bars.
Thanks.
