McPingvin Posted December 28, 2004 Posted December 28, 2004 I have a problem with winLIRC on skystar2.When i try to initalize winLIRC it says:winLIRC failed to initalize.Would you try to change the configuration and try again? I'm using IR on COMPORT1 Can you help me? Quote
Klausing Posted December 28, 2004 Posted December 28, 2004 Please PDF-manual from TechniSat, there you find all needed information. Quote
McPingvin Posted December 28, 2004 Author Posted December 28, 2004 errr,there are no skystar2 manuals... Quote
Klausing Posted December 28, 2004 Posted December 28, 2004 They are in the driver package. If not ask TechniSat. In the past you could find them there. Quote
Gioxy Posted December 29, 2004 Posted December 29, 2004 You can find more in the WinLIRC web site... Or also try this WinLIRC alternative: Wirr, that's simpler to configure and, at least for test pourpose, can perfectly replace WinLIRC... Gioxy Quote
McPingvin Posted December 29, 2004 Author Posted December 29, 2004 i dont know italian,and google finds onla ###### sites powered by wi.rr and in the manual are no enswers about the winLIRC... Quote
Gioxy Posted December 29, 2004 Posted December 29, 2004 WinIRC site isn't italian ...sorry instead for the strange Wirr link, dunno what's up... Try this instead: http://ideegeniali.altervista.org/animax/download.html: yes, the site is in italian, but you have simply to click on the Wirr link (the third one...)... ...but maybe you simply haven't noticed that the undelined words of my previous post were links to the sites I mentioned... ...let me say with Woody Allen: "Play It Again, Sam!" Gioxy Quote
McPingvin Posted December 30, 2004 Author Posted December 30, 2004 thnx for wirr.it is working.now,how to make skystar2 to use wirr instead of winlirc? Quote
Gioxy Posted December 31, 2004 Posted December 31, 2004 Nothing special at all... Wirr is already a perfect WinLIRC clone, so all the operation you have to do are: • install and configure Wirr assigning some string to your RC keys • set DVBViewer to use WinLIRC • configure DVBViewer remote keys selecting the function and pressing a RC key • enjoy... Moreover with Wirr you can change the key setting in real time... Good luke! Gioxy Quote
Robin Posted January 25, 2005 Posted January 25, 2005 Hello I have been watching the correspondence about IR remote control as I have been unsuccessful. I have not tried wirr and , though at least it opens for configuration, unlike WINLIRC, I cannot get a response. My IR receiver is part of a Matrix front panel connected to the motherboard. I have enabled it, and successfull transferred data through it. It immediately recognises my mobile phone. But respond to a remote controller - no way. There are a variety of settings, and I wonder if anyone can spot what I am doing wrong. Alternatively, what other USB or serial device is sure to work? This is way out of my depth. Onboard SIR 3F8/IRQ4 (I have tried other settings) IR Mode select IrDA RxD, TxD Active Hi, Lo IR transmission delay - enabled UR2 Duplex mode half Ise IR pins IR-Rx2T x2 Grateful for any advice Quote
Guest Lars_MQ Posted January 25, 2005 Posted January 25, 2005 It immediately recognises my mobile phone. But respond to a remote controller - no way. Well I would say you trying to use a IRDA IR-Receiver with a normal IR-Control. It won't work in most cases, cause they use different frequencies. For a list of working IR-Receivers have a look at the Lirc Homepage that's the linux pedant to winlirc and simple receivers working with lirc will work also with winlirc. lars Quote
Gioxy Posted January 25, 2005 Posted January 25, 2005 As you can read in his site (winlirc.sourceforge.net, WinLIRC (as also Wirr) doesn't support IRDA port or any other MB integrated IR, but only a simpler receiver connected to one of the standard serial PC port... You can also search Internet for "Animax", the name that most often is used to refer to this kind of receiver... not so many time ago there was various place where you could buy it for a couple of buck... Quote
joewil Posted January 31, 2005 Posted January 31, 2005 Nothing special at all... Wirr is already a perfect WinLIRC clone, so all the operation you have to do are: • install and configure Wirr assigning some string to your RC keys • set DVBViewer to use WinLIRC • configure DVBViewer remote keys selecting the function and pressing a RC key • enjoy... Moreover with Wirr you can change the key setting in real time... Good luke! Gioxy <{POST_SNAPBACK}> I too have been having problems getting WinLIRC to work, the replies are hard to follow. Can anyone explain what I need to do in simple english, I can get TV channels but not radio channels and of course WInLIRC says failed to initialise. Quote
Klausing Posted January 31, 2005 Posted January 31, 2005 inside the driver package is aPDF manual for WinLIRC. You only have to read this! There are all informations which you need. BTW. for DVBViewrTE the makes TechniSat support . Here is the forum for DVBViewerPr Versoin Quote
