All 4k/UHD channels have no video and show resolution of 0x0
This affects all 4k Channels :( They work fine in progdvb but I dislike it, I want to use DVBViewer.
The problem is only with the video, the audio is decoding and playing back fine.
I have included an image of the problem and my support.zip
Please help if you can.
Thanks for the response craig_s, I went out and bought a 1060 gpu today and set the lav filter to use it.
I still have the issue, and progdvb still decodes the channels fine, What can i do to get them working?
I really don't want to have to switch over to progdvb :(
Maybe your channel list is out-dated. I've attached the four free UHD channels on Astra 19° East that I can receive with DVBViewer (not really well, because my PC is too slow, but I get at least video & audio). Drag and drop the attached INI file into the DVBViewer channel editor.
uhd.ini
  • Like 1
Thanks guys. I backed up my channel list and epg. uninstalled DVBViewer, restarted my pc, reinstalled DVBViewer, and restored my channel list and epg, and it's all working fine now so I don't know what was up. Some glitch in the matrix I guess. Thanks for your responses and help :)
