picture capture
linusalba
hi, i would like to capture some picture from a film with DVBViewer.
Is it already possible? It should be a new idea for DVBViewer.
CIAO, Marco
load your mpg to a player (powerdvd,....) and make your shots.
Greetings Plubsi
Guest Michael
CIAO, Marco
screenshots will be officaially supported with the incoming XVR renderer
ENG
Yes, you'd use DVD2AVI:
1. Load your .mpg or .m2v;
2. choose Video > Color Space > RGB
3. move the slide bar on the frame you want to shot;
4. press "B"
and you'll find your picture in the same directory you've installed DVD2AVI.
ITA
Si', basta usare DVD2AVI:
1. Carica il tuo fimato .mpg o .m2v;
2. scegli Video > Color Space > RGB
3. posizionati con la slide bar sul fotogramma che vuoi catturare;
4. premi "B"
e troverai il fotogramma nella stessa directory in cui hai installato DVD2AVI.
There is a way to capture screenshots directly from the DVBViewer with the following steps:
- Deactivate the Overlay Mixer in the options and terminate the DVBViewer
- Launch another program that uses overlay, any player will do... let it play a short part of a video and then let it pause.
- Launch the DVBViewer again. It won't use overlay now, because overlay is already occupied. Then make your screenshots with ALT+PrintScr.
Griga
Griga
well, you can always work around a problem....
but it would be really nice to get that feature implemented directly in DVBViewer.
thanks.
