felix_max Posted February 1, 2018 Posted February 1, 2018 Hello, I'm looking for ay tips, wiki, guide to stream from Win10 DVBViewer PRO to a Amazon Fire TV Stick on same LAN (and wifi). Is there anyone who wants to guide me on how to do? Thank you!! Quote
felix_max Posted February 10, 2018 Author Posted February 10, 2018 No one can help me??? Really?? Quote
Lakeuk Posted February 10, 2018 Posted February 10, 2018 Install Kodi on your firestick, then on kodi install the DVBViewer client add -on, you'll find it in the PVR add-on section. Youtube will have a walkthrough video, likely to be against an older version of kodi but you should be able to figure it out. Quote
felix_max Posted February 11, 2018 Author Posted February 11, 2018 I do this but Kodi can only see channel list and EPG but no video (and audio) at all. Quote
Cian Posted February 12, 2018 Posted February 12, 2018 (edited) Could be a ports issue on the PC. From my small experience, one you can see the channel list and EPG, things should be good to go. Try turning off your Windows firewall and see if that fixes it. If it does, you know that is the problem and you can open the specific ports on the PC. (Don't leave your firewall turned off though - that's asking for problems!) Edited February 12, 2018 by Cian Quote
felix_max Posted February 12, 2018 Author Posted February 12, 2018 Thank Cian. I'll give it a try. Quote
