transcode x265
mezzy
hi
i want to know if transcode with libx265 is possible? because i've got low bandwith
i've tried to modified ffmpeg_prefs.ini with no success (no video )
when we install ffmpeg  - is libx265 librairy installed by default ?
someone has a config file to share ?
thanks
Launch ffmpeg.exe without parameters from the command line for getting information about what is enabled. libx265 is included in up-to-date builds from Zeranoe.
For using HEVC instead of H.264 you need to replace libx264 by libx265 in the file ffmpegprefs.ini - see installation directory (where DVBViewer.exe is), config sub-directory. Additionally the following options have to be removed from the preset because libx265 does not understand them:
-tune film
-vprofile main
-vprofile baseline
-level 30
For getting a lower data rate you need to use higher -crf xx values, approx. plus 5 compared to H.264. Read more about it here.
libx265 can only be used for TS presets (and maybe flash, I didn't try...). The next DVBViewer Media Server release will allow to configure HEVC video for transcoded  TS output in the web interface.
Please note that transcoding to HEVC causes a high CPU load on the server PC - much more than H.264.
hi
with test i can load video files in DVBViewer but in KODI-addon it seems not transcode
some has an idea ?
