Can't link DVBViewer to DMS
paulie68
I'm a long time user of both DVBViewer Pro and Recording Service/Media Server and have never previously had a problem until now.  After the recent Windows 10 update I am unable to connect DVBViewer to DMS.  I've reinstalled both programs - no change.  I've reinstalled Windows 10 (1803)  no change.  I've checked the firewall and even disabled it - no change.  It's just not there...
If i manually set the server in Options it fails...
Any ideas?
Thanks, Paul
Most likely due to a bug in the DMS 2.1. Announcing the Sat>IP/RTSP server in the network only works if the UPnP AV server is enabled (see second screenshot above). So just tick this checkbox as work-around. There will be a bugfix release within the next days.
Yes; that worked.  One check box versus all I did.  Should have asked the question earlier so lesson learned!
Many thanks for the quick response and for your excellent software.
