Recommended Server graphic card
e123enitan
I'm running every thing through server (details specs below), 4 client is running fine, I planned to ADD another Tuners (same as the current ) to server additional  4 users, making total of 8 clients. My concerns if the Video Ram is sufficient to handle the additions or If I need to upgrade Video card with Big RAM.
DVBViewer Version: 6.1.1.0
Tuner Card TBS 6985 Quad DVBS/S2
OS:
Windows 7 x64 Service Pack 1
OS Build: 7601
Aero enabled: True
DirectX:  10.0
Memory:  6141 MB
CPU:  Intel(R) Xeon(R) CPU  E5620  @ 2.40GHz
CPU Speed:    2394 Mhz
CPU Count:    8
Videocard:
Nvidia Geforce
GPU Engine Specs
CUDA Cores 16
Graphics Clock 35 MHz
Memory Clock 135 MHz
Memory 1024 mb
You don't need a graphics card in the server for the DMS at all ?
The DMS ist just transferring extracted data streams to the clients. All video processing (MPEG, H.264, H.265, ...) is done at the clients, not the server.
Only if you transcode streams to different formats i.e. with ffmpeg for special clients the cpu of the server has to do the work.
Thank you, more like what thought.
