Otto Lanjouw Posted September 9, 2018 Share Posted September 9, 2018 Hi i have used DVBViewer for years, but had to reinstall windows. Pc, card and cable connection arent changed Installation of DVBViewer went without errors however i can't get the correct channels back in reception type i only see TS Stream, im using cable tv and infortunately dvb-c is not available any ideas? Quote Link to comment
Griga Posted September 9, 2018 Share Posted September 9, 2018 DVB-C should show up as reception type if your DVB-C device has been detected. Go to Options -> Hardware and check if your DVB-C device is listed there. If not, click "Scan Devices". If it still doesn't show up, check the status of the device and its driver in the Windows Device Manager. Quote Link to comment
