scooby81
IPTV - M3U via URL - Refreshing channels
scooby81
Hello all,
I have had a look through the existing forum topics.
Found a few good posts on using Transedit to "scan in" channels from a M3U file - but my question is different.
I am using DVBViewer Pro 6.1.2 and really looking to understand whether what I want to achieve is even possible.
Any help appreciated.
I would like to maintain a M3U playlist of IPTV channels available from a fixed URL
The playlist would ONLY include TS streams
Each channel would be coded to provide channel name, category, EPG ID and logo url
For example:
#EXTINF:-1 tvg-id="BBC1.uk" tvg-name="BBC1.uk" tvg-logo="http://expatiptv.org/logo/ent/bbc%20one.png" group-title="UK ENTERTAINMENT",BBC ONE HD [+]
I would like DVBViewer to:
Download the M3U playlist via the URL
Automatically parse / scan the channels, creating the categories defined in the M3U
On a regular (e.g. 24 hours) basis, repeat the process, overwriting the existing data
Anyone know if this is achievable?
Thank you.
Share this post
Link to post
Griga
DVBViewer does not support automatic M3U download.
Share this post
Link to post
jampeer
Hello.
Can you please tell if it is possible to download EPG for IPTV channels?
Sorry, I use a translator.
Share this post
Link to post
jampeer
Thank.
Did as indicated on your link but the EPG did not appear.
Apparently I have to add my link to the EPG?
How to do it right?
Thank.
Share this post
Link to post
jampeer
Hello.
How to watch IPTV archive?
Share this post
Link to post
hackbart
What do you mean? You can add IPTV channels into the DVBViewer and handle them like regular DVB channels. Right now HLS, TS and Shoutcast resp. IceCast channels are supported. We do work on Dash which will need some time.
This thread is about assigning IPTV channels with XEPG in order to get EPG working.
  • Like 1
Share this post
Link to post
jampeer
Hello.
Yes, I normally watch IPTV channels in live mode. But the provider gives the function of viewing channels in the recording, this function is called the archive. The transmissions for the elapsed time are turned on from the EPG window.
Is there such an opportunity in dvb weever? Naprime in prog dvb this is implemented .For this, you need to have a playlist URL in the program. Thanks.
Edited by jampeer
Share this post
Link to post
