greglip Posted October 5, 2018 Posted October 5, 2018 Hallo, I have a Technisat Skystar USB 2 HD CI and it doesn’t work under Windows 10 64bit system on i7-8700K and Z370 platform. Each time I try to scan channels results immediately with a blue screen. Driver is the last one available. I have tried almost everything. Is there any way to resolve this problem. Does any one have a similar platform working fine. Regards Greg Quote
kmfan Posted October 6, 2018 Posted October 6, 2018 I guess you connected the box to a USB 3 port, Technisat Skystar USB 2 HD CI likes USB 2, this should solve your problem with the blue screen. Quote
greglip Posted October 7, 2018 Author Posted October 7, 2018 Thank's but I've already tried all possible ports including 2.0, always blue screen. Quote
kmfan Posted October 9, 2018 Posted October 9, 2018 Technisat Skystar USB 2 HD CI must be connected to USB 2, there is no workaround, using UBS 3 will always crash the PC. Using USB 2 should not crash your PC, test an other USB cable first, maybe it's broken. If you have the chance testing the box with an other PC, you should do it to exclude if the box is defect, if nothing happens you know the hardware is ok and you can continue searching the bug. It is necessary you are using an USB 2 port! Quote
greglip Posted October 13, 2018 Author Posted October 13, 2018 As I've told you before I"m using USB 2.0 port. On my second PC, but with H67 chipset and i7-2600, all other parts the same including W10 64 - everythig works perfectly. The problem is in Z370 chipset (ASUS ROG STRIX Z370-G GAMING microATX board) Maybe USB driver or maybe not. Quote
PJay Posted November 3, 2021 Posted November 3, 2021 Technisat Skystar USB 2 HD CI causes BSOD with Asus B75M-A and Windows 10 x64 but no problem with Windows 7 x64. It doesn't matter if I change the USB settings in BIOS. Quote
hussun Posted August 13, 2022 Posted August 13, 2022 The driver file I have given in the link below is pass permission in windows 11 https://mega.nz/file/fUY11LyI#ndsLHg0PmzMxlxWcBGjWeEBI60YlJlbGw6ndXB4v96s mega key:ndsLHg0PmzMxlxWcBGjWeEBI60YlJlbGw6ndXB4v96s Quote
Elit3 Posted September 22, 2024 Posted September 22, 2024 Hello Hussun, Is that driver still working for you now? With the latest version of Windows 11 Pro 23H2 I have a blue screen. Thanks. Quote
Elit3 Posted September 25, 2024 Posted September 25, 2024 Hello, Could you approved this content? thank you. Quote
Griga Posted September 25, 2024 Posted September 25, 2024 Sorry, it was overlooked. Has been approved now. Quote
