chingpk Posted November 9, 2018 Posted November 9, 2018 I was using recording service before and i update to media server 3 days before. Unfortunately after I update to media server, the service halt 3 times in 2 days. The features are that 1.the web interface cannot be open, 2.new timer cannot start, 3.the recording timer will not automatically stop recording. I tried to uninstall both DVBViewer and Media Server, however the problem still happened. My machine is a Windows 10 Pro and i use TBS6514 tuner for recording. Do you guys have any idea what is going on. Thanks a lot for you attention. Quote
Griga Posted November 10, 2018 Posted November 10, 2018 A support.zip would be good for getting further insight. A frequent cause for this kind of trouble is the file TbsCIapi.dll, that enables CI support for TBS cards. If you don't need it it is recommendable to switch Media Server Options -> Hardware -> Has CI off for all TBS tuners or to remove the DLL from C:\Program Files (x86)\DVBViewer or at least to update it to the latest version from the TBS site: https://www.tbsiptv.com/download/common/tbs-cidll_v1.0.2.2.zip 1 Quote
chingpk Posted November 10, 2018 Author Posted November 10, 2018 Noted. I will try this later. Thanks a lot. Quote
