SunCo Posted January 7, 2019 Posted January 7, 2019 Hello! I'm experiencing a problem. Just upgraded my monitor to a 4k uhd one (3840x2160). If i use the EVR custom presenter it works fine in any windowed mode. But if i click full screen the screen dies with black screen. And only the program's restart helps. Same with SD and HD sources too. On full hd resolution the fullscreen worked fine. The same EVR custom presenter in mediaplayer classic works fine in full screen with the very same presenter. Also the full window size works, just the 4k fullscreen is dead in DVBViewer. I tried different decoders too with the same result. Temporary i can use for fullscreen the madVR presenter, but that eats too much resource. Any ideas how can i get use of the EVR custom presenter back in 4k fullscreen? Thanks Quote
SunCo Posted January 9, 2019 Author Posted January 9, 2019 Excuse me for the double post, i did not find where to edit my original post for the attachment. support.zip Quote
Webturtle Posted January 10, 2019 Posted January 10, 2019 Hello, @SunCo: Newbies are not able to edit their original posts. When you have written more post (about 50 or so ?) you'll find under your postings a button like "edit". Many greetings Webturtle Quote
