Jacob Andersen 0 Posted January 8 Hi, I have just installed the Video Editor and I test ran it on a full length movie trying to skip commercials. It detected the commercials just fine but when I try to save the cut it just hangs. I have tried it three times now and it hangs at the same spot every time. As you can see on the attached screen dump then this has been hanging for 11h and nothing happens. Any ideas? Regards, JSA Quote Share this post Link to post
Jacob Andersen 0 Posted January 8 (edited) Inspired by other reports then I switched to the 32bit version (as the above problem was for the 64bit version) using the same project file so I did not have to redo the comskipping again. I runs without any problems on the 32bit version. /JSA Edited January 8 by Jacob Andersen Quote Share this post Link to post
