jactkwn Posted February 3, 2019 Posted February 3, 2019 I have tried DMS to record several Youtube channels, but the recordings are 'corrupted', no timecode shown, and cannot be opened/deleted easily through Windows Explorer. I need to open the file inside the player. But nothing wrong when I record other non-Youtube channels. How to fix the issue? And is there a way to update the channel list of DMS instantly, so I don't need to restart the computer? Many thanks. Quote
Griga Posted February 3, 2019 Posted February 3, 2019 vor 2 Stunden schrieb jactkwn: the recordings are 'corrupted', no timecode shown, and cannot be opened/deleted easily through Windows Explorer. May be a consequence of removing the clock reference. The Explorer may get into trouble or even crash if the decoder or other components used for thumbnail creation can't cope with the file content somehow. vor 2 Stunden schrieb jactkwn: is there a way to update the channel list of DMS instantly, so I don't need to restart the computer? You only need to stop / restart the DMS by using the DMS tray menu. Quote
jactkwn Posted February 3, 2019 Author Posted February 3, 2019 (edited) 5 hours ago, Griga said: May be a consequence of removing the clock reference. The Explorer may get into trouble or even crash if the decoder or other components used for thumbnail creation can't cope with the file content somehow. No improvement. I have tried to record after unclicking removing the clock reference, and the recording still can't show duration on the explorer. For non-Youtube channels, even if I click the removing the clock reference, the recording can still show duration BTW, how to "save" the recordings that fail to create thumbnail? Edited February 3, 2019 by jactkwn Quote
Griga Posted February 3, 2019 Posted February 3, 2019 vor 30 Minuten schrieb jactkwn: the recording still can't show duration on the explorer. Most likely because the broadcasted time stamps are corrupted. Sometimes internet streams are quite far away from being "clean". You can try to use TSPlayer (see download area -> tools) for re-recording the file and applying a time stamp continuity correction. Read more about it here and here. Quote
jactkwn Posted February 3, 2019 Author Posted February 3, 2019 (edited) 1 hour ago, Griga said: Most likely because the broadcasted time stamps are corrupted. Sometimes internet streams are quite far away from being "clean". You can try to use TSPlayer (see download area -> tools) for re-recording the file and applying a time stamp continuity correction. Read more about it here and here. Not really working. However, I can see the correct duration from Day 1 when I play it in players. Just have difficulties in creating thumbnails and thus difficult to open/delete thru Windows Explorer. Edited February 3, 2019 by jactkwn Quote
jactkwn Posted February 17, 2019 Author Posted February 17, 2019 Now I face another question: DMS will “hang” suddenly, which I have not experienced before. how can I solve/prevent it? Quote
jactkwn Posted March 7, 2019 Author Posted March 7, 2019 On 2/4/2019 at 12:21 AM, jactkwn said: Not really working. However, I can see the correct duration from Day 1 when I play it in players. Just have difficulties in creating thumbnails and thus difficult to open/delete thru Windows Explorer. I wonder if there is any other solution? Mant thanks. Quote
jactkwn Posted July 19, 2020 Author Posted July 19, 2020 On 3/8/2019 at 1:27 AM, jactkwn said: I wonder if there is any other solution? Mant thanks. I wonder if we are able to choose recording all streaming into mp4 format. That may solve the problem. Many thanks. Quote
Griga Posted July 20, 2020 Posted July 20, 2020 Am 19.7.2020 um 12:40 schrieb jactkwn: I wonder if we are able to choose recording all streaming into mp4 format. Not possible. You can only let the DMS transcode recordings to MP4 after they are finished by selectiing "Generate MP4/MP3" as task after recording in the web interface timer dialog. Generally you are providing too little information for getting help. You should at least attach a support.zip. Quote
jactkwn Posted July 23, 2020 Author Posted July 23, 2020 On 7/20/2020 at 9:04 PM, Griga said: Not possible. You can only let the DMS transcode recordings to MP4 after they are finished by selectiing "Generate MP4/MP3" as task after recording in the web interface timer dialog. Generally you are providing too little information for getting help. You should at least attach a support.zip. I am simply saying if the file name of recording can be .mp4 at least, just like if I use streamlink, I can choose using file name with .mp4 instead of .ts So the recording is still in MPEG transport stream format but with file name ending with .mp4 Quote
Griga Posted July 26, 2020 Posted July 26, 2020 Am 23.7.2020 um 15:40 schrieb jactkwn: So the recording is still in MPEG transport stream format but with file name ending with .mp4 Why? Doesn't make sense to me. Quote
jactkwn Posted July 28, 2020 Author Posted July 28, 2020 On 7/26/2020 at 7:59 PM, Griga said: Why? Doesn't make sense to me. as mentioned above, I have tried DMS to record several Youtube channels, but the recordings are 'corrupted', no timecode shown, and cannot be opened/deleted easily through Windows Explorer. I need to open the file inside the player. If the file name is ending with .mp4, no thumbnail will be created so the file can be played normally. Quote
