yakov2905 Posted February 6, 2019 Posted February 6, 2019 Hi. I configured ffmpegprefs.ini to transcode on GPU many times/versions ago, and all worked fine before last 2.1.4 update. If I downgrade DMS to 2.1.2 , GPU transcode resumes to work. In support.zip you can fing ffmpegpref.ini, I not configured all lines to work (some of them wrongly configured). Only TS streams which contains input format description are right and working on 2.1.2, for instance - this most used config, 100% working: [TS H264 Low-Mid 1000 kbit] GPU: Spoiler [Display] Operating System: Windows 10 Pro, 64-bit DirectX version: 12.0 GPU processor: Quadro P400 Driver version: 391.58 Direct3D API version: 12 Direct3D feature level: 12_1 CUDA Cores: 256 Core clock: 1227 MHz Memory data rate: 4010 MHz Memory interface: 64-bit Memory bandwidth: 32.08 GB/s Total available graphics memory: 6110 MB Dedicated video memory: 2048 MB GDDR5 System video memory: 0 MB Shared system memory: 4062 MB Video BIOS version: 86.07.39.00.0B IRQ: Not used Bus: PCI Express x16 Device Id: 10DE 1CB3 11BE10DE Part Number: G212 0500 [Components] nvui.dll 8.17.13.9158 NVIDIA User Experience Driver Component nvxdplcy.dll 8.17.13.9158 NVIDIA User Experience Driver Component nvxdbat.dll 8.17.13.9158 NVIDIA User Experience Driver Component nvxdapix.dll 8.17.13.9158 NVIDIA User Experience Driver Component NVCPL.DLL 8.17.13.9158 NVIDIA User Experience Driver Component nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel nvCplUI.exe 8.1.940.0 NVIDIA Control Panel nvWSSR.dll 23.21.13.9158 NVIDIA Workstation Server nvWSS.dll 23.21.13.9158 NVIDIA Workstation Server nvViTvSR.dll 23.21.13.9158 NVIDIA Video Server nvViTvS.dll 23.21.13.9158 NVIDIA Video Server nvLicensingS.dll 6.14.13.9158 NVIDIA Licensing Server NVSTVIEW.EXE 7.17.13.9158 NVIDIA 3D Vision Photo Viewer NVSTTEST.EXE 7.17.13.9158 NVIDIA 3D Vision Test Application NVSTRES.DLL 7.17.13.9158 NVIDIA 3D Vision Module nvDispSR.dll 23.21.13.9158 NVIDIA Display Server NVMCTRAY.DLL 23.21.13.9158 NVIDIA Media Center Library nvDispS.dll 23.21.13.9158 NVIDIA Display Server NVCUDA.DLL 23.21.13.9158 NVIDIA CUDA 9.1.84 driver nvGameSR.dll 23.21.13.9158 NVIDIA 3D Settings Server nvGameS.dll 23.21.13.9158 NVIDIA 3D Settings Server support.zip Quote
yakov2905 Posted February 6, 2019 Author Posted February 6, 2019 Resolved, FFmpeg issue. Updated to last FFmpeg version. Quote
Tom Nee Posted November 19, 2020 Posted November 19, 2020 Hi, I would like to enable nvenc on my server, too Is it possible you send me your modifications of your ffmpegpref.ini ? Regards Quote
