Full Screen Output
Warlord007
hi all
my first post :wub:
well ive read all the documents i can find, and "most" of the plugins for this feature
what i am looking for is an option for full screen to be sent to the second monitor/tv
i use the tv output a lot with dvb , and the main problem is you cant read any small print on the tv screen, so it means u have to keep dropping back to a window, dragging DVBViewer back to the monitor screen, change channel, drag back to tv and then go full screen
an option to leave the app on the monitor but output full screen to tv would be a godsent :)
i have only ever seen this option in 1 other dvb app, and it dosent support my cable card so i cant use it
wonder how long the wifeee is gonna put up with me keep interupting her viewing while i make small changes to the settings hehe
great app all, keep up the good work, im running the beta version and found nothing wrong yet, but its only been 1 night
tnx all
warlord
Most up-to-date graphics cards provide such a feature (my GeForce MX 440 does). It's called "Theater Mode" (ATI) or "Clone Mode" (NVidia). I additionally had to select the Secondary Display as "Full Screen Device" in NVidia's nView settings.
In this mode, the TV picture (on a TV set as second monitor) is always sent as full screen, independently from the monitor output - even when the DVBViewer is minimized. It only works if the DVBViewer uses "Overlay" or "Unchanged" for video output, not in the VMR modes (see Options/DirectX).
This feature has to be activated in the display settings, however... right-click your desktop / properties / settings / extended or such... give it a try.
Guest Lars_MQ
Not shure if your graka supports this, but there is something like theatermode on nvidias and dvdmax on matrox, where the graphiccard duplicates only the TV/Moviescreen into a fullscreen images on a second monitor...
[edit]griga was faster, and he is right theatermode was ATI :wub:[/edit]
tnx for the info
will have a look at me card when i get home
ive only just bought the thing, and i think its a raden 6500 series
warlord
hi all
thanks a lot for the help above
got theatre mode working, (after new drivers and a few resets) but i cant see the OSD on tv and teletext is grayed out, even for channels that displayed them b4
maybe this should go in another thread
tnx again
warlord
Guest Lars_MQ
that's because of overlay mode. The osd is only visible in the DVBViewer window and not on the secondary screen. Unfortunaly thats a limitation of windows itself.
