IPTV playlist
bounguine
Can anyone help me.
I have 9 different IPTV playlists (3 per 1 source with different credentials).
Many channels have the same names.
If I add them right to DVBViewer, I have 9 groups in channel editor and I have e.g. 9 instances of channel 1 to be added to favourites.
Only one channel 1 can be added to favourites, so 8 more playlists will not work, because DVBViewer cannot work with virtual (merged) channels.
So I add 9 playlists to DVBLink (with 9 sources to broadcast) and join chanels with same names.
Now I have only one instance of channel 1 from 9 sources.
I export a playlist to *.m3u and now I can use 9 clients.
If I import this playlist to DVBViewer and add a TS Stream in MS and restart it plus add 2 instances of RTSP network service , I can watch channel 1 in DVBViewer and channel 2 in Kodi.
But I cannot watch channel 1 both in DVBViewer and Kodi.
What is wrong?
With VLC I tested 9 instances of channel 1 broadcasted from DVBLink at once and everything is OK
