DVB-T/C/T2 USB tuners.
jirim100
DVBViewer.zip
Good day I have these DVB T/C/T2 tuners:
- AVerMedia TD310
- PCTV 291e/461e
- Hauppauge WinTV-soloHD
All worked in receiving DVB-T. But only Hauppauge WinTV-soloHD worked in receiving DVB-C (unencrypted). I need usb sticks AVerMedia TD310, PCTV 291e/461e to work in DVB-C reception as well.
Please help. I use last version of DVBViewer 6.1.1.0 on Win7 64b where I test it.
I can't use supporttool, because it show error "Pro mapovač koncových bodů nejsou k dispozici další koncové body/No other endpoints are available for the endpoint mapper." therefore I only compress all relevant files from folder c:\ProgramData\CMUV\DVBViewer.
Edited by jirim100
  • 3 weeks later...
Do you plan to solve this problem?
Am 30.5.2020 um 18:04 schrieb jirim100:
PCTV 291e/461e
Try the latest driver from Hauppauge (that owns PCTV):
http://www.hauppauge.de/files/drivers/hcwembda/install_driver_hcwembda_5_2019_0221_37057.exe
Additionally install an up-to-date DVBViewer version. There was an important fix for your PCTV device concerning DVB-C in version 6.1.6:
Am 12.2.2020 um 09:38 schrieb hackbart:
“Scan Devices” did not add the SRx1000 entry (read from an updated hardware database) to an already existing DVB-C tuner in the file hardware.xml.
After that, perform Scan devices on Options -> Hardware. If DVB-C still does not work with this device, please zip the file hardware.xml (see configuration folder) and attach it here.
Unfortunatelly not working. Even not working both - DVB-T and DVB-C (before worked DVB-T). I use Win7 sp1 64bits. DVBViewer 6.1.6.9 with latest fix from download area.
hardware.zip
Edited by jirim100
I revert drivers for PCTV 291e/461e back (to DriverVer = 12/06/2013, 5.2013.1206.0) and now it working (!) and video is great:
https://i.imgur.com/IaaPYyI.jpg
But now I want to solve why video for the same channel in DVB-C for Hauppauge WinTV-soloHD is very bad:
https://i.imgur.com/4myz0ZB.jpg
I use last driver version "wintv-solo_dual_quadhd_5_2020_0406_38125.exe" for it.
In DVB-T - video from both tuners is ok.
AVerMedia TD310 in DVB-C still now working.
Edited by jirim100
vor 12 Stunden schrieb jirim100:
Was it always like this?
Have a look at the DVBViewer Filter property page. I guess it will show an increasing number of discontinuities. If the reception is ok, it usually means that the driver is losing data. However, this would also affect DVB-T. in case of DVB-C another possible cause is an overdriven tuner because the signal is too strong, thus requiring an attenuator.
Yes it's always like this.  Hauppauge WinTV-soloHD  receiving data from DVB-T channels smoothly without problems, but with unencrypted DVB-C channels has problems.
Both DVB-T and DVB-C channels are in the same cable. I have now three DVB-C tuners and only Hauppauge WinTV-soloHD   has problems. Comparing reception on the same unencrypted channel (in the same cable) in DVB-C today:
CT 4650 CI:
- Signal quality 70% as show it DVBViewer.
- DVBViewer video https://i.imgur.com/6i6asmp.jpg - zero discontinuities: https://i.imgur.com/gXL22x6.png
PCTV 291e/461e:
- Signal quality 56% as show it DVBViewer .
- DVBViewer video https://i.imgur.com/BW5B4zL.jpg - zero discontinuities: https://i.imgur.com/6txhPJy.png
Hauppauge WinTV-soloHD (last driver version 5.2020.406.38125, driver date 4.5.2020 2:00:00)   :
- Signal quality 66% as show it DVBViewer .
- DVBViewer video https://i.imgur.com/wiqZ3vj.png -  many discontinuities: https://i.imgur.com/oRgI5Uy.png
DVBViewer is the last version 6.1.6.9 with the latest fix from download area.
Edited by jirim100
vor 50 Minuten schrieb jirim100:
This can't be influenced in DVBViewer. There is either something unhealthy happening on the driver level, or the signal level is not suitable for the tuner. I would ask a local TV/Radio dealer for a cable signal attenuator (that lowers the signal level) and try if it helps. Such attenuators are not expensive. They only cost a few Euros.
But why the recetion with the other two tuners is without problems? Same channel, same signal source. And reception of DVB-T channels is without problems.
May be I should be to contact Hauppauge about this problem?
Edited by jirim100
vor einer Stunde schrieb jirim100:
Because they are other tuners :)
Yes, maybe. But I've already written what I would try first.
May be for you I will be idiot but I don't see reason for signal attenuator when for all tuners is used the same source.
And why don't working DVB-C with AVerMedia TD310?  Is any chance to solve it?
vor 2 Stunden schrieb jirim100:
I don't know. I have no AverMedia device and I can't receive DVB-C, so there is nothing that I can try myself. My efforts to find out more about it can be read here, but the user reports didn't yield a clear picture of the device behaviour.
DVB-C seems to work in DVBViewer under certain circumstances, see here, but I have no idea what has to be done for it.
Hm, it's sad.
Probably the best tuner (in stisk format) is PCTV 291e/461e  - no problems with DVB-T and DVB-C (under DVBViewer), but is relative expensive.
