SatWaveDude Posted July 5, 2020 Posted July 5, 2020 (edited) Hi, Are there Windows 7 64-bit BDA drivers for the Hauppauge WinTV-CI-USB2 11000LF ? After installing the current Hauppauge available drivers version 1.3607.26283 the CI still don't recognised in the DVBViewer hardware menu. Dateiname: WinTV-CI_1_3607_26283_WHQL.zip What do I have to do to makes this work ? Edited July 5, 2020 by SatWaveDude Quote
Griga Posted July 6, 2020 Posted July 6, 2020 This has been implemented several years ago by someone else, and I have no experience with it. I can only tell you what DVBViewer does to find the device. It lets Windows enumerate all devices in the AM_KSCATEGORY_CAPTURE category and then picks those with one of the following two sub-strings in their hardware path: {10887089-3447-4be3-85f6-75ca7451c02e} {9b365890-165f-11d0-a195-0020afd156e4} The first one seems to be the device ID of "Hauppauge WinTV-CI BDA (11xxx)" (see here). Can you find it in the INF file contained in the WinTV-CI_1_3607_26283_WHQL.zip? 1 Quote
SatWaveDude Posted July 6, 2020 Author Posted July 6, 2020 SUCCESS !!!! After removing the driver with the tool hcwclear.exe and a computer re-start I installed the driver again with HcwDriverInstall.exe and now the CI shows up in External CI (experimental). Quote
