jirim100 Posted July 14, 2020 Posted July 14, 2020 Sometimes is the error "TemplatePower Error: Can't find the block definition of "withrights"" in the svcdebug.log: 12.07.20 11:00:01.619 TWinApp Working Directory C:\Users\JiriM\Documents\Visual Studio 2008\Projects\MyPDC_2017\x64\Release\ 12.07.20 11:00:01.621 TProcessTimer StartRecord VPS_PDC started 12.07.20 11:00:02.633 TProcessTimer NeedsEnding VPS_PDC finished 12.07.20 11:00:29.173 TTemplatePower TemplatePower Error: Can't find the block definition of "withrights" 12.07.20 11:30:00.452 TRecording ($01E80B70) W:\For The Record\Ty naše písničky; ; ; ; vysíláno 2020-07-12.ts Discontinuities: 0 - Total size: 1,93 GB - Device: PCTV 291e/461e BDA 28179 TVTuner (9) Should I worry about that? Quote
Griga Posted July 15, 2020 Posted July 15, 2020 Am 14.7.2020 um 20:08 schrieb jirim100: Should I worry about that? No. It just means that the DMS tries to modify something in a HTML template (from the SVCweb folder) that doesn't exist. Such a block definition looks like this <!-- START BLOCK : withrights --> .... <!-- END BLOCK : withrights --> In your case it may be due to a changed HTML file where the expected block is missing. If it would really matter, you would experience visual or functional disorder in the web interface. Quote
jirim100 Posted July 16, 2020 Author Posted July 16, 2020 Aha, Ok. This is probably because I am using epg_searchresults.html from old recording service ?. Quote
