lordjim1985 Posted October 18, 2020 Posted October 18, 2020 Hi, first thanks for this great software. I wanted to ask a question, maybe anyone will be able to help. First time I launch DVBViewer Pro 6.1.7.2 after upgrading from 6.1.7.1 everything works including the OSD (which stopped working for some reason). Next when enter MHEG5/HbbTV application and restart DVBViewer Pro 6.1.7.2 the OSD never appears again. I've tried restarting couple of times but it does not help. I've also tried installing again DVBViewer Pro 6.1.7.2 but this also does not help. Can anyone provide any clues to what might be wrong? I'm using Windows 10 2004 x64 Pro. Quote
lordjim1985 Posted October 18, 2020 Author Posted October 18, 2020 I've narrowed it down. The problem appears to be related to running software on a laptop with two graphics cards enabled. If I use the integrated AMD Vega GPU the OSD works well. If I use NVDIA GPU then the problem appears. Quote
