Leonte Posted November 17, 2020 Posted November 17, 2020 (edited) Hi, Every time I start DVBViewer I must enable the subtitles in my choose language. Always start with 'none', below I have option for my native language to be selected despite setting it in 'settings''. Why it not save last option ? Edited November 17, 2020 by Leonte Quote
Griga Posted November 17, 2020 Posted November 17, 2020 DVBViewer Pro saves the last selected subtitles for TV channels in the file TVDatabase.db3. It is located in the Database sub-directory of the configuration folder (see DVBViewer help menu). Maybe the file is corrupted, so that subtitle settings can't be stored anymore. Remove the file while DVBViewer is closed. After a restart DVBViewer will recreate it automatically. Quote
Leonte Posted November 17, 2020 Author Posted November 17, 2020 45 minutes ago, Griga said: DVBViewer Pro saves the last selected subtitles for TV channels in the file TVDatabase.db3. It is located in the Database sub-directory of the configuration folder (see DVBViewer help menu). Maybe the file is corrupted, so that subtitle settings can't be stored anymore. Remove the file while DVBViewer is closed. After a restart DVBViewer will recreate it automatically. Yes, it worked. Thanks a lot. Quote
