DVBViewer cannot connect to recordings after update (3.0.0.0 & 7.0.0.0)
HD.
Hi, anybody have idea for this. I have updated to DMS 3.0.0.0 and after that everything else works but DVBViewer (7.0.0.0) cannot connect to recordings. (no recording list, not able to do new timers) Both were updated the same time.
The recordings-list is empty and if I try to do a new timer it says "Media Server Error Missing or wrong username and password".
Web interface works and playback from there too.
In DVBViewer settings the connection to DMS tests ok so password etc is correct.
And they did work earlier before update.
Confirmed. Seems to be the result of a stupid bug. Already spotted.
I will upload a fix to the members area -> beta section ASAP and notify you here. Stay tuned...
Perfect, thanks for the information.
The fix is up. Please download DVBViewer_Fix_7_0_0_2.zip form the members area -> beta section and read the included ReadMe!
  • Like 1
That works again. Thanks.
