miha2154 Posted December 30, 2020 Posted December 30, 2020 (edited) 1) the ability to create a timer task in manual mode (if there is no EPG for this channel, then the task cannot be created); 2)the ability to manually select a specific tuner for a specific task (with different sensitivity of tuners, the same channel on the same tuner may contain errors in the stream); 3)add more information about the DVB stream: signal status indicators L, SNR, Q, DVB demultiplexer statistical information. For example: 4)ability to add an external TV program from different sources: Edited December 30, 2020 by miha2154 Quote
Griga Posted December 30, 2020 Posted December 30, 2020 vor 4 Stunden schrieb miha2154: 1) the ability to create a timer task in manual mode DVBViewer: TV/Radio -> Timer Recordings -> Enter data for a new timer -> Click Add. DVBViewer Media Server: Web Interface -> Timer Page -> New Timer -> Enter data for a new timer -> Click Save. vor 4 Stunden schrieb miha2154: 2)the ability to manually select a specific tuner for a specific task Can be achieved by using channel groups: TV/Radio -> Channel Editor -> Assign a Group A...H to the channel(s) in question. You may also assign a group to a whole category or to all channels in a root folder. Settings -> Options -> Hardware -> Select a tuner -> Select the channel groups that this tuner shall handle (or not handle) by (un)ticking the corresponding checkboxes. vor 4 Stunden schrieb miha2154: 3)add more information about the DVB stream Some information in your screenshot can be found in the DVBViewer Channel Editor. However, signal status indicators L, SNR, Q, DVB demultiplexer statistical information and stuff are not exposed by the BDA interface, but must be retrieved in a device specific way, requiring special interfaces provided by the DVB device manufacturer. This is a lot of work, first getting the information from the manufacturer, then implementing it for each device type separately... since we are short of resources (and also a bit lazy ), I don't think that it will be implemented in near future. Quote
miha2154 Posted December 31, 2020 Author Posted December 31, 2020 19 hours ago, Griga said: DVBViewer: TV/Radio -> Timer Recordings -> Enter data for a new timer -> Click Add. This is copying an existing job for a specific channel. You can change the date and time. The channel itself cannot be changed to another one. Quote
HaraldL Posted December 31, 2020 Posted December 31, 2020 Did you try to click on a channel in the channel list on the left? Quote
miha2154 Posted December 31, 2020 Author Posted December 31, 2020 10 minutes ago, HaraldL said: Did you try to click on a channel in the channel list on the left? Oh! I had a closed channel list in the scheduler. Yes, it happened! An existing task is copied, but with the desired channel - the name and time can be edited. Quote
miha2154 Posted January 3, 2021 Author Posted January 3, 2021 is it possible to add an external TV program (jtv, xmltv) from different sources? Quote
