HenPen 0 Posted January 3 Share Posted January 3 After the upgrade to Media Server 3.0.0 and DVBViewer 7.0, and the recent hot fixes, the Hauppauge WinTV ATSC tuner isn't recognized by a hardware scan. Saw the following in the thread on Homerun tuner. Made these changes (TunerType = 3) and everything works as well as before. DVBViewer fix Win10 path: %ProgramData%\CMUV\DVBViewer DVBViewer File: hardware.xml Media Server fix Win10 path: %ProgramData%\CMUV\DVBViewer\config DVBViewer File: svchardware.xml Update: <entry name="TunerType">0</entry> Set value while DVBViewer is closed (0 = Cable, 1 = Satellite, 2 = Terrestrial, 3 = ATSC). Repeat for all tuners in this file (I have 4) Quote Link to post
Griga 712 Posted January 5 Share Posted January 5 Please attach your zipped svchardware.xml here (see config subdirectory of the configuration folder), so we can see the hardware ID of your device. It may enable us to take measures that avoid this issue in future. Quote Link to post
HenPen 0 Posted January 6 Author Share Posted January 6 svchardware.zip Thanks for taking a look. Quote Link to post
Griga 712 Posted January 6 Share Posted January 6 Thanks. The hardware database that is included in DVBViewer Pro and the Media Server will in future enable to flag devices (like yours) with "needs tuner type selection", thus allowing to select the tuner type in Options -> Hardware. It will be available in the next DVBViewer/DMS Fix uploads and in the next release anyway. However, after an update of an already existing installation, it will require to perform Options -> Hardware -> Scan Devices again in order to take effect. Quote Link to post
HenPen 0 Posted February 13 Author Share Posted February 13 Thanks guys...3.0.2 and 7.0.2 fixed this! Quote Link to post
