RK3040 - SAT>IP server -> DVBViewer pro scan failed
Pagin
Hello,
Config :
* RK3040 SAT> ip server
* LNB no diseqc , direct ASTRA 19.2
SAT> IP line 1 -> scan , i can see frequency during scan but no channel found.
If i connect direct line to DVB-S² card inside PC , i can scan correctly.
Is any tweaking to get SAT>IP server box working ?
Regards
03.02.21 15:39:15.900 TRTSPNetworkStream   OPTIONS          10060
03.02.21 15:39:15.900 TRTSPNetworkStream   OpenDevice       Server not found: rtsp://192.168.1.15:8000/
03.02.21 15:39:15.901 TfrmScanner          AllocateHardware Open failed
03.02.21 15:41:19.175 OSD Loadsettings     Completed
03.02.21 15:41:39.122 TfrmScanner          AllocateHardware SAT2IP 2
03.02.21 15:41:39.166 TRTSPNetworkStream   SetTuner         TType: 1, Freq: 10788, Symrate: 22000, LOF: 9750, Tone: 0, Pol: 1, DiseqC: 0, FEC: 4, APID: 0, VPID: 0, PMT: 0, SID: 0, TID: 0, NID: 0, SatMod: 1, DiseqCVal: 0, Flags: 0, Group: 0
03.02.21 15:41:44.936 TfrmScanner          Release          SAT2IP 2
03.02.21 15:41:44.936 TfrmScanner          Free             SAT2IP 2
03.02.21 15:41:45.255 TfrmScanner          Freed            SAT2IP 2
03.02.21 15:41:45.255 TfrmScanner          hamDeleted       SAT2IP 2
03.02.21 15:50:26.815 USceneRender         issuing WM_DEVICELOST
03.02.21 15:50:29.112 TfrmMain             End App          before OSD terminate
03.02.21 15:50:29.130 End App              -----------------------------------
03.02.21 15:52:41.961 Start App            ----------------------------------------
03.02.21 15:52:41.961 Start App            DVBViewer.exe
03.02.21 15:52:41.961 Start App            7.0.1.4
03.02.21 15:52:42.004 TfrmLoader           Status           Creating Windows...
03.02.21 15:52:42.089 TfrmLoader           Status           Searching Directshow Components...
03.02.21 15:52:42.162 TfrmLoader           Status           Loading Setup File...
03.02.21 15:52:42.880 TDVBDeviceList       LoadSettings     DVB-S2 RTSP Network Device, status 0
03.02.21 15:52:42.881 TDVBDeviceList       LoadSettings     TBS 5922 USB DVB-S2 Tuner (2), status 0
03.02.21 15:52:42.881 TDVBDeviceList       LoadSettings     SAT2IP 2, status 1
03.02.21 15:52:42.881 TDVBDeviceList       LoadSettings     REALTEK DTV Filter (1), status 0
03.02.21 15:52:42.882 TDVBDeviceList       CheckDevicesPresent TBS 5922 USB DVB-S2 Tuner (2) not available
03.02.21 15:52:42.882 TDVBDeviceList       CheckDevicesPresent REALTEK DTV Filter (1) not available
03.02.21 15:52:43.282 TfrmLoader           Status           Searching Plugins...
03.02.21 15:52:43.282 Param                running vanilla
03.02.21 15:52:43.288 OSDResourceManager   Init complete
03.02.21 15:52:43.291 OSDPropertymanager   Init Complete
03.02.21 15:52:43.293 OSD Startup          Create Complete
03.02.21 15:52:43.294 TfrmLoader           Status           Completing Options...
03.02.21 15:52:43.391 TfrmLoader           Status           Initializing Plugins...
03.02.21 15:52:43.396 TfrmLoader           Status           Waiting for the Media Server...
03.02.21 15:52:43.400 TfrmLoader           Status           Loading Channel List...
03.02.21 15:52:43.416 TfrmLoader           Status           Loading EPG...
03.02.21 15:52:43.465 TfrmLoader           Status           Loading Service EPG...
03.02.21 15:52:43.466 TfrmLoader           Status           Loading  Favourites...
03.02.21 15:52:43.530 TEPGDownloadThread   Execute          200
03.02.21 15:52:43.765 TfrmLoader           Status           Initializing OSD Skin...
03.02.21 15:52:43.813 OSD Restore          Completed
03.02.21 15:52:43.813 OSDLocalize          Load default language C:\Program Files (x86)\DVBViewer\language\english.lng
03.02.21 15:52:43.816 OSDLocalize          Load language C:\Program Files (x86)\DVBViewer\Language\French.lng
03.02.21 15:52:43.817 OSD Loadsettings     Completed
03.02.21 15:52:43.823 LoadWindowDefs       Loading WindowDefFile: C:\ProgramData\CMUV\DVBViewer\windowdef.xml
03.02.21 15:52:43.826 LoadReference        Setting Skinsize to 1280 x 720
03.02.21 15:52:43.826 LoadSkin             Loading Skinfile: C:\Program Files (x86)\DVBViewer\OSDSkins\default\myHome.xml
03.02.21 15:52:43.828 No Translation!      Mosaic Preview
03.02.21 15:52:43.829 LoadSkin             Loading Skinfile: C:\Program Files (x86)\DVBViewer\OSDSkins\default\myClock.xml
03.02.21 15:52:43.830 LoadSkin             Loading Skinfile: C:\Program Files (x86)\DVBViewer\OSDSkins\default\tvWindow.xml
03.02.21 15:52:43.831 LoadSkin             Loading Skinfile: C:\Program Files (x86)\DVBViewer\OSDSkins\default\videoinfo.xml
03.02.21 15:52:43.832 LoadSkin             Loading Skinfile: C:\Program Files (x86)\DVBViewer\OSDSkins\default\myVolume.xml
03.02.21 15:52:43.837 TOSD                 WindowsInit      Complete
03.02.21 15:52:43.837 OSD Startup          Init Complete
03.02.21 15:52:43.981 TfrmLoader           Status           Completing Initialization...
03.02.21 15:52:44.014 TfrmMain             SetTuner         Start
03.02.21 15:52:44.018 TfrmMain             AllocateHardware SAT2IP 2
03.02.21 15:52:44.018 TfrmMain             SetTuner         Found usable hardware
03.02.21 15:52:44.018 TRTSPNetworkStream   SetTuner         TType: 1, Freq: 12207, Symrate: 29700, LOF: 10600, Tone: 1, Pol: 1, DiseqC: 3, FEC: 2, APID: 921, VPID: 910, PMT: 900, SID: 9009, TID: 1090, NID: 1, SatMod: 142, DiseqCVal: 0, Flags: 24, Group: 0
03.02.21 15:52:44.140 TfrmMain             SetTuner         End
03.02.21 15:53:40.946 TfrmMain             Release          SAT2IP 2
03.02.21 15:53:40.946 TfrmMain             Free             SAT2IP 2
03.02.21 15:53:41.246 TfrmMain             Freed            SAT2IP 2
03.02.21 15:53:41.246 TfrmMain             hamDeleted       SAT2IP 2
03.02.21 15:53:41.260 TfrmScanner          AllocateHardware SAT2IP 2
03.02.21 15:53:41.305 TRTSPNetworkStream   SetTuner         TType: 1, Freq: 10891, Symrate: 22000, LOF: 9750, Tone: 0, Pol: 0, DiseqC: 0, FEC: 2, APID: 0, VPID: 0, PMT: 0, SID: 0, TID: 0, NID: 0, SatMod: 134, DiseqCVal: 0, Flags: 0, Group: 0
03.02.21 15:53:46.966 TfrmScanner          Release          SAT2IP 2
03.02.21 15:53:46.966 TfrmScanner          Free             SAT2IP 2
03.02.21 15:53:47.277 TfrmScanner          Freed            SAT2IP 2
03.02.21 15:53:47.277 TfrmScanner          hamDeleted       SAT2IP 2
03.02.21 15:55:04.442 TfrmMain             End App          before OSD terminate
03.02.21 15:55:04.463 End App              -----------------------------------
