Retrofan Posted May 13, 2021 Posted May 13, 2021 Hi, Is there also a debug mode for TransEdit? When I want to analyze some muxes from Tvheadend server some of them are failing with "Tuning Error" while others do open without problems. I tried the amount of pids and it's not limited to 32. I tried 40. How can this be fixed? Quote
Griga Posted May 13, 2021 Posted May 13, 2021 vor 16 Minuten schrieb Retrofan: Is there also a debug mode for TransEdit? Limited to HTTP connections: https://www.dvbviewer.tv/forum/topic/2745-transedit/?do=findComment&comment=489129 Quote
Retrofan Posted May 16, 2021 Author Posted May 16, 2021 On 5/13/2021 at 5:36 PM, Griga said: Limited to HTTP connections: https://www.DVBViewer.tv/forum/topic/2745-transedit/?do=findComment&comment=489129 Hi, thanks. Here's the support file. Hope you know why it's going wrong with some muxes. I'm using the Fritz!WLAN Repeater DVB-C device with Tvheadend. support.zip Quote
Griga Posted May 16, 2021 Posted May 16, 2021 Zitat 11:03:46.449 GetHeader Error: 10054 https://docs.microsoft.com/en-us/windows/win32/winsock/windows-sockets-error-codes-2 Zitat WSAECONNRESET 10054 Connection reset by peer. An existing connection was forcibly closed by the remote host. This normally results if.... Quote
Retrofan Posted May 16, 2021 Author Posted May 16, 2021 9 hours ago, Griga said: https://docs.microsoft.com/en-us/windows/win32/winsock/windows-sockets-error-codes-2 Okay, thanks, but what's next we can do? Quote
Griga Posted May 17, 2021 Posted May 17, 2021 I don't know why Tvheadend breaks the connection. It happens outside TransEdit. I can do nothing about it. Search the web for the error and try to find out more about it Something that is also wrong (but not related to the broken connection): If Tvheadend delivers a TS, the media type reported by the server should be video/MP2T (see here), not application/octet-stream, in order to save clients unnecessary guessing. Quote
Retrofan Posted May 22, 2021 Author Posted May 22, 2021 Hi, just tried an USB stick with DVB-T2 and DVB-C tuner and no problems anymore. So, probably it has something to do with limited PID filtering or compatibility issue. Anyway, it's solved this way. Thread can be closed. Quote
SasaSAT Posted February 1, 2025 Posted February 1, 2025 (edited) Trans edit when press go to preset 0 position dont wont to go. Only goes when press go to angular position when scaning then it moves its.Is it that becouse driver support its not updated DVBSky S950c? Have some isues in DVBViewer with aac chanels loading and not starts audio sometime,but after reload works Remembering old days all was fine with DVBViewer and i support that.tnx Just in case Il atach file ,let me know iff all loks good,or need anything else support.zip Edited February 1, 2025 by SasaSAT Quote
Griga Posted February 2, 2025 Posted February 2, 2025 vor 7 Stunden schrieb SasaSAT: Trans edit when press go to preset 0 position dont wont to go. Where? In the Positioner Console? Position 0 has a special meaning, as you can read here: Zitat 0 is reserved as reference position and cannot be used to store a user defined position. Maybe the motor does not support it. Do other preset positions (1, 2, 3...) work? vor 7 Stunden schrieb SasaSAT: Have some isues in DVBViewer with aac chanels loading and not starts audio sometime,but after reload works Which channels on which satellite position / frequency? Before attaching a support.zip, the issue (or at least tuning one of these channels) should be reproduced in DVBViewer debug mode, as suggested here. Quote
SasaSAT Posted February 2, 2025 Posted February 2, 2025 Today somehow work fine it was example on 13e 11278 27500 V loading while press. 12713 30000 V.Cant realy shure,cant remember where aac audio got not sound but after reload worked. How goes with transedit you press go to reference 0 (preset) / then press calculate positions / and then go to selected satelite? One more question in transedit i forgot how many steps its for 1degres (its cc 13steps 1degree EAST/WEST) and what maximum steps can input in one command. Quote
