Mr.Scienceman2000 Posted September 11, 2021 Posted September 11, 2021 I have been running DVBViewer Pro on my Mediacentre pc for around year now and been working great. Few months ago however I found DVBViewer GE from members area and wanted give it a change on my older pc running socket 478 Pentium 4 and Windows XP. IT worked great and had no issue playing channels or viewing teletext. However I have few issues remote is not detected and bigger issue EPG information shows in Swedish. In Finland cable tv operator Elisa sends EPG information on two languages Swedish and Finnish DVBViewer asks English EPG information by default but since cable TV does not supply one, it defaults to Swedish. On DVBViewer PRO I was able fix this issue by changing preferred EPG language in the settings, but DVBViewer GE seems lack this feature. As for remote I am using Hauppauge offical remote with Hauppauge WinTV soloHD usb tuner and 5.2015.1030.34035 driver for 32bit Windows XP SP3. I downloaded HCWRemote plugin from members section and copied Irremote.dll to root directory of DVBViewer GE and activated plugin, but input>remote tab does not allow me to enter keys for remote. I did not find way to create support.zip using DVBViewer GE, but if there is way and you need it just tell me how and I will. Hopefully someone can assist with this problem Quote
Griga Posted September 11, 2021 Posted September 11, 2021 vor 4 Stunden schrieb Mr.Scienceman2000: On DVBViewer PRO I was able fix this issue by changing preferred EPG language in the settings, but DVBViewer GE seems lack this feature. That's true. The expected behaviour is that DVBViewer GE shows the EPG items in all languages. either seprated by slashes for the title / subheading or by line feeds for the long description. However, I have never tested it with a multilingual EPG. Quote
Mr.Scienceman2000 Posted September 11, 2021 Author Posted September 11, 2021 2 hours ago, Griga said: That's true. The expected behaviour is that DVBViewer GE shows the EPG items in all languages. either seprated by slashes for the title / subheading or by line feeds for the long description. However, I have never tested it with a multilingual EPG. is there way change priority of them or toggle of some languages? Quote
Griga Posted September 12, 2021 Posted September 12, 2021 vor 16 Stunden schrieb Mr.Scienceman2000: is there way change priority of them or toggle of some languages? No, there isn't. Quote
Mr.Scienceman2000 Posted September 15, 2021 Author Posted September 15, 2021 On 9/12/2021 at 10:11 AM, Griga said: No, there isn't. Well shame. Anyway I tried normal DVBViewer on it and seems it was not as heavy as I though would be. Tv broadcasts run fine on 2.80ghz 478 socket Pentium 4 and even multimedia runs works very well that opposite that I expected. Also it wont overload cpu even on recording so program seems well optimised ?. Remote started working after I downloaded runtimes using DVBViewer downloader utility Quote
