AndreaB Posted October 6, 2021 Posted October 6, 2021 Hi. I start a new topic to differentiate it from the server (next step). Attached is the file with the translation of DVBViewer 7.1.2.1 in Italian. Since I have been updating the translation for a few years now, it would be nice if my name is in the Credits ... ? Ciao, Andrea DVBViewer-7_1_2_1-IT.zip Quote
Griga Posted October 6, 2021 Posted October 6, 2021 3 hours ago, AndreaB said: Attached is the file with the translation of DVBViewer 7.1.2.1 in Italian. Thanks for your contribution 3 hours ago, AndreaB said: it would be nice if my name is in the Credits Done. Quote
AndreaB Posted October 7, 2021 Author Posted October 7, 2021 23 hours ago, Griga said: Thanks for your contribution In order for a new version to come out with the updated translation, is it not possible to access the beta versions? Ciao, Andrea Quote
AndreaB Posted October 17, 2021 Author Posted October 17, 2021 Quote In order for a new version to come out with the updated translation, is it not possible to access the beta versions? Whenever we write about improving the DVBViewer translation process (improvements LngEditor.exe, access to the beta program, etc.)... we get no response. ? From what I see, the translation of DVBViewer into other languages is certainly not at the top of your priorities. ? Ciao, Andrea Quote
Griga Posted October 17, 2021 Posted October 17, 2021 Currently there is no beta available, not even internally, because lengthy development concerning the support for new subtitle formats (WebVTT, TTML) is in progress. Quote
AndreaB Posted October 23, 2021 Author Posted October 23, 2021 Thanks for the answer, but that's not what I wanted to get to. I was asking if it is possible to activate a process to facilitate translations. Updating DVBViewer translations is always a big job and if "LngEditor.exe" was once enough now it doesn't help much. Ok, I'll update the Italian translation when I have a lot of free time... too bad because DVBViewer is a really nice program. Ciao, Andrea Quote
AndreaB Posted February 8, 2022 Author Posted February 8, 2022 Hi. Attached is the updated Italian translation of DVBViewer. Few changes, fortunately ? Ciao, Andrea DVBViewer-7_2_0_0-IT.zip Quote
Griga Posted February 8, 2022 Posted February 8, 2022 Thanks. It will be included in the upcoming 7.2.1 bugfix release. Quote
AndreaB Posted February 11, 2022 Author Posted February 11, 2022 Hi. Attached is the updated Italian translation of DVBViewer. Ciao, Andrea DVBViewer-7_2_1_0-IT.zip Quote
AndreaB Posted June 9, 2022 Author Posted June 9, 2022 Hi. Attached is the updated Italian translation of DVBViewer. Ciao, Andrea DVBViewer-7_2_2_1-IT.zip Quote
AndreaB Posted June 9, 2022 Author Posted June 9, 2022 PS: (I can't edit previous message) Why is there a commented line like ";A C D N M O S U " at the beginning of some sections? Quote
Griga Posted June 9, 2022 Posted June 9, 2022 vor 1 Stunde schrieb AndreaB: Why is there a commented line like ";A C D N M O S U " at the beginning of some sections? The comment enumerates the already used "accelerator keys" that appear underlined in the UI. For example, the key "A" (in combination with the Alt key) is assigned to the Add button in the [frmActionEditor] section. The & character in "btnAdd.Caption=&Add" indicates which key shall trigger the Add function. The comment helps to avoid using the same letter accidentaly two times for different things. Though most people are using the mouse, particularly blind people need a key for every function. Quote
AndreaB Posted March 7, 2023 Author Posted March 7, 2023 (edited) Hi. Attached is the updated Italian translation of DVBViewer. Ciao, Andrea PS: I turned on notifications for this topic, but I haven't received any emails, sorry for the delay:https://www.DVBViewer.tv/forum/topic/64626-DVBViewer-700/ DVBViewer-7_2_3_0-IT.zip Edited March 7, 2023 by AndreaB Quote
Griga Posted March 8, 2023 Posted March 8, 2023 Thanks. I've integrated it in the DVBViewer setup for the next release. Quote
AndreaB Posted December 1, 2023 Author Posted December 1, 2023 Hi. Attached is the updated Italian translation of DVBViewer. Ciao, Andrea DVBViewer-7_2_4_0-IT.zip Quote
Griga Posted December 5, 2023 Posted December 5, 2023 Thanks again. Downloaded and integrated (also the Media Server file). Quote
MarGal Posted December 14, 2023 Posted December 14, 2023 On 12/1/2023 at 1:16 PM, AndreaB said: Hi. Attached is the updated Italian translation of DVBViewer. Ciao, Andrea DVBViewer-7_2_4_0-IT.zip 34.25 kB · 3 downloads Hi, sorry but the translation has been wrong for years, since the first version 7. Is it possible that no Italian has noticed? I remade it for myself, but if you want I'll post it with my name. Quote
AndreaB Posted December 14, 2023 Author Posted December 14, 2023 1 hour ago, MarGal said: Hi, sorry but the translation has been wrong for years, since the first version 7. Is it possible that no Italian has noticed? I remade it for myself, but if you want I'll post it with my name. I use DVBViewer frequently and have never encountered errors in the translation (what I did is try to eliminate useless Englishisms). I only use it for the terrestrial and common parts, not the satellite part (even though I know the RF section quite well). So if you have any suggestions you can make them here. Ciao, Andrea Quote
MarGal Posted December 15, 2023 Posted December 15, 2023 (edited) On 12/14/2023 at 10:21 AM, AndreaB said: Uso spesso DVBViewer e non ho mai riscontrato errori nella traduzione (quello che ho fatto è cercare di eliminare inutili inglesismi). Lo uso solo per la parte terrestre e comune, non per la parte satellitare (anche se conosco abbastanza bene la sezione RF). Quindi, se hai suggerimenti, puoi farli qui. Ciao, Alessio Ciao, prima di tutto ho cercato di accorciare le traduzioni perché molte frasi erano più lunghe dello spazio disponibile per la lettura e non si capiva nulla del significato, e poi la cosa più importante che è stata cambiata per molto tempo è la traduzione dei suggerimenti bollon quando ci si posiziona sui pulsanti "canale preferito precedente" e "canale preferito successivo", dove invece compaiono le parole "rimuovi dai preferiti" e "aggiungi ai preferiti". Visto l'enorme lavoro svolto, vorrei anche che il mio nome comparisse nell'elenco finale. Grazie. Allego il file modificato. Google translation to English: Hi, first of all I tried to shorten the translations because many sentences were longer than the space available for reading and nothing was understood about the meaning, and then the most important thing that has been changed for a long time is the translation of the tooltip (?) suggestions when you position yourself on the "previous favorite channel" and "next favorite channel" buttons, where the words "remove from favorites" and "add to favorites" appear instead. Given the enormous work done, I would also like my name to appear in the final list. Thank you. I attach the modified file. Italiano.lng Edited December 15, 2023 by Griga Google translation added Quote
Griga Posted December 15, 2023 Posted December 15, 2023 @MarGal Thanks for your suggestions. Please add an English translation if you are posting in Italian, so everybody can understand what it is about. Usually we don't allow posts in languages that we don't understand, because it could be spam that is hidden in this way. However, if you want to communicate with someone in your native language, you may use personal forum messages. 5 hours ago, MarGal said: first of all I tried to shorten the translations because many sentences were longer than the space available for reading This may be due to different text size (DPI) settings in Windows. If the text size is more than 100%, DVBViewer adjusts to it automatically, but some text may become too long nonetheless. A language file can be tested with a different text size by using the Resizer.exe tool in the DVBViewer program directory. It only takes effect on DVBViewer, not on whole Windows. Ciò potrebbe essere dovuto a impostazioni diverse della dimensione del testo (DPI) in Windows. Se la dimensione del testo è superiore al 100%, DVBViewer si adatta automaticamente ad essa, ma parte del testo potrebbe comunque diventare troppo lunga. È possibile testare un file di lingua con una dimensione di testo diversa utilizzando lo strumento Resizer.exe nella directory del programma DVBViewer. Ha effetto solo su DVBViewer, non su tutto Windows. Quote
MarGal Posted December 15, 2023 Posted December 15, 2023 1 hour ago, Griga said: @MarGal Thanks for your suggestions. Please add an English translation if you are posting in Italian, so everybody can understand what it is about. Usually we don't allow posts in languages that we don't understand, because it could be spam that is hidden in this way. However, if you want to communicate with someone in your native language, you may use personal forum messages. This may be due to different text size (DPI) settings in Windows. If the text size is more than 100%, DVBViewer adjusts to it automatically, but some text may become too long nonetheless. A language file can be tested with a different text size by using the Resizer.exe tool in the DVBViewer program directory. It only takes effect on DVBViewer, not on whole Windows. Ciò potrebbe essere dovuto a impostazioni diverse della dimensione del testo (DPI) in Windows. Se la dimensione del testo è superiore al 100%, DVBViewer si adatta automaticamente ad essa, ma parte del testo potrebbe comunque diventare troppo lunga. È possibile testare un file di lingua con una dimensione di testo diversa utilizzando lo strumento Resizer.exe nella directory del programma DVBViewer. Ha effetto solo su DVBViewer, non su tutto Windows. Hi, regarding my post in Italian, I don't understand what happened because it was all in English...Then I had to make a change in the text and it became all in Italian. I thought it was due to google's automatic translator, but that wasn't the case. I apologize for what happened. Good evening Mario Quote
AndreaB Posted February 22, 2024 Author Posted February 22, 2024 Hi. Attached is the updated Italian translation of DVBViewer. Ciao, Andrea DVBViewer-7_2_5_0-IT.zip Quote
AndreaB Posted June 16, 2024 Author Posted June 16, 2024 Hi. Attached is the updated Italian translation of DVBViewer 7.3.0.0. Ciao, Andrea DVBViewer-7_3_0_0-IT.zip Quote
AndreaB Posted January 3 Author Posted January 3 Hi. Attached is the updated Italian translation of DVBViewer 7.3.1.0. Ciao, Andrea DVBViewer-7_3_1_0-IT.zip Quote
Griga Posted January 3 Posted January 3 Thanks. Integrated for the next release (also your Media Server update). Every Italian user who updated to DVBViewer 7.3.1 / Media Server 3.3.1 should use the new translations and store them in the Language sub-directory of the DVBViewer program directory (usually C:\Program Files (x86)\DVBViewer\Language). Quote
AndreaB Posted October 6 Author Posted October 6 Hi. Attached is the updated Italian translation of DVBViewer 7.3.1.9. Ciao, Andrea DVBViewer-7_3_1_9-IT.zip 1 Quote
