DVBViewer 7.0.0
hackbart
Change Log DVBViewer Pro 7.0.0
Overview
Please note: DVBViewer Pro 7.x contains major changes. If DVBViewer is associated with a DVBViewer Media Server (full or basic version), it should be updated to version 3.x, because there may be compatibility issues with older Media Server 2.x versions. “Associated” means in this context, that Options → DVBViewer Media Server → Enable support for the DVBViewer Media Server is switched on and the Media Server in question is selected on this page.
A brief overview of the main changes:
  • Streaming: MPEG Dash is supported as new streaming format. The support for HLS has been enhanced, particularly the playback of files that are provided as HLS stream.
  • Channel List: All kinds of media streams and files can now be included in the channel and favorites list, thus giving it playlist functionality.
  • Recording has generally been reworked and harmonized with the DVBViewer Media Server, plus several functional and UI enhancements. More settings can now be set up individually per timer in the Timer Recordings window. The recorder engine enables the download of files from streaming sources (e.g. HbbTV) and storing them as recording, by just clicking the Record button.
  • Timeshift has been redesigned completely. Timeshift recordings are now performed by the recorder engine, not by the playback engine anymore, which involves several enhancements. If you decide to keep a timeshift file, it gets fully integrated as recording. Ongoing recordings are automatically used for timeshift. Multi-timeshift enables switching between two or more channels with timeshifted playback.
  • Media Server Support: Particularly the cooperation with a DVBViewer Media Server as background recording engine has been elaborated further and harmonized in several respects.
  • Keyboard / Remote Control: The Options → Input page has been reworked, particularly for making it more convenient and self-explanatory. It provides extended facilities for organizing the assignment of keys to DVBViewer functions.
  • Option pages have partly been moved to another tree view position, renamed, redesigned or merged, in order to achieve a more reasonable and understandable structure.
Please click the links above for more details!
Streaming
  • Added: TS Stream: Support for the streaming format MPEG Dash. Usually the URLs have the filename extension .mpd and refer to an XML manifest. The general handling is similar to HLS. MPD URLs for Dash streams can be used in Playback → Open URL, in the playlist and channel list. Additionally they may be selectable on HbbTV pages (requires HbbTV add-on). Please note the following limitations:
    • Supported codecs are H.264 and HEVC video and AAC, AC3 and EAC3 audio.
    • The only supported container format is the mostly used segmented MP4 base media format (which is internally transcoded to TS). Some rarely used MPEG Dash options are not supported.
    • The current implementation does not support playing encrypted / DRM-protected streams.
  • Added: TS Stream: Support for HLS (HTTP Live Streaming) with
    • AC3 and EAC3 audio (previously only MP3 and AAC).
    • segments in MP4 base media format (previously only segmented transport and audio elementary streams). DVBViewer internally converts it to a transport stream.
    • master playlists that offer streams with different video/audio formats (e.g. H.264 and HEVC). The desired format can be selected by appending ?codec=… to the URL (or &codec=… if there is already a query part). The codec selection is not sent to the server, but processed and removed by DVBViewer. The specified codec must be a sub-string of (or equal) the CODECS attribute in the master playlist, e.g. codec=avc1
  • Added: File Playback: Files provided by the server as HLS or MPEG Dash stream can now be played as files by using the DVBViewer Filter, including support for jumping to another position. All HLS/Dash URLs originating from Playback → Open URL or the Playlist are handled in this way. If they are actually live streams, jumping is disabled. HLS/Dash URLs from the channel list are only played as file, if “Play as file” is checked in the Channel Editor.
  • Added: Playback Components Options (former DirectX options): Two additional checkboxes on the DVBViewer Filter tab: Use DVBViewer Filter for *.m3u8 (HLS) and *.mpd (MPEG Dash). They specify whether the DVBViewer Filter shall be used for HLS / MPEG Dash file playback or a third party source filter, provided a suitable component is registered in the system. HLS can also be played with the LAV source filter, if installed. However, no alternative is currently known for MPEG Dash.
  • Change: File Playback: DVBViewer can now play files with HTTPS URLs by using the DVBViewer Filter, even if the server uses a self-signed certificate or a certificate with unknown issuer. Previously playback failed in this case due to the underlying WinInet API, so that the LAV Source Filter had to be used as fallback.
Channel List
  • Added: Channel Editor: Possibility to include all kinds of media streams and files in the channel list and start playback from there (previously only live streams belonging to the TS Stream type). The Channel Editor enables it in the following ways:
    • Drag and drop media files and folders from the explorer into the Channel Editor. Multi-selection is supported. Only media files are added (see Options → Movies/Music/Images for media file extensions). The drive letter is used as root folder name and the directory name as category.
    • Select media files in the Import Dialog (after switching to the “All Files” type).
    • Add a single item by clicking New → Stream. Enter the URL or file path in the Address input line and the stream name in the Name input line. Finally click the Add button. You can preselect the position where the new item shall be inserted by first selecting an existing category folder or channel list item.
Such items can also be included in the favorites. Channel +/- or Favorite +/- can be used to switch between them, and DVBViewer stores them as “Last Channel”. However, using the number or up/down keys for switching is not possible, because they have another function for file playback. Please note that there are drawbacks due to the channel list file format. Names may get shortened after restarting DVBViewer. Furthermore items with Unicode characters that are missing in the local character set are not handled correctly.
  • Added: Channel Editor: Checkbox “Play as file” on the Channel/Stream Data page for (TS) Stream items. It decides which internal DVBViewer branch takes over playback:
    • If “Play as file” is unchecked, the TS Stream branch intended for live streams is used. It only covers transport streams (TS) and streams that DVBViewer can convert to a transport stream (like MP3/AAC audio or MPEG Dash). Seeking/jumping is disabled.
    • If “Play as file” is checked, the file playback engine is used. However, it can also handle some live stream formats, that are not covered by the TS Stream branch, particularly if the LAV Filters are installed. If the source has a finite length, seeking/jumping is enabled, otherwise disabled.
In many cases DVBViewer recognizes the type automatically and sets/resets the “Play as file” checkmark accordingly. If an item is clearly not playable with the TS Stream branch, the checkbox is checked and disabled. However, in some cases DVBViewer cannot distinguish “live” and “file” by examining the URL (without asking the server), so a manual adjustment may be necessary. This particularly applies to URLs for MP3, AAC, TS, HLS or MPEG Dash Streams.
  • Added: Channel List: New “Playlist Settings” sub-menu in the context menu of all channel list representations (except OSD and Channel Editor), including the Popup Channel List and the Channel Lists in the EPG and Timer Recordings window. The sub-menu contains the following items:
    • Playlist Mode: Switches the mode on/off. In playlist mode file entries in the channel list are played consecutively. When playback of a file is finished, DVBViewer automatically switches to the next one. It skips all channels and streams that are not recognized as file or not marked with “play as file” in the Channel Editor (see above).
    • Endless Playback: Switches endless mode on/off. In endless mode DVBViewer continues with the first file entry after the last has been played.
    • Across Categories: If switched off, DVBViewer regards each category as a separate playlist. It stops playback if the last file entry in the current category has been played, or continues with the first entry within the category in endless mode. If “Across Categories” is switched on, DVBViewer regards all file entries in the channel list as a single playlist.
  • Added: Channel List: “Only File Entries” item in the Filter sub-menu of the context menu. It activates/deactivates a filter for only showing file entries in the channel list. Since file entries don't contain video/audio format information, the H.264/HEVC and AC3 filter options are ignored in this case.
Recording
  • Change: Main Window: The red record button now also signals an ongoing timer recording of the currently played channel by changing its color to blue-gray (previously only in case of manual instant recordings). By this the record menu, that appears after clicking the blue-gray button, is also applicable to timer recordings. If there are two or more ongoing recordings of the channel, an additional submenu level allows to select the recording that shall be targeted by commands like “Stop” or “Delete”. Please note that in two cases the end time of ongoing recordings cannot be changed via the record menu (e.g. by “Stop in 30 Minutes”):
    • Timer recording with weekly repetition on certain days, because it would affect all future recordings triggered by this timer.
    • Timer recordings that are stopped in the Media Server by the EPG status.
  • Added: Main Window: Tweak “Record button only for instant recordings” (→ launch Tweaker.exe). Switching it on lets the record button behave like in previous DVBViewer versions, so that the button and associated menus in the main window only respond to ongoing (manual) instant recordings, not to timer recordings. The default is off. Please note that the action “Record” (by default assigned to the R key) always refers to instant recordings, independently from the tweak. This enables to start instant recordings, even if a timer recording of the currently played channel is already going on. If an instant recording is going on, the action opens the OSD record menu.
  • Change: Recording Options: The elements on the “Recordings” and “Recording Timers” pages (former “Recorder” and “Recordings”) have been re-sorted:
    • The Recordings page contains settings that are applied to recordings when they are started by DVBViewer (not by the Media Server, that uses its own set of corresponding settings).
    • The Recording Timers page contains settings that serve as default for recordings that are executed by DVBViewer or delegated to the Media Server. The settings can be changed individually per timer in the Timer Recordings window (see below).
  • Added: Recording Timers Options: New Placeholders button. It opens a tool window that enumerates all placeholders that can be used in the File Naming Scheme. Double-clicking a placeholder or selecting it and pressing the Return key inserts it at the current position in the input line.
  • Added: Timer Recordings Window: Possibility to adjust the recording format, the included streams and the file naming scheme individually per timer. This entails several internal adjustments. The file timers.xml has a new forwards and backwards compatible hybrid format. Besides timer data in the previous format the same data plus additional fields is written in a more flexible format close to the one used by the DVBViewer Media Server in its svctimers.xml. This avoids weak points of the old format. Now semicolons can be used in the timer name/description, semicolons in channel names do not corrupt timer data anymore.
  • Change: Timer Recordings Window: Deactivated timers (without checkmark) are now displayed grayed (previously in italics). If “Send timers to the server” is configured, remaining DVBViewer timers are displayed in italics. Additionally the hint for such timer list entries contains “DVBViewer Recording!” (previously no indication).
  • Change: Timer Recording Window: The tuner type icons in the timer list now also indicate with a small yellow key if the to be recorded channel is encrypted. If no channel can be assigned to the timer, so that DVBViewer cannot execute the recording, the icon is replaced by a red cross. However, this does not apply to timers that are delegated to the Media Server, because DVBViewer does not know whether the server can assign a channel (its channel list may be different).
  • Fix: Timer Recording Window: The timer list now displays a channel name, even if no channel can be assigned to a timer, since the name can also be taken from the timer's channel ID. Additionally the timer can now be edited in case of a missing channel assignment (previously the Apply button was disabled).This particularly applies to Media Server timers for which no matching channel is present in the DVBViewer channel list.
  • Added: Recording Statistics Window: Bottom panel buttons for stopping, deleting and playing recordings. Previously the commands were only available in the context menu. The Title column of the Recordings tab shows the EPG title plus the EPG subheading (if present) separated by a hyphen (previously only the title). The list views on the Recording Status and Recordings tab now show entries as hints on mouse over if they exceed the column width.
  • Added: Recorder: If the currently played file is referenced by an URL and not located on the local hard disk, it can be downloaded by clicking the red record button. This particularly applies to HbbTV videos from media libraries (HbbTV add-on required). Basically DVBViewer handles the download like a normal recording:
    • The progress can be viewed in the Recording Statistics Window.
    • The file is named according to the user defined scheme (as far as possible without EPG) and stored in a recording directory
    • The download is included in the recording database and listed as recording.
Since the download is performed independently from playback, it will usually be finished before playback is completed. The feature also applies to files that have been added as channel list entries (see “Channel List” section). This allows to schedule the download by creating a timer recording. It stops when the download is finished, or at the latest when the end time is reached.
  • Fix/Change: Recorder: Henceforth DVBViewer will log recordings in the file rec.log (no more in svcrec.log), in order to avoid access clashes with the Media Server.
  • Change: Recorder: The “Delete and Restart” command, available in the he context menu on the Recording Status tab of the Recording Statistics windows and in the Record Menu of the Main Window, now shifts the start time of the restarted recording to “Now” (except in case of timers with weekly repetition), but keeps the duration. Previously the end time was not shifted accordingly, thus shortening the restarted recording.
  • Change: Recorder: Enhanced synchronization between the channel and timer list. Every relevant change in the channel list (e.g. renaming of a channel) immediately updates the assignment of channels to timers. Deleting channels from the channel list lets the timer list create a temporary copy of the channel data, so that the timers can still be executed until DVBViewer is closed. Adding channels lets the timer list check if lost links can be restored. This avoids wrong channel assignments and drifting apart of timers and corresponding channel list entries.
  • Change: Recorder: If Options → DVBViewer Media Server → Send timers to the server is switched on, as well as Options → Recorder → Use Windows Task Scheduler, DVBViewer timers, that are executed by DVBViewer, are still synchronized with the Windows Task Scheduler. Previously any synchronization was prevented by the “Send timers to the server” option.
Timeshift
  • Change: Timeshift: The handling of timeshift recordings has been reworked and changed completely:
    • Timeshift recordings are now performed by the recorder engine, not by the playback unit anymore. The settings on Options → Recordings / Recording Timers apply to it, except the recording format, that is always TS, because it is required for the “recording from timeshift buffer” feature.
    • “Rebuild Playback” does not cancel timeshift recording and playback anymore. The same applies to switching to another audio track, if Options → Recording Timers → Include All Audio Tracks is ticked. After the action playback is continued at the position where it has been stopped.
    • After changing to a currently recorded channel or when a recording of this channel starts, DVBViewer automatically uses the file for timeshift, allowing to jump back in time. This also applies to recordings with MPG or MP2, AC3 etc. as format. Using recordings for timeshift can be limited or switched off by the tweak “Use ongoing recordings for timeshift” (→ launch Tweaker.exe): 0 = don't use recordings, 1 = only timer recordings, 2 = only manual (instant) recordings, 3 = all recordings.
    • When switching away from such a persistently recorded channel, DVBViewer saves the current (timeshift) playback position and restores it when returning to this channel. This enables switching between two or more channels with time-shifted playback (multi-timeshift), provided enough tuners are available for receiving the channels simultaneously.
    • TV/Radio → Keep Timeshift File is no general permanent setting anymore, but specifies the recording status of the currently played channel. The menu item is disabled if no recording of the channel is going on. It is checked in case of a normal (persistent) recording and unchecked in case of a volatile timeshift recording, that is deleted automatically when not needed anymore. Clicking “Keep Timeshift File” changes the recording status from volatile to persistent and vice versa. DVBViewer prompts for confirmation when “Keep Timeshift File” is switched off.
    • Volatile timeshift recordings are not signaled as recordings. REC indicators are not visible and the record button remains red, so that recordings from the timeshift buffer can be started. Furthermore volatile timeshift recordings are not included in the recording database, so they don't appear in the list of recordings, unless “Keep Timeshift File” is switched on before they are deleted. However, timeshift recordings are listed in the Timer Recordings window and on the Recording Status tab of the Recording Statistics window (similar to manually started instant recordings), where they can be controlled by using context menu commands. In contrast to persistent recordings they are displayed in blue, not in black.
    • The Options → Timeshift page has been removed. Two settings have been moved to the TV/Radio page (start timeshift automatically, warning on timeshift termination), other settings are now covered by the Recordings and Recording Timers page. The Directories section provides a new checkbox “Use for timeshift”, allowing to direct timeshift recordings to the selected recording directory. If no directory is assigned to timeshift, DVBViewer takes the first usable directory from the top for it.
    • If DVBViewer is configured as client of a DVBViewer Media Server on the same PC and Options → DVBViewer Media Server → “Send timers to the server” is switched on, it is possible to activate the tweak “Delegate timeshift recordings to the Media Server” (→ launch Tweaker.exe). It lets the Media Server execute timeshift recordings and include them in its recording database, if “Keep Timeshift File” is switched on in DVBViewer (see above). Please note that in this case the Media Server settings apply to timeshift recordings, not the ones in DVBViewer.
  • Change: Media Server Client: When DVBViewer sends timers to the Media Server, it now includes all settings that are visible on the Options → Recording Timers page and in the Timer Recordings Window, thus allowing DVBViewer clients to specify timers more individually than before. However, some of the Media Server’s per-timer properties (EPG Monitoring, Task after Recording, Series, Priority) cannot be controlled in DVBViewer. The Media Server uses default values for them, that are specified in its options.
  • Added: Media Server Client: If “Options → DVBViewer Media Server → Send timers to the server” changes from off to on, DVBViewer timers (supposed to be executed by DVBViewer) are moved to the Media Server. If “Send timers to the server” is already active on program start, but there are DVBViewer timers that previously could not be sent to the server, DVBViewer tries to send them again after loading its timer list (timers.xml).
  • Change: Media Server Options/Wizard: If “Connect to the server's timer list” gets switched off, DVBViewer also switches “Send timers to the server” off, in order to prevent adding of timers without any feedback and control in DVBViewer.
  • Change: Recorder: DVBViewer is now able to delegates timer recordings to the Media Server, even if the channel belongs to the TS Stream reception type and has an URL that refers to the Media Server itself (HTTP transcoded/non-transcoded or RTSP). Previous DVBViewer versions executed such timers themselves, because the server cannot work as its own client. For circumventing this problem, DVBViewer now changes the Channel ID of the timer to the one of the original Media Server channel (retrieved from the URL) when sending the timer and changes it back to the TS Stream Channel ID after having received the timer list from the Media Server.
  • Change/Added: Media Server Client: More consistent and extended error handling when using the Media Server API. If the server is unreachable or responds with a HTTP error code, DVBViewer displays an error message (OSD or message box), particularly “Cannot reach the Media Server”, “Function unavailable” (404 Not Found), “Missing or wrong user name and password” (401 Unauthorized), or the error code in other cases.
  • Change: Recorder: If Options → DVBViewer Media Server → Send timers to the server is switched on, but the server is not reachable or responds with an error code to adding a new timer, a DVBViewer timer (executed by DVBViewer) is created as substitute, if possible.
  • Change: Media Server Client: If DVBViewer is configured as client of a Media Server on the same PC, reception of all TS Stream channels (except those with localhost as source) is delegated by default to the Media Server's web server, that passes the stream on to the DVBViewer client, in order to avoid double bandwidth occupancy, e.g. if the same Internet TV/Radio channel is played in DVBViewer and simultaneously recorded in the Media Server. Please note: This feature requires DVBViewer Media Server 3.0.0 or later.
  • Added: Media Server Client: The tweak “Receive TS Stream via the local Media Server” (→ launch Tweaker.exe) allows to switch reception of TS Stream channels via the Media Server off, if unwanted.
  • Added: Media Server Client: DVBViewer is now able to establish HTTPS connections to the Media Server 3.0 or later, if it is configured accordingly. For this purpose https:// must be prefixed to the content of Options → DVBViewer Media Server → Address and port. Please note that messages from the Media Server to DVBViewer clients, e.g. for letting them update the timer list, use another protocol (UDP Multicast) which can not be changed to HTTPS. The same applies to RTSP/Sat>IP. Auto-detection of Media Servers in the network always assumes HTTP due to the underlying UPnP protocol.
  • Change: Timer Recording Window: Selecting a Media Server timer with EPG monitoring disables the input fields for date, start and end time, because the times are determined by the EPG.
  • Added: Recording Statistics Window: The Recording Status tab now provides full information about recordings executed by the Media Server by means of a new Media Server API (version 3.0.0 or later required). Previously most of the information was empty.
  • Change: Media Server Options / Wizard: The “Ignore local recordings” setting has been reversed and renamed to “Also show DVBViewer recordings” to make it more comprehensible. Additionally DVBViewer prevents the options “Connect to the server's recording list” and “Also show DVBViewer recordings” to be both switched off, because this combination would yield an empty recording list.
  • Change: Recording Statistics Window: If “Options → DVBViewer Media Server → Connect to the server’s recording list” and “Also show DVBViewer recordings” are both switched on, duplicate entries in the recording list are filtered out. Entries originating from the Media Server recording database are preferred over entries originating from the DVBViewer database. Additionally they are displayed in different colors (black = Media Server, blue = DVBViewer), so they can be distinguished.
  • Fix: Media Server Options: If the associated Media Server is currently executing instant or timeshift recordings, and sending timers to the server gets canceled by changed settings, the recordings are stopped after prompting for confirmation.
  • Change/Fix: Input Options: The input options have been reworked completely. Several issues have been fixed. Adding/Editing user defined commands is more convenient and comprehensible now. In detail:
    • Change: The default command list has been restructured. Some groups have been renamed (in the English and German language files), some commands have been moved to a more suitable group so they can be found easier. However, after updating an existing DVBViewer installation to 7.0.0, Options → Input will still show the previous structure, that is loaded from the file default.remote in the Remotes subdirectory of the configuration folder. For adopting the new structure, first rename this file while DVBViewer is closed, e.g. to old.remote. After starting DVBViewer, Options → Input will show the new default list. For restoring user defined commands and key assignments, click Import and select the previous (renamed) default.remote file.
    • Change: The “Learn On / Off” button has been replaced by a checkbox, that indicates the current state more clearly.
    • Fix: Added key assignments are now automatically scrolled into view.
    • Fix: Clicking Apply in learning mode prevented further assignment of remote control keys, though the "Learn Off" button still signaled an active learning mode. It was necessary to switch the learning mode off and on again in order to assign more remote control keys. The keyboard was not affected.
    • Change: “Add Group” does not open an input box prompting for the group name anymore, but adds a new group with the default name “New” and activates an in-place input line in the command list.
    • Change: “Add Command” does not open an input box prompting for the command name anymore. The input line is now integrated in the Command Editor, with “New” as default name.
    • Change: The useless “action name” input line has been removed from the Command Editor. DVBViewer did not use the name. Actions defined in the command.vbs script file (with action numbers starting from 20480) always got and still get the name “User Defined”.
    • Added: Changing the Action ID in the Number input line of the Command Editor or selecting an action in the “Action sequence assigned to the command” list now automatically displays the corresponding item in the “Select an action” drop-down list.
    • Fix: Wrong insert position when re-sorting the action sequence in the Command Editor by drag & drop.
    • Added: All groups can now be deleted (previously only user defined groups). Additionally they can be renamed by slowly double-clicking the name in the command list. It lets an in-place input line appear. Previously renaming was only possible for user-defined groups by deleting and recreating the item.
    • Added: All commands can now be deleted, renamed (by slowly double-clicking them) or edited. Previously only user defined commands could be changed, not the predefined ones that initially populate the command list. Please note: After changing the name of a predefined item it is internally regarded as user-defined. It is not translated by language files anymore.
    • Added: The new button “Import Default” adds missing default commands, that have been deleted or changed before, to the command list again.
    • Change: The previous “Default” button has been renamed to “Load Default”, making more clear what it does. Generally “Import” buttons add something to the list, whereas “Load” buttons replace the whole list.
  • Change: Winlirc: For being launched automatically on DVBViewer start, Winlirc.exe can now also be stored in a Winlirc sub-folder of the DVBViewer program directory (instead of the DVBViewer program directory itself). This avoids a conflict between the Winlirc Plugins sub-folder and the DVBViewer Plugins sub-folder.
Options
  • Change: Options: The Options tree view has been restructured:
    • The Timeshift page has been removed. Two settings have been moved to the TV/Radio page (start timeshift automatically, warning on timeshift termination), other settings are now covered by the Recordings and Recording Timers page (see Timeshift section above).
    • The Shutdown page has been merged with the Extended page.
    • The EPG, Teletext, Subtitles and Channel Logos pages are now subitems of the TV/Radio page. The Teletext page has been renamed to Teletext/HbbTV (see below).
    • The Weather page is now a subitem of the News page.
    • The Images page including its subitem has been moved down below the Movies and Music pages.
    • The DirectX page has been renamed to Playback Components (for making more clear what it is about).
    • The DVBViewer Media Server page has been moved up below the Recording pages, so it is visible without scrolling.
  • Change: Hardware Options: The tuner type of BDA devices cannot be changed anymore in the options, in order to prevent misconfiguration (see here). If really necessary, the type must be tweaked by editing the TunerType entry in the file hardware.xml while DVBViewer is closed (0 = Cable, 1 = Satellite, 2 = Terrestrial, 3 = ATSC).
  • Fix: OSD Menu Options: Missing translation of parent menu names in the list of OSD pages, missing update of the whole list after a language change and other issues.
  • Added: Teletext/HbbTV Options: The new HbbTV section contains HbbTV auto-start options. They are only available if the HbbTV add-on is installed (see DVBViewer help menu → Order/Unlock Add-Ons). The options specify for which channels DVBViewer shall start HbbTV automatically after channel selection. Without auto-start HbbTV has to be activated by pressing OSD Red (F5). The “Passive HbbTV mode” tweak is superseded by the new options and has been removed.
Auto-start can be activated for all channels, only radio channels, no channel or for channels whose name contains a certain character string like “(internet)” or “(connect)”. The last option particularly targets channels that use HbbTV for automatically starting an internet stream after they have been selected, like the German public internet TV channels on the DVB-T2 ARD frequency and the commercial Freenet Connect internet TV channels in substream #1 of the DVB-T2 ZDF frequency.
Please note that HbbTV auto-start may cause a temporary insert in the TV picture after channel selection, depending on the broadcaster. Activated HbbTV (even if not visible) captures some keyboard / remote keys, so that they don’t have their normal OSD function anymore. Pressing OSD Menu or Esc switches HbbTV off and lets DVBViewer return to the normal key assignment.
Miscellaneous
  • Fix: Recording and Device Statistics: Wrong color for unavailable tuners on the Device Status tab (gray instead of red).
  • Fix: Playlist: If the DVBViewer Filter handled live streams originating from a playlist, the playlist was reset to the “not playing” state, causing no item to be selected and the Previous/Next actions to be disabled (see here).
  • Change: TV Playback: Better handling of streams using the H.264 baseline profile, which caused problems with the LAV Video Decoder if configured for DXVA2 native. This also includes measures in the DVBViewer Filter.
  • Fix: Playback: Video format detection failed in case of HEVC Range Extension and High Throughput profiles (also concerns the DVBViewer Filter, see here).
  • Added: EPG Window: Tuner type icons on the “EPG at...” tab.
  • Fix: Screenshots: If Options → General → Use EPG for screenshot filename was switched off, the channel name was not included in the filename in case of TV playback, yielding a filename that only consisted of date/time.
  • Change: Main Window: The “Change Log” item in the Help menu has been renamed to “Release Notes”.
  • Added: Zoom Presets: Tweak “Number of zoom presets” (→ launch Tweaker.exe). It can be used to change the number of zoom presets. Four presets are set up by default. The Preset #x button in the Settings -> Zoom window or the "Zoom Next Preset" action switch over to the next set of zoom settings.
  • Change: Network Libraries / OpenSSL: Network libraries have been updated for OpenSSL 1.1.x support. OpenSSL is required for encrypted connections via HTTPS. The new OpenSSL DLLs (libssl-1_1.dll and libcrypto-1_1.dll) have been added to the setup. They carry different names than the previously used OpenSSL 1.0.2 DLLs (ssleay32.dll and libeay32.dll). DVBViewer preferably uses the new DLLs, if available, but is also able to work with the old ones.
  • Added: Hardware: Plugin interface that allows to support new hardware (e.g. ATSC 3.0 devices) by adding a DLL (by Christian).
  • Removed: Hardware: Support for Freenet DVB-T2 USB devices. If still needed the support will be added again as plugin (see above).
  • Like 1
  • Thanks 2
  • 3 weeks later...
Change Log DVBViewer Pro 7.0.1 (Bugfix Release)
  • Change: General: HTTP Wiki URLs in DVBViewer and the German and English language files have been changed to HTTPS.
  • Fix: Recording Timers Options: DVBViewer did not keep the “Include Teletext, DVB Subtitles…” etc. settings after a restart.
  • Fix: COM Interface: The interface for adding timers was not compatible with old add-ons (particularly Zappi).
  • Fix: Channel List: DVBViewer did not not show EPG hints on mouse over, though "Show EPG Hints" in the context menu was switched on (applies to the Popup channel list and the Channel List, EPG and Timer Recordings window).
  • Fix: Favorites Menu: The items did not show EPG hints on mouse over anymore, after a hint appeared in a tree view or list view.
  • Fix: TS Stream: DVBViewer displayed no EPG for TS Stream channels delivered via HTTP by receivers/servers like Dreambox or VU+.
  • Fix: EPG Window: Wrong channel assignment on the “EPG per Channel” tab after changes in the Channel Editor. The wrong channel was displayed in the details after selecting an EPG item and also assigned to scheduled recordings that were created from this tab (see here).
  • Fix: Timeshift: Stuttering timeshift playback if the timeshift recording was located on a (remote) network share, due to an insufficient read buffer size.
  • Added: Media Server Client: Tweak “Allow timeshift delegation to a remote Media Server” (→ launch Tweaker.exe). Enables DVBViewer to delegate timeshift recordings to a Media Server on another PC. EXPERIMENTAL! The "Delegate timeshift recordings" tweak must also be switched on. Additionally the Media Server MUST be configured to write timeshift recordings to a shared directory with a network (UNC) path (see Media Server Options -> Recordings). Please note: There is no protection against incorrect usage!
  • Fix: Media Server Client: DVBViewer could not connect to a Media Server that is protected by username and password (see here). If a username and password for the Media Server was set up on Options -> DVBViewer Media Server, DVBViewer did not respond anymore to user actions for some seconds after receiving a message from the Media Server (see here).
  • Fix: OSD: The OSD record indicator was not updated on recording start/stop if the main window toolbar was hidden (particularly in full screen mode).
  • Fix: MHEG-5: MHEG-5 did not work with the HbbTV/MHEG-5 add-on, though the HbbTV/MHEG-5 add-on was installed.
  • Fix: Hardware Options: The tuner type selection has been re-enabled for HDHomeRun devices. It is required because the tuner type information exposed by the driver is ambiguous (see here).
  • 1 month later...
Change Log DVBViewer Pro 7.0.2 (Bugfix Release)
  • Fix: OSD: The OSD record indicator was not updated on a channel change if the toolbar was hidden in the main window (particularly in full screen mode).
  • Fix: Music Options: FreeDB Audio CD lookup did not work anymore, because the service was closed. It has been replaced by GnuDB.
  • Fix: Timer Recordings Window: Changing the TV or Radio Format for a scheduled recording in the Timer Recordings window did not work. After Apply the format was reset to the standard format specified on Options -> Recording Timers.
  • Fix: TS Stream: A wrong calculation of time stamps for MP3 streams (particularly internet radio) with 44.1 kHz sample rate could cause periodically interrupted playback after 20 to 30 minutes.
  • Fix: Recorder: Audio frames (particularly AAC frames) that were not aligned with the data packets, misled the audio format detection of the recorder repeatedly and yielded wrong entries in the recording log  (see here).
  • Added: Timer Recordings Window: “New Timer” item in the context menu of the timer list (shortcut Ctrl + N). It deselects the current timer item, resets the timer input area to default values (as specified on Options → Recording Timers), sets the start time to now and the end time to now plus one hour. Previously an empty line in the timer list had to be clicked for it.
  • Added: EPG Window: Picture in Picture menu item in the context menu. It makes Picture in Picture available on the “EPG at…” and “Timeline” tab.
  • Added: Hardware: Possibility to flag devices in the hardware database with “needs tuner type selection”, so that tuner type selection is enabled for them on Options → Hardware, thus avoiding the necessity to change it in the file hardware.xml. Up to now this applies to HDHomeRun devices and the Hauppauge WinTV-dualHD ATSC Tuner (see here).
  • Fix: Timeshift: The DVB hardware used for timeshift recording was not released correctly after a “Keep Timeshift File” on/off change. Besides that issues after using TV/Radio → Stop Timeshift Recording were fixed.
  • Added: Timeshift: Tweak “Delete timeshift files automatically” (→ launch Tweaker.exe).  By default it is switched on, so that DVBViewer deletes timeshift files automatically (e.g. on a channel change). Please note that timeshift files must be deleted outside DVBViewer if this option is switched off, so that they do not fill up the whole hard disk over time. It is recommendable to configure a separate timeshift recording folder for facilitating it (see Options → Recordings).
  • Added: EPG: Experimental possibility to supply IPTV channels with an EPG if the same channel is received via DVB-S/T/C. The mechanism is based on a user-created text file EPGPairingList.txt in the configuration folder that specifies source and target EPG-Channel-ID pairs. DVBViewer and also the Media Server check if the ID of received EPG entries matches one of the source IDs in the list. If yes, a copy of the EPG entry is stored with the target ID. Please note the following:
    • EPGPairingList.txt must contain a pair of EPG-Channel-IDs per line, first the source, then the target ID separated by a comma. Everything preceded by double slashes (//) is regarded as comment and ignored, as well as lines that can’t be read as a sequence of IDs. Example:
562954315180093,1995469939489785 //Das Erste HD (DVB-S) -> Das Erste (Internet)
    •  IDs must only appear once in the file, no matter if as source or target. Otherwise unpredictable behavior or even a crash may occur. If two or more channels shall receive the same copied EPG, additional comma-separated IDs can be appended to the line, e.g.
562954315180093,1995469939489785,2223050546878918 //Das Erste HD → two targets
    •  EPG-Channel-IDs are copied to the Windows clipboard by selecting the channel in the DVBViewer Channel Editor and pressing Ctrl+G.
    •  The source channel frequency must be tuned for supplying the target channel(s) with EPG data. Tuning the target channel won’t do it.
    •  If the URL of an IPTV channel changes, the EPG-Channel-ID also changes, so that the corresponding entry in EPGPairingList.txt must be updated.
    •  For technical reasons the copied EPG data is internally flagged as “External” (as if imported from somewhere). Therefore displaying external EPG must be allowed for the target channel in the Channel Editor (it is by default).
    • Since loading EPG data from the Media Server removes all external EPG data in DVBViewer (thus also copied EPG data), the Media Server should do the EPG copying in this case.
  • 2 months later...
Change Log DVBViewer Pro 7.1.0.0
  • Added/Change/Fix: EPG Window: Various enhancements on the Timeline tab, particularly for people who like to use it for channel selection:
    • Change: Playing a channel by clicking the channel button now only requires a single left click (previously a double click, which is still required for channel switching via the EPG item buttons). A right-click on a channel button allows to select the channel for Picture in Picture via the context menu.
    • Added: Possibility to select a channel and scroll it into view by typing the first letters of the channel name. If the interval between two subsequent keypresses is more than half a second, the key buffer is cleared and a new search started with the next input.
    • Added: The Timeline now marks the currently selected channel (not necessarily played channel) with a yellow frame around the channel button, so the selection remains visible even if the channel has no EPG or the selected EPG item has been scrolled out of view.
    • Added: Two new items in the Timeline context menu:
      • Simple Timeline View (previously only available as tweak) switches to the timeline style of version 6.1.2 and earlier. It lists more channels in a given area, because the lines contain no EPG sub-heading, thus requiring less space. Additionally the simple view doesn’t use different colors for indicating the genre of programs.
      • Show Channel Logos: Displays channel logos in the timeline instead of channel names (provided logos are installed and available for the channels). Please note that logos can’t be displayed in the simple timeline view because there is not enough space for them. As substitute DVBViewer adds tuner type icons to the channel names.
    • Fix/Change: The width of the channel name column and the height of the header row (containing the time) on the Timeline tab were not scaled according to the Windows text size. In “simple timeline view off” and “show channel logos off” mode channel names are now displayed with word wrap in up to three lines, thus showing long channel names completely.
    • Change/Added: The filter dropdown list on the “EPG at…” and “Timeline” tab has been replaced by a button. It opens a popup menu containing the filter options “Only TV Channels”, “Only Radio Channels”, “Only Favorites” and on the Timeline tab additionally “Only Channels With EPG”, allowing to also include channels without EPG. The options can be combined arbitrarily, except “Only TV Channels” and “Only Radio Channels”, which are mutually exclusive.
  • Added: EPG/Teletext: Tweak “Remove (German) gender-neutral language” (→ launch Tweaker.exe). If activated, it replaces German forms of gender-neutral language in the EPG and teletext by generic forms, either masculine or feminine: 0 = unchanged (default), 1 = masculine (Musiker*innen → Musiker), 2 = feminine (Musiker*innen → Musikerinnen). Please note that the setting is applied to EPG data when it is received, not to data already stored in the file epg.dat. Thus it may take time until a change fully takes effect, unless the file is deleted.
  • Added: Channel List: Tweak “Use tuner type icons in channel lists” (→ launch Tweaker.exe). It replaces the media type icons (video/audio) in channel lists by tuner type icons indicating the reception type (DVB-S/T/C or Internet TV/radio. This is useful if the channel list contains a mix of channels from different sources.
  • Change: Channel List: The root folder and Video/Audio sub-folder icons in the channel list have been replaced by other icons.
  • Fix: Channel List: The Picture-in-Picture button in channel list toolbars was always disabled and wrongly showed “Back” as hint on mouse over.
  • Added: Channel Editor: If a (TS) stream channel list entry is selected or New → Stream has been performed and the Address input line is the active element, Ctrl + U copies the URL of the currently played stream / the file path of the currently played file to this input line. This allows to copy the URL of a HbbTV video to the channel list, for example. Previously HbbTV URLs could only be retrieved from the DVBViewer.log after playing the video in debug mode.
  • Fix: TV/Radio Playback: Playback → Rebuild Playback did not work if a live stream was played that was not present in the channel list, particularly internet TV/radio channels that were automatically started from German DVB-T2 HbbTV. Additionally,  after switching playback off, these channels could not be played again without tuning another channel first.
  • Removed: TV/Radio Options: Needless “Channel plus/minus switching delay” checkbox. The delay can as well be switched off by setting it to zero.
  • Fix: TS Stream: Channels using the HLS format were played and recorded without audio if the broadcaster used MP4 segments that contained both video and audio, not separate segments.
  • Fix: Recorder: Options →  Recordings → Auto split on channel data change was not handled correctly, particularly in case of dynamic program switching by the broadcaster, as performed by the German ARD when switching to regional editions of a program and back to the main program.
  • Fix: Recorder: Memory leak on each recording start.
  • Fix: Timeshift: Timeshift was stopped unnecessarily on video/audio A/B switching.
  • Fix: Timeshift: Unnecessary warnings when using Stop in timeshift mode (supposed to stop timeshift when it is active).
  • Change: Main Window: The main window now automatically becomes the foreground window (by temporarily switching to “always on top”), if an urgent message appears in the OSD, e.g. announcing a shutdown after a timer recording.
  • Added: Main Window: If the support for visual impaired users is active, the text panel with EPG information that covers the TV picture can now be hidden / shown by pressing Ctrl + Enter, without affecting other features for the visual impaired. Previously it was not possible to switch the text panel off except by deactivating the support for the visual impaired completely.
  • Fix: OSD: If DVBViewer was started with activated support for visual impaired users (implicating a deactivated OSD), switching the support off did not reactivate the OSD. It required a DVBViewer restart.
  • Change: OSD: The Recordings page now also displays the year of the recording date (previously only day and month).
  • • Fix: UPnP Selection Window: Toggling the “Show Thumbnails” option in the context menu let DVBViewer freeze, if the item list on the right was empty.
  • • Fix: Picture in Picture: Timing issue if Picture in Picture was started on a second monitor with the EVR as video renderer, causing playback to remain in stopped state.
  • • Added: Remote Control: A simulated keyboard keypress on each remote control keypress signals user presence to Windows, thus letting it return from “Away Mode”.
  • • Change: HbbTV: Some optimizations.
  • • Change: Plugins: Measures against “evil “plugins stealing the DVBViewer input focus when they get initialized, particularly on recording/timeshift and picture-in-picture start (see here).
  • • Change: Hardware: DVBViewer now avoids unnecessary automatic TS Stream device creation on internal device availability checks.
  • Thanks 1
  • 3 months later...
Changes in Version 7.1.1.0
  • Added/Fix/Change: Support for visually impaired users: Corrections and additions in the text panel for the visually impaired, that appears in the Main Window if Options → Extended → Support for visually impaired users (JAWS) is switched on (see here).
    • Radio text is displayed in the second line below the channel name, if available.
    • The recording status that was previously displayed in the second line has been removed (there was a bug anyway). The status of timers (deactivated, waiting, timeshift, recording).is now displayed at the beginning of each entry in the timer list that appears at the end of the text panel.
    • The text panel is now displayed with black text on white background, not white on black anymore, in order to avoid screen reader errors.
  • Added/Change: Support for visually impaired users: If Options → Extended → Support for visually impaired users (JAWS) is switched on, main window audio is now muted if another DVBViewer window gets activated (gets the input focus), but is switched on again as soon as the main window gets the input focus back, without having to close the other window first. Additionally the muting can be switched off completely in Options -> Extended with a new checkbox "Mute main window while another DVBViewer window is active".
  • Fix: Support for visually impaired users: If the support for visually impaired users was switched on, DVBViewer still used different background colors and icons in list views at various locations, instead of displaying them in a simple black on white style for facilitating screen reader usage.
  • Change: Recordings: If a recording is deleted by or in DVBViewer, directories that were automatically created for this recording due to path elements in the file naming scheme (e.g. %year\%m\%event\…) are now deleted too if they are empty after deletion of the recording. This also applies to timeshift recordings. Please note that Windows may prevent the deletion of empty directories in case of access conflicts e.g. with the Explorer.
  • Added: Recordings: Under the following conditions DVBViewer informs the Media Server about a recording executed by itself (not by the Media Server), so that it also appears in the Media Server recording list:
    • DVBViewer is associated with a Media Server (see Options → DVBViewer Media Server), that it located on the same PC.
    • Options → DVBViewer Media Server → Connect to the server’s recording list is switched on.
    • The recording directory used by DVBViewer is also a Media Server recording directory.
Even if DVBViewer is associated with a Media Server, it may execute recordings itself, either because Options → DVBViewer Media Server → Send Timers to the Server is switched off, or because DVBViewer has to do the job for technical reasons, e.g. if the recording is actually a file download or a recording from the timeshift buffer. When the Media Server gets informed about such a recording, it copies the corresponding DVBViewer recording database entry to its own database. This saves performing a recording database update in the Media Server for including such recordings.
  • Fix/Change: Recordings: Several adjustments and corrections concerning the handling of recordings, particularly for implementing the feature above.
  • Added: Recording: Tweak “Convert LOAS/LATM to ADTS for AAC recordings” (→ launch Tweaker.exe). For recordings with the file extension .aac it may be useful to let DVBViewer convert a broadcasted LOAS/LATM container to the older ADTS container for compatibility with certain software/devices, particularly editing software like mp3DirectCut.
  • Fix: Recording Statistics Window: Opening an Explorer window with the content of the current recording folder by clicking the path displayed on the Recording Status tab did not work if the path contained Unicode characters that are not available in the local character set..
  • Change: Databases: Optimized handling of the recording, media and music database.
  • Fix/Change: Audio Playback/Recording: Some fixes and enhancements concerning the processing of AAC audio.
  • Added: Radio Text (RDS): Detection of RDS data that is not contained in the audio data, but in a separate stream, as used by German ARD radio channels after changing the audio format from MP2 to AAC. DVBViewer automatically sets the RDS flag and adds the PID of the RDS stream as teletext PID. It can be inspected in the Channel Editor. Additionally DVBViewer is now able to include such RDS streams in recordings and display the radio text on playback, provided the radio recording format is TS and Options → Recording Timers → Include Teletext is switched on.
  • Fix: Radio Text (RDS): Radio text contained in a recorded MP2 or TS file was not displayed in the OSD (only in the control bar).
  • Fix: Radio Text (RDS): Wrong conversion to Unicode if the local (language-specific) Windows character set is not Windows Western European.
  • Change: Audio Playback: On playback of radio recordings in MP2, MP3, AC3 or AAC format DVBViewer now retrieves displayed metadata (like title and description) from the recording database or the EPG Info File. Previously DVBViewer only looked for tags in the file, which are usually not present in recordings.
  • Added: File Playback: EPG data contained in a recording in TS format is now displayed in the OSD Media Window (after pressing OSD OK or the Return key) and additionally in case of radio recordings as radio text at the top of the video window, provided the DVBViewer Filter is used for TS playback (see Options → Playback Components → DVBViewer Filter).
DVBViewer and the Media Server include Now/Next EPG data in TS recordings if Options → Recording Timers →  Include EPG Data is switched on. Please note that recorded EPG data may change during playback, in contrast to the static EPG data stored in the recording database and the EPG Info files. This particularly applies to internet radio, for which DVBViewer transforms the broadcasted metadata (like artist and title) to EPG data.
  • Added: Video Playback: If no metadata (like title, description etc.) can be found for a played video in the recording and media database, DVBViewer now uses data provided by the LAV source filter (splitter), if available. This particular applies to MP4 and MKV videos. The data appears in the OSD Media Window after pressing OSD OK or the Return key.
  • Added: Channel Logos: Support for a new logo administration that spares providing the same logo several times with different filenames for different channel names (e.g. BBC One Scot, BBC One Lon...). In future only one logo file will be needed in this case, plus a file LogoNames.ini that assigns channel names to logo files.
  • Change: Channel Logos: Enhanced assignment of logos to channel names. It may find more or better matches by unifying the strings before comparison, particularly by replacing “+” by “plus” and removing all characters that are no letters or digits.
  • Fix: OSD: Vertical text misalignment in the Movies, Music, Playlist, Images and UPnP list views.
  • Change: EPG: Up to now DVBViewer appended extensive technical information originating from EPG data to the long EPG description (e.g. aspect ratio, video format, available audio tracks, subtitles etc.), often occupying several text lines. It has now been reduced to the most important facts that may change per program. They only occupy a single line and use the following symbols/abbreviations for what is signaled in the EPG:
    • [4:3] [16:9] Program aspect ratio
    • [3D] 3D transmission
    • [HDR] High Dynamic Range video
    • [OA] Original audio provided
    • [5.1] Multi-channel (surround) audio provided
    • [SUB] Subtitles provided
    • [AD] Audio description for the visually impaired provided
    • [age+] Recommended minimum age, e.g. [16+]
    • [PDC day.month hour:minute] Originally intended program start time. The Program Delivery Control is used by the Media Server for program recognition and EPG monitoring.
Please note that this information is not always reliable. Unfortunately some broadcasters handle this EPG based information quite carelessly, e.g. signal a wrong aspect ratio or indicate subtitles for all programs if they are only available for some programs. The new format is applied to newly received EPG entries, not to already stored entries.
  • Change: EPG/Teletext: Further enhancements for the “Remove (German) gender-neutral language” function (see 7.1.0 changes).
  • Fix: TS Stream: Erroneous confusion of the HTTP Location header (used for redirections to another URL) with other headers that also contain the sub-string “location:”.
  • Added: Hardware: Support for assigning up to 4 CI modules in the settings dialog of RTSP network devices for Digital Devices Sat>IP servers (previously only 2).
  • Added: Hardware: On hardware detection DVBViewer creates an additional DVB-C tuner entry for the TBS 5881 hybrid USB Box. This measure saves tweaking the tuner type for DVB-C reception.
  • Fix: Hardware: If the DVB-T2 substream (PLP) ID is undefined, DVBViewer does not set it to 0 anymore as default for TBS devices, which prevented auto-detection in the driver and DVB-T2 reception in Austria, where the substream ID is 1 throughout. Now the TBS API call is omitted in this case (see here).
  • Thanks 2
  • 4 weeks later...
Change Log DVBViewer Pro 7.1.2 (Bugfix Release)
  • Fix: TS Stream: Work-around for erroneous time stamp headers in HLS segments of additional audio tracks provided by German ARD channels, that caused audio drop-outs.
  • Fix: TS Stream: Teletext data in HLS segments of AAC audio tracks provided as separate stream was mistaken for audio.
  • Fix: Recorder: Under certain timing conditions the recorder detected the wrong AAC type when a channel with LOAS/LATM AAC audio was recorded. It caused permanently changing wrong format information in the recording log, but without disturbing TS recordings.
  • Added: Recording Statistics Window: Display of the recording log (if available) in the Details panel of the Recordings tab. The “Show Recording Log” item in the context menu of the Details view or Ctrl+L allow to toggle between EPG details and recording log display for the selected recording. The font for the log display can be selected with the Fonts → Recording Log item of the context menu.
  • Fix: Recording: Missing path and filename of the recording in the recording log.
  • Fix: File Playback: Media files on mapped network and local drives drives could not be played if DVBViewer was configured as client of a Media Server on another PC and Options → DVBViewer Media Server → Connect to the server’s recording list was switched on (since version 7.1.1).
  • Fix: Recording Playback: Recordings of a remote Media Server that were made available on the DVBViewer PC by means of a mapped network drive with the same drive letter as the original (physical) disk were not accessed directly (as intended), but via Media Server streaming.
  • Thanks 2
Change Log DVBViewer Pro 7.1.2.1 (Hotfix Release)
  • Fix: Recording Playback: Recordings of a local Media Server on the same PC were not accessed directly (as intended), but via Media Server streaming (since version 7.2.0).
  • Fix: EPG: The import of external EPG data via Xepg did not work anymore (since 7.1.2.0).
  • Added: OSD: “Only With EPG / Also Without EPG” option in the OSD timeline context menu, that appears after pressing OSD Blue / F8. It specifies if only channels with EPG or also channels without EPG are displayed in the timeline (see here).
  • Thanks 2
  • 4 months later...
Change Log DVBViewer Pro 7.2.0.0
  • Added: TV/Radio Options: Checkbox “Use custom channel numbers”. It allows to configure a custom channel numbering that is independent from the sequence of channels in the channel and favorites list and not necessarily contiguous (which means, there may be gaps between numbers). The channel numbers can be imported from TransEdit, originating from a scan for Logical Channel Numbers (LCN), or manually entered in the DVBViewer Channel Editor (see here). Please note that without these measures there are no channel numbers at all in “custom channels numbers” mode: Channel selection by entering numbers is disabled, and DVBViewer displays “---” where a number is supposed to appear.
  • Added: Channel Editor: “Channel No.” input line on the Channel Data page, allowing to input and edit channel numbers, that take effect in “custom channels numbers” mode (see above). The custom channel numbers are also contained in .ini and .csv channel list exports. Please note that DVBViewer does not check for duplicate numbers (yet). It is up to the user to avoid them. On channel selection by number input DVBViewer switches to the topmost channel from the list with a matching custom channel number (see here). However, the channel number search function of the Channel Editor (after entering a channel number in the right input line of the search panel and pressing Return) always starts from the currently selected channel, so that it finds the next channel with a matching custom number and can be used for duplicate detection.
  • Added: Channel Editor: “Clear Custom Channel Numbers” item in the context menu. It removes all numbers in the selected tree view nodes.
  • Fix: Channel/Favorites Editor: The selection bar was not adjusted correctly to a changed channel/category name width (see here).
  • Fix: Channel Editor: After New → Satellite for entering the data of a new satellite channel it was not possible to specify DiSEqC, 22 kHz signal and LOF because the corresponding controls were disabled.
  • Fix: Channel Search: A satellite channel search with certain DVB hardware (e.g. DVBSky) wrongly reset the DVB-S2 flag of channels on DVB-S2 transponders.
  • Added: Channel List: Command line parameters for importing a M3U or INI channel list, optionally to a specified root folder (see here):
-l (with l being a lowercase letter L) must be followed by a blank and a URL, that specifies the to be imported file. URL can be a network (web) address or a local file path, that must be enclosed in double quotes if it contains blanks. Examples:
-l http://example.com/iptv.m3u
-l "D:\Channel Lists\Terrestrial.ini"
-r must be followed by a blank and a root folder name, that specifies the root folder to which the preceding list shall be imported. It must be enclosed in double quotes if it contains blanks. If this folder already exists, its previous content is deleted. Example:
-r http://example.com/iptv.m3u -r "HLS IPTV"
This parameter can be used to update a root folder content. If no root folder is specified for an import, the list is added to the channel list as if imported by drag & drop into the DVBViewer Channel Editor.
  • Added: Channel List: Tweak “Recognize TS Stream channels by name, if necessary” (→ launch Tweaker.exe). Deleting a TS Stream (IPTV) channel and then restoring it with a different URL usually disables favorites and timers that are associated with this channel. This option allows DVBViewer to re-establish the connection as soon as possible by searching the channel list for TS Stream channels with the same name and type (TV/Radio). Please note that this function may cause unwanted wrong assignments if there are two or more TS Stream channels with the same name and type (see here)!
  • Added: Channel List: Tweak “Load/save channel names as Unicode” (→ launch Tweaker.exe). It lets DVBViewer convert all channel name input to Unicode (UTF-8), if switched on, and subsequently store the names with this character coding. Please note that this may cause compatibility issues with add-ons, plugins and previous DVBViewer versions. They may display characters wrongly. The conversion is applied to channel, category and root names originating from a channel search, the DVBViewer channel list (channels.dat) and channel list imports in INI, CSV etc format. It enables DVBViewer to display different character sets simultaneously in the channel list (Latin, Greek, Cyrillic, Chinese...).
If the tweak is switched off, all channel name input is as far as possible converted to the local (ANSI) character set and stored with this coding. Only characters that are included in this set and ASCII characters are processed correctly. This is the default setting. It conforms to the behavior of previous DVBViewer versions.
  • Added: General: Tweak “Broadcast standard” (→ launch Tweaker.exe). This setting helps DVBViewer to apply suitable methods for the received broadcast standard, if it can't be detected automatically (e.g. when reading Japanese ISDB channel names, see here, or when receiving Japanese EPG with start times that are not UTC, see here). Possible values are 0 = DVB (default), 1 = ATSC, 2 = ISDB (Japan), 3 = ISDB (Latin America).
  • Fix. Timer Recordings & EPG Window: Wrong channel list response on double clicks. Expanding / collapsing elements did not work as intended.
  • Added: EPG Window: Like other EPG views, the Timeline view now responds to Shift + mouse wheel rotation by scrolling horizontally (also applies to the OSD Timeline, see here). Additionally the Timeline view and the list views on other EPG Window tabs now respond by horizontal scrolling, when the mouse wheel is tilted or the horizontal scroll wheel is rotated (see here).
  • Fix: EPG Window: The wrong horizontal scroll direction in the Timeline view after a (mouse wheel) middle-click for switching between vertical/horizontal scrolling has been corrected. The Timeline now scrolls to the left on mouse wheel upward rotation and to the right on downward rotation.
  • Added: File/Timeshift Playback: Continuous display of the picture at the current position with the VMR 7/9 and EVR Enhanced Video Renderer while dragging the position slider with the mouse or using the fast forward / rewind function. Previously this was only possible with the Overlay Renderer, Custom EVR or MadVR.
  • Added: OSD: New method for displaying the OSD with the EVR Enhanced Video Renderer (not custom) as replacement for the previously used OSD Source DirectShow Filter. Compared to the old method the new one provides a better OSD quality with various graphics cards, resembling the quality achieved with the EVR Custom Video Renderer (that is optimized for OSD output) and the MadVR Renderer, except one drawback: If video playback stops for reasons outside DVBViewer (e.g. due to signal loss), the OSD is not updated anymore, unless the user pauses, stops or restarts playback. If the new method does not yield satisfying results, a checkbox “Use OSD Source Filter” on Options → Playback Components enables to return to the previous OSD output method for the EVR Enhanced Video Renderer.
  • Added: OSD: If the OSD Media Window is shown in timeshift playback mode (see tweak “Show Mini EPG in Timeshift mode”), it now displays the filename of the timeshift file, the channel name and logo (if available) and “Timeshift” for indicating timeshift mode.
  • Fix: OSD: Text containing full height Unicode characters (particularly Japanese) was not displayed with certain combinations of font height (defined by the OSD skin) and Windows text size (see here).
  • Fix: OSD: The OSD subtitle menu could not be opened directly by a (keyboard or remote control) keypress assigned to this action, if only external SRT subtitles were available.
  • Added: TS Stream (HLS and MPEG Dash) Display and recording of TTML and WebVTT subtitles, that are used by some providers for HLS and MPEG Dash TV streams and videos. The subtitles can be selected as usual in the Settings → Subtitles menu. They are included in TS recordings, if the corresponding checkbox in the timer settings is ticked. Other players than DVBViewer may not be able to (dis)play these subtitles, particularly since (in contrast to TTML) there are no official specifications for embedding WebVTT in a transport stream (TS). Please note that the DVBViewer subtitle renderer does not implement the full set of TTML and WebVTT features (see here and here), but only parts that are currently needed for broadcasted subtitles (particularly color and position). Additions may be necessary in future.
  • Fix: Recorder: The download of files (by clicking the red record button during playback) that are available as HLS or MPEG Dash streams and storing them as TS files did not include audio and subtitle tracks that were provided as separate streams.
  • Change: Recorder: Sharper check for encrypted data. It prevents writing of encrypted data to disk (see here).
  • Fix: Recorder: DVBViewer could not perform a system shutdown as final action of a timer recording, if a lock screen was active (e.g. after the PC woke up for an unattended timer recording in a password protected user account).
  • Fix: File Playback/Subtitles: Color and other tags in external subrip (.srt) subtitle files were displayed as part of the subtitles instead of being processed and removed. Over-length lines were not wrapped to the next line.
  • Added: File Playback/Subtitles: Processing of external WebVTT subtitle files. The beginning of the filename must conform with the corresponding video file; the filename extension must be .vtt. Additional characters in the filename of the subtitle file following after a separator character are displayed in the DVBViewer subtitle menu, e.g. as WebVTT (eng), if the filenames are myvideo.mp4 and myvideo-eng.vtt.
  • Added: Subtitles: Optionally removing (German) gender-neutral language (see 7.1.0 changes) is now also applied to text-based subtitles (Teletext, WebVTT, TTML, SRT).
  • Fix: Subtitles: Teletext subtitles contained in a TS file could not be displayed (since version 7.1.1).
  • Removed: Subtitle Options: Shadow, shadow color, background color, outline color settings, that were only applied to external subrip (.srt) subtitles in a special OSD branch. It has now been substituted by the general subtitle handling, which does not support shadow effects. The background color is black if not specified differently within the subtitles. The outline thickness and background transparency can still be adjusted. It applies to teletext, SRT, WebVTT and TTML subtitles.
  • Fix: Playlist: After starting playback of a video that was no recording (particularly MKV/MP4 files) the playlist displayed the duration of this item and additionally its title (if it could be retrieved as metadata) for all other video items.
  • Fix: Playlist: The width of the playlist columns was not adjusted to the Windows text size, thus causing cut-off duration values in case of more than 100% size.
  • Fix: Equalizer Settings: After a DVBViewer restart the Presets drop-down list did not indicate the last selected equalizer preset, but always “None”. The preset was applied correctly to the audio output, though (see here). The same applies to the Equalizer OSD page.
  • Change: Hardware: Newly created virtual RTSP (Sat>IP) Network Devices now use a client UDP port range from 47700 to 47800 as default (previously 52000 to 52100), particularly for avoiding collisions with port ranges excluded by Windows due to the usage of Hyper-V.
  • Thanks 1
  • 3 weeks later...
Change Log DVBViewer Pro 7.2.1.0 (Bugfix Release)
  • Added: Mouse Options: Possibility to configure an action for rotating or tilting the horizontal mouse wheel (if present). Furthermore “Jump” has been added as action, enabling to (incrementally) jump forward and backward in files with the mouse wheel.
  • Change: OSD: DVBViewer does not respond to fast mouse clicks (double clicks) with a window ↔ full screen change anymore if the clicks are consumed by the OSD.
  • Fix: OSD: The Updown buttons for browsing the lists on the Channels and Recordings OSD page with the mouse did not work.
  • Fix: News Feeds: Processing news feed URLs without a filename like https://www.tagesschau.de/xml/rss2/ failed, so that no news were displayed in the OSD.
  • Added: News Options: Edit button allowing to change an already present news feed entry.
  • Fix: Zoom Presets: The tweak “Number of zoom presets” did not work anymore (since version 7.2.0.0).
  • Fix: General: Any system shutdown triggered by DVBViewer resulted in a reboot (since version 7.2.0.0).
  • Thanks 2
  • 3 months later...
Change Log DVBViewer Pro 7.2.2.0
  • Fix: Recorder: Certain dynamic channel data (PMT) changes were not handled correctly, particularly audio track changes in connection with the “auto-split on channel data change” option, when German ARD TV channels switched over from common to regional programs.
  • Fix: Recorder: Some issues concerning manual (instant) recordings from the DVBViewer timeshift buffer (starting during timeshifted playback): The recording actually started at a position several seconds later, it could fail if the tweak “Automatically create TS Stream devices on demand” was switched off, the tool bar / TV/Radio menu did not respond by turning the record button gray / checking the “Record Current Channel” item, potential data loss when writing to disk due to a buffer overflow etc.
  • Change: Recorder: If no EPG data can be assigned to a recording, DVBViewer now stores the actual recording duration as duration value in its database and EPG Info file, not the timer duration anymore. This particularly applies to manual (instant) recordings with a default timer duration of 23:59 hours. If EPG data can be assigned, the stored duration value is the program duration.
  • Fix: Timer Recordings Window: Individual per-timer settings in the Include section, that deviated from the corresponding standard settings in the Include section on Options → Recording Timers, got lost on a DVBViewer restart, because they were not read correctly from the file timers.xml.
  • Fix: Media Server Client: If DVBViewer delegated timers to an associated Media Server (see Options → DVBViewer Media Server → Send timers to the server), changing the file naming scheme in the Timer Recordings Window did not work, because the scheme was not sent correctly to the server (see here).
  • Fix/Change: File/Timeshift Playback: Some fixes and enhancements concerning the display of the picture at the current position while seeking/jumping, when the EVR Enhanced Video Renderer (not Custom) is used.
  • Fix: File/Timeshift Playback: Seeking in pause mode with the Custom EVR or MadVR Video Renderer disabled returning to play mode by pressing / clicking Pause again, thus making it necessary to use the Play function (since 7.2.0.0, see here).
  • Added: TS Stream (HLS/MPEG Dash Live Streams): Jumping in internet live streams with the usual means (control bar, forward/back functions), if the broadcaster provides a timeshift buffer (e.g. German public broadcasters). The control bar shows the total duration of the buffer and the current position in this buffer. The previous setting for a fixed (static) time offset in the Channel Editor has been removed. Please note that jumping in the broadcaster’s timeshift buffer is not available
    •  if its duration is less than 3 minutes.
    • if DVBViewer is associated with a Media Server on the same PC, from which it obtains internet streams in order to avoid double bandwidth occupancy. This is the default setting. For using the broadcaster’s timeshift buffer the tweak “Receive TS Stream via the local Media Server” has to be switched off (→ launch Tweaker.exe, see 7.0.0 changes → Media Server Support).
    • if the internet connection of the virtual TS Stream Device additionally supplies other “consumers” like Picture in Picture or a recording besides main window playback. Only the latter is able to handle on-the-fly position changes in the broadcaster’s timeshift buffer. A recording would be spoiled by it.
    • if the built-in DVBViewer timeshift is active, e.g. after Pause or the start of a manual (instant) recording.
Manual (instant) recordings start at the current position in the broadcaster’s timeshift buffer. If it is timeshifted, DVBViewer performs the recording itself, independently from the “Send timers to the server” setting. However, timer recordings always start at the live position of the channel (with a small default offset, see below). Simultaneous timeshifted playback of the channel causes double bandwidth occupation. Just as for different channels, reading from different positions in the broadcaster’s buffer requires a separate internet connection for each.
  • Added: TS Stream (HLS/MPEG Dash): Tweak “Default delay for HLS/MPEG Dash playback” (→ launch Tweaker.exe). The settings specifies the default position in the broadcaster’s timeshift buffer, or with other words, how many seconds playback lags behind the "live edge" of HLS and MPEG Dash live streams. This allows DVBViewer to fetch data ahead and to buffer it, in order to avoid stuttering playback. It can be regarded as a "minimum timeshift" that DVBViewer tries to establish. The default is 30, the minimum 10 and the maximum 60 seconds. The default in previous DVBViewer versions were hard-coded 30 seconds.
  • Change: Timeshift / Control Bar: While the Control bar slider is dragged in timeshift mode, the time display now changes from timeshift buffer position / timeshift buffer length to time at the current position / time now. This enables seeking for a certain time in the past at which a program shall be watched. The change applies to seeking in a DVBViewer timeshift file, as well as in a timeshift buffer provided by the broadcaster in case of HLS / MPEG Dash streams (see above). Please note that for DVBViewer timeshift a precise time measurement cannot be expected, because the timeshift file position is calculated by assuming a constant average data rate, which may be actually variable. So the time display should only be regarded as a rough guide.
  • Change: Timeshift / Main Window: EPG information appearing in the DVBViewer Main Window during timeshifted playback (e.g. in the Control Bar and the OSD Mini EPG) now indicates the program at the played point of time, not the currently broadcasted program anymore. The change applies to DVBViewer timeshift, as well as timeshift provided by the broadcaster in case of HLS / MPEG Dash streams. Concerning the precision of time calculation, the same restrictions have to be considered as for the time display in the Control Bar (see above).
  • Added: Configuration Wizard: Possibility to select the broadcast standard (DVB, ATSC, ISDB Japan, ISDB South America) on the EPG Settings page. It helps DVBViewer to decode EPG data correctly  (see below and here).
  • Change/Added: EPG: EPG start times from ISDB EPG data are now converted to DVB compliant times (UTC, GMT) on arrival, so that afterwards they can be handled like DVB EPG data throughout and the “Automatic Time Zone” setting in the EPG Options is applicable. In detail:
    • Japan: The broadcasted EPG start times are UTC+09:00 (JST, Japan Standard Time), so 9 hours are subtracted. On a Japanese PC, the EPG Options in Automatic Time Zone mode will usually show a GMT offset of +09:00 (see here), which is added to the UTC EPG times, yielding the original JST value.
    • Latin America: The broadcasted EPG start times are UTC-03:00 (Brasilia time zone, see here), so 3 hours are added. The GMT offset displayed by the EPG Options in Automatic Time Zone mode will depend on the actual time zone for which the PC is configured and whether daylight saving time is in effect.
Please note that DVBViewer does not detect the ISDB broadcast standard automatically. If not already set up in the Configuration Wizard (see above), it has to be configured by launching Tweaker.exe, searching for the “Broadcast Standard” setting and entering 2 for ISDB Japan or 3 for ISDB Latin America.
  • Change: EPG: Smarter algorithm for rounding EPG times to minutes, if they are broadcasted to the second. It avoids 1 minute gaps or overlaps between adjacent programs due to double rounding errors.
  • Fix: EPG Options: The times in already received EPG data were not adjusted to a changed GMT offset after switching from Manual to Automatic Time Zone mode.
  • Added: Channel Editor: On the Reception Settings page there is a new checkbox “Check for updates”. If it is ticked (default), DVBViewer checks if its program directory contains a newer version of the transponder list file that shall be used for a channel search. If yes, the user is prompted to decide whether the old file in the Transponders subdirectory of the Configuration folder shall be renamed to .bak and replaced by the new one. Please note: Only users who maintain their transponder list themselves, e.g. by using TransEdit, should untick this checkbox.
  • Added: Channel Search: Additional transponder lists installed with a new DVBViewer version are now copied automatically from the program directory to the Transponders subdirectory of the Configuration Folder, where the transponder lists that are used for a channel search are stored. Previously this had to be done by the user.
  • Change: Channel List: When using the channel list with media file entries as playlist (see 7.0.0 changes → Channel List) the Previous/Next actions (|< and >| buttons in the Control Bar) now switch back/forward to the previous/next file(previously one minute back/forward). This switching and also the automatic switching at the file end plays the previous/next file from the beginning, without considering the setting Options → Movies → On resume ask. Any other kind of switching to a file entry in the channel list (including channel/favorite plus/minus) obeys the setting (see here).
  • Added: Channel List: The “Show EPG Hints” option in the channel list context menu lets DVBViewer additionally show the EPG for recordings that have been added in the Channel Editor as file entries (see 7.0.0.0 changes), provided EPG data is available in the recording database or an EPG info file. Music file metadata is also shown (artist, title, duration, album e.g. originating from MP3 tags), if available, and for other files at least the complete filename without path.
  • Fix: Channel List: If the channel list contained entries with the TS Stream reception type and the Tweak “Automatically create TS Stream devices on demand” was switched on (default), selecting the Filter → Only Available Channels option in the context menu of the channel list let DVBViewer freeze due to an infinite loop.
  • Added: Channel List: New menu item “Sort by Channel Number” in the context menu of channel list representations (except OSD and Channel Editor). This item is only visible if Options → TV/Radio → Use custom channel numbers is switched on (see here). Channels without custom channel number (LCN) are put to the end of the list.
  • Fix: Favorites Editor: A changed category name was updated in the favorites menu, but not in other channel / favorite list representations unless DVBViewer was restarted.
  • Fix: Channel Editor: Media files with network paths (UNC) in M3U playlists were not imported into the channel list, but skipped,
  • Fix: Channel Editor: Incomplete ID values were assigned to media files imported into the channel list. They were corrected automatically on next DVBViewer start. However, favorite list entries for these media files that were created before the restart did not work anymore because they still referred to the incomplete ID.
  • Removed: OSD: Selection dialog for German Sky option channels. It could be opened in certain situations with OSD Green (F6). Sky only provides this mechanism for some SD channels. Moreover it didn’t work correctly anymore since DVBViewer 5.6.
  • Fix: OSD: Misalignment between the mouse position and the internally stored coordinates of OSD elements after starting video file playback using the VMR7/9 or standard (non-custom) EVR Enhanced Video Renderer. It caused mouse operation in the OSD to work imprecisely or not at all (see here).
  • Fix: Subtitles: Blu-ray subtitles (presentation graphics) did not work anymore (since 7.2.0, see here).
  • Fix: HbbTV: Measures against the unnecessary additional download of media files and streams by the HbbTV browser besides the download performed by the DVBViewer playback engine.
  • Change: HbbTV: Measures enabling the HbbTV OSD window to process playback state changes even if it is not active, in order to prevent a premature stop of HbbTV videos.
  • Fix: Teletext/HbbTV Options: A change of the “HbbTV auto start for all channels / only radio channels / no channel” settings required a DVBViewer restart to take effect.
  • Fix: Hardware Options: The Default Button in the RTSP Network Device settings dialog reset the UDP port range to the old values 52000...52100, not to the new values 47700...47800 (see 7.2.0 changes).
  • Change: General: A PC shutdown performed by DVBViewer now considers whether the Windows fast startup feature is enabled (also called hybrid shutdown, available since Windows 8). If yes, shutdown is performed with a flag that lets Windows boot faster on next startup, due to the usage of “suspend to disk” (hibernation). Otherwise a shutdown performed by DVBViewer causes a “traditional” power off and subsequent slow startup (see here).
  • Fix: General: Measures against potential access violations when DVBViewer gets closed.
  • Updated: OpenSSL Libraries to version 1.1.1n with an important security fix.
  • Like 1
  • Thanks 4
  • 6 months later...
Change Log DVBViewer Pro 7.2.3.0
  • Added: Key Tool: Possibility to create an encrypted license data backup file containing the key file content, DVBViewer password and add-on passwords. Please note that the Key Tool stores already installed license data as backup, not possibly differing data entered or edited in the Key Tool user interface. So it is necessary to install licenses before creating the backup. The Backup should be saved on an external medium like a USB drive, where it survives a PC crash, so that you don’t have to purchase the license(s) again in this case!
Loading a license data backup with the key tool requires first entering the user name (the mail address used for ordering DVBViewer) with which the backup was created. After loading the file the Key Tool immediately re-installs the back-upped data without requiring further action.
  • Change/Fix: Key Tool: Several fixes and adjustments in the Key Tool user interface, among them:
    • For writing license data to your hard drive the Key Tool user interface now uses the term “Install”, not “Save” anymore, in order to avoid confusion with “Save License Backup”.
    • For letting the browser show the add-on “Order” pages the Key Tool now uses HTTPS URLS, not out-dated HTTP URLs anymore.
    • Deleting installed key files did not work correctly under certain circumstances.
  • Removed: OSD: All games and the Alarm Timer page, assuming that nobody uses/needs it anymore. The pages can be reactivated with a tweak. Please post in the forum if there is any need for it.
  • Fix: OSD Mini EPG: When using the Mini EPG for browsing through channels (requiring Options -> TV/Radio -> Browse in Mini EPG to be switched on), previously displayed EPG data was not replaced by "No EPG data available", if no EPG data for the next channel and given time was available (since 7.2.2, see here). Furthermore the bar in the Mini EPG showing the already elapsed time of the currently running program did not vanish when switching to the EPG of future or past programs with OSD Right/Left and did not show the elapsed time correctly after returning to the EPG of the currently running program (since 7.2.2, see here).
  • Change: OSD Mini EPG: The time for which the EPG shall be displayed is reset to “Now” on each channel change, or to the time of the currently played program in case of timeshifted playback. Previously the last set time was kept (see here).
  • Added: Radio Text:: Detection and display of radio text embedded in AAC frames, as broadcasted by the German ARD via satellite. This applies to playback of live radio and recordings in TS and .AAC format, no matter whether they have been recorded by earlier DVBViewer- and Media Server versions or converted from th broadcasted LOAS/LATM container to ADTS AAC. Please note that the used method (reading the AAC frames in reverse direction) detects almost all radio text, but may overlook parts of it in rare cases.
  • Fix: TS Stream: General failure with URLs containing no path element, but an at sign (@) or colon in the query part (something like http://xxx.xxx?y=@zz:zz). They were parsed incorrectly, causing a socket error. Moreover redirections from a persistent “keep-alive” HTTP connection to an HTTPS URL with the same domain were not handled correctly.
  • Removed: Channel List: Menu item “Sort by Channel Number” in the context menu of channel list representations (introduced in version 7.2.2). It didn’t prove to be useful (see here).
  • Change: Channel List: After the import of M3U or INI channel lists by using the -l command line parameter (introduced in 7.2.0) DVBViewer saves its channel list automatically if it is configured as client of a Media Server on the same PC, in order to also update the channel list used by the Media Server (see here).
  • Added: Channel Editor: On M3U (IPTV) channel list import the Channel Editor now adopts channel numbers from tvg-chno tags, if present. Using them for channel selection by number input requires Options → TV/Radio → Use custom channel numbers to be switched on.
  • Fix: DiSEqC Editor: Display fault in the top area (see here).
  • Added: Playlist Window: New “Auto-Save when DVBViewer Closes” item in the context menu. If checked this setting lets DVBViewer automatically save the current playlist to the Playlist.m3u file in the configuration folder on closing for restoring it on next start. Previously the playlist could only be saved manually.
  • Change: Playlist Window: Now the Save/Reload Playlist tool buttons and context menu items are only enabled if the playlist differs from the content of the Playlist.m3u file in the configuration folder. Previously they were always enabled. The numbering of items (if switched on, see context menu) now is one-based. Previously it was zero-based.
  • Fix: Playlist Window: Drag and drop of media files / folders from the Explorer into the Playlist Window did not work anymore as soon as a playlist item was selected.
  • Fix: HbbTV: If a HbbTV video was playing, Playback → Playback Off did not finish the OSD HbbTV mode, so that the keyboard did not return to its normal OSD functionality and HbbTV content possibly remained on the screen.
  • Change/Fix: HbbTV: Several HbbTV-related fixes and enhancements enabling to show (mostly German) HbbTV content and play HbbTV videos/streams that did not work before, for example the ARD and ZDF Replay function (see here), allowing to watch the currently running program from the beginning.
General remark about HbbTV: Due to the generally problematic preprocessing of HbbTV content for presentation in PC browser components, and also because of out-dated third party HbbTV components, the HbbTV add-on for DVBViewer should not be expected to work flawlessly in every respect. It still works passably in German speaking countries (Germany, Austria, Switzerland). However, this can not be guaranteed for the future. In other countries the HbbTV add-on is mostly unusable.
  • 4 months later...
Change Log DVBViewer Pro 7.2.4.0
  • Change: Recorder: Handling of loading/saving the timer list from/to the file timers.xml for avoiding data loss on crashes (see here):
    • If the file timers.xml can not be loaded, because it is corrupted, DVBViewer now automatically replaces it by the file timers.bak, which contains the previous timer list state before the last saving. Previously DVBViewer preserved an already existing timers.xml by renaming it to timers.bak before saving a new one, but did not use it.
    • If the file timers.xml is detected as invalid on loading, it is deleted or renamed, so it cannot become timers.bak anymore on next saving. Renaming occurs if there is still some content in the file. The new name is timers[yyyymmddhhnnss].bak, where [yyyymmddhhnnss] is the current date and time, e.g. timers20230105100634.bak. This file can be used for manual repair attempts.
    • DVBViewer now avoids unnecessary saving of the timer list right after loading the timers.xml on DVBViewer start and before the PC enters sleep mode / hibernate. In the latter case usually all timer list changes have been saved before. However, the list is still saved on closing DVBViewer “just in case” to make sure that the current state of the timer list is identical with the one on disk. Normally this yields identical timers.xml and timers.bak files.
  • Added: Timer Recording and Recording Statistics Window: The list views in these windows now also respond to tilting the scroll wheel or rotating the horizontal scroll wheel by horizontal scrolling (previously only in the EPG Window).
  • Fix: TV/Radio Playback: On Rebuild Playback the (stored) ID of the last channel was overwritten by the ID of the current channel, so that the Last Channel function subsequently performed a retune instead of returning to the previous channel.
  • Added: Channel Editor: Automatic conversion of a user agent indication in imported M3U IPTV lists (#EXTVLCOPT:http-user-agent=…) to an equivalent DVBViewer URL appendix (?addhdr=User-Agent:…, see here).
  • Change: Channel Search: In order to make a channel search more comprehensible for first-time users, the “Scan” button on the Reception Settings panel and the “Scan Range” button on the Channel Search panel have both been renamed consistently to “Channel Search” (see here). However, the function remains unchanged. It lets DVBViewer scan all frequencies starting with the one selected in the “Start” field up to (and including) the one selected in the “End” field.
  • Change/Added: Channel Search: The “Scan Frequency” button above “Scan Range”, that previously let DVBViewer scan a single frequency selected in the “Start” field, has been substituted by a different button at a different place. Altogether there are three possibilities to scan a single frequency:
    • The new “Scan” button next to the “Start” field for scanning the frequency selected here.
    • The new “Scan” button next to the “End” field for scanning the frequency selected here.
    • The “Scan this Frequency” item in the (right-click) context menu of a selected channel for scanning its frequency. It does not change the start frequency to the channel frequency anymore, previously requiring an additional click on “Scan Frequency”, but immediately triggers the scan.
  • Change/Fix: Subtitles: Enhancements concerning TTML subtitles, that are preferably used for MPEG Dash streams. Additional styling methods for colors, markup and text position are now recognized and applied.
  • Fix: Subtitles: DVBViewer used “fully transparent” as wrong default value for subtitles background. It was temporarily adjusted to the intended “half transparent” by opening the subtitle options, but permanently corrected only by applying them after some change.
  • Added: Hardware Options: Tweak “Allow BDA tuner re-detection by name” (→ launch Tweaker.exe). Switching this option on allows DVBViewer to re-detect BDA tuners by name if Windows has changed the hardware ID (e.g. after driver installation or a reboot). Retrieving "lost" tuners is performed on DVBViewer start. It avoids "No matching DVB device available" messages and a manually performed "Scan Devices" (see here). Please note: This option should only be applied if really necessary, because two or more tuners with the same name and tuner type (DVB-S/T/C) could be mistaken for each other. After a resulting automatic correction of hardware IDs DVBViewer updates the file hardware.xml immediately.
  • Change: Hardware: On tuner availability checks and tuner initialization DVBViewer now only searches for a device with matching ID in the Windows device enumeration. It does not additionally compare the tuner name anymore (see here).
  • Fix: Hardware Options: For some hybrid/multi-standard BDA tuners a wrong identification string was created on device detection and subsequently transmitted to other simultaneously running applications from the DVBViewer family (e.g. TransEdit), so that they could not recognize a tuner occupation by DVBViewer and vice versa. Please note that performing a new device detection in Settings → Options → Hardware is necessary for the fix to take effect.
  • Change: TS Stream: Changed timing when receiving radio streams in order to avoid problems with unsteadily arriving data.
  • Fix: HbbTV: “arte Mediathek” did not work anymore, caused by a changed HbbTV version indication in the HbbTV user agent string (since 7.2.3).
  • Fix: HbbTV: Due to a bug ARD and ZDF HbbTV videos did not become visible in Automatic Color Key mode, because they remained covered by the HbbTV OSD. Furthermore, due to the same bug, the playback of ZDF HbbTV videos was stopped after some time (since 7.2.3).
  • Fix: HbbTV: An additional empty line in the HTTP header could cause servers to send no response.
  • Fix: General: A runtime library function for conversion of 64 bit integer numbers to text yielded wrong results (particularly concerning Channel IDs), if DVBViewer was running on Apple hardware with ARM M1/M2 CPU in a Parallels Desktop virtual machine.
  • Fix: General: Uninstalling DVBViewer left a still installed Media Server in an unusable state and even prevented uninstalling the Media Server subsequently, if the user opted for DVBViewer program directory deletion. Therefore the DVBViewer uninstaller now prompts the user to uninstall the Media Server first, if it finds DVBVservice.exe, and terminates without doing something.
  • Updated: OpenSSL Libraries to version 1.1.1t (see here).
  • 8 months later...
Change Log DVBViewer Pro 7.2.5.0
  • Added: General: Possibility to open the context menu of list view column headers (allowing to hide/show columns) by pressing Alt + F10, provided the list view is focused, so it can receive keyboard input. Previously the menu could only be accessed by right-clicking the headers, which was an obstacle for visually impaired users. Additionally, if the list supports sorting, a “Sort by…” sub-menu inserted at the top of the context menu allows to select the column by which the list shall be sorted. Selecting an already selected column (marked with a “radio button” dot) reverses the sort order from ascending to descending and vice versa. Previously this could only be achieved by left-clicking column headers. The additions apply to the “EPG per Channel” and “EPG at…” tabs of the EPG Windows, the Timer Recordings and UPnP Server windows and the “Recording Status” and “Recordings” tabs of the Recording Statistics window.
  • Fix/Added: General: Measures for receiving Windows suspend/resume messages in case of modern (connected) standby (see here), so that sleep / wake-up events can be handled properly. In contrast to normal standby applications explicitly have to register for the messages.
  • Fix: General: Adjustments avoiding certain issues if DVBViewer is running under Linux/Wine.
  • Fix: General: Potential issues concerning window positions, caused by unreliable acquisition of the difference between the visible window bounds and the ones reported by the Windows 10/11 API (see 5.6.0 changes: “Windows did not dock gaplessly to the desktop edges or other windows under Windows 10”).
  • Fix: Main Window: The title bar flickered when the DVBViewer main window was moved (since 7.2.4, see here).
  • Fix: URL Playback: DVBViewer did not recognize the content of HTTP carrying a transport stream if the URL contained no .ts filename extension.
  • Fix/Change: Playback: The “Resume playback after sleep mode / hibernation” function (see Options → General) has been reworked. It now ensures that playback does not resume until the user has logged in, if a lock screen is present after wake. The previous lock screen detection method did not work reliably. In case of a network/internet TV/Radio source or HbbTV auto-start the new method additionally ensures that playback does not resume after wake until the host is reachable, checked by a ping once per second, because network adapters may not work at an early stage.
  • Fix: Playback Components Options: Switching “Use DVBViewer Filter for *.m2ts” off on the DVBViewer Filter tab did not take effect because the setting was not assigned correctly to the .m2ts filename extension.
  • Added: Playback Components: Support for the MPC Video Renderer. It can be selected on Settings → Options → Playback Components → Video as video renderer, if it is registered in the system. See here what is working / not working with it. The MPC Video Renderer is recommendable if DVBViewer is running under Linux/Wine.
  • Change: OSD: DVBViewer does not display “n/a” for unknown artists or album names on OSD main menu → Media Center → Music anymore, but omits it.
  • Added: OSD: “Record Series” items in the OSD Blue context menus of OSD pages showing EPG data. Please note that the items are only available if DVBViewer is configured as client of a Media Server full version (not Basic version) and “Send timers to the server” is enabled (see Options → DVBViewer Media Server). DVBViewer itself contains no series recording functionality.
  • Change: OSD: The overscan settings in Options -> OSD General, enabling a certain OSD size reduction on each side so it doesn’t get cut off on CRT TV sets (see here), has been replaced by OSD size adjustment settings. They allow to shrink the horizontal and/or vertical OSD size to a certain percentage of the whole display area extent. An additional “Only apply to full screen” checkbox enables using the settings for OSD adjustment to an ultra wide screen monitor (21:9) or a monitor with portrait orientation (9:16), thus avoiding OSD deformation to the full extent (see here).
  • Removed: OSD: The code for games and the Alarm Timer page. They cannot be reactivated with a tweak anymore (see 7.2.3 changes).
  • Change: Music Database: A database cleanup now also deletes single music files that are no more present (previously only directories including their content that are no more present).
  • Added: Music Tags: DVBViewer now recognizes and reads the IDv2.3 “Album Artist” tag and uses it as artist information for its music database, if no per-track-artist is specified.
  • Fix: Recorder: After a download of a file referenced by an MPEG Dash URL (.mpd) the recording representing the download was not stopped automatically.
  • Change: Timeshift: No (useless) timeshift recording is started automatically anymore if a video and audio PID are missing in the channel data. DVBViewer now waits until the automatic channel update has retrieved the PIDs.
  • Fix: Timeshift: In case of timeshifted playback, activated “Warning on timeshift termination” option and the start of a live stream via the file playback code branch (where live streams are detected and redirected to the live TV branch) the user was prompted two times to decide whether timeshift should be canceled, because after the first confirmation timeshift was not stopped.
  • Fix: Channel Logos: Before using a cached channel → channel logo assignment from the file ChannelLogos2.ini, DVBViewer now checks if the image file exists. If not, DVBViewer automatically deletes the assignment and tries to find another matching logo for the channel. This avoids missing logos in the UI due to removed or renamed logo image files. Previously the user had to reset all cached logo assignments in the Channel Logo Options or to delete the file ChannelLogos2.ini for getting it fixed.
  • Fix: Channel Editor: On a transponder list update to which the user agreed (see 7.2.2 changes), user defined settings stored in the old transponder list (name, channel group, DiSEqC, LOF values) were not copied to the new (updated) one.
  • Added/Change: EPG Window: The EPG export as XML now conforms to the XMLTV format (see here), which is widely used for storing and processing EPG data. Additionally the export function provides saving the EPG in the DVBViewer data format (*.dat), that conforms to the format of the file epg.dat in the configuration directory, where DVBViewer stores its EPG data when it is closed.
  • Change: Hardware: Due to frequent DiSEqC timing problems, the DiSEqCCount value for TBS DVB-S devices is now 2 by default (previously 1), so that every DiSEqC command is sent two times to the switch (see here). The change takes effect on the next device detection (see Options → Hardware).
  • Change: Hardware Options: The “Shared LNB” option has been renamed to “Shared antenna cable” and supplemented by the hint “Tuner connected via 2-way splitter” that appears on mouse-over, in order to prevent misunderstanding and wrong usage.
  • Fix: RTSP (Sat>IP) Client: Increased timeout for connection attempts to Sat>IP servers if the presence of Bitdefender security software is detected, that delays the procedure considerably, so that the normal timeout lets the initialization of virtual RTSP network devices fail.
  • Fix: TS Stream: Memory leak if a transport or radio stream was received and the server forcibly closed the connection (WSAECONNRESET socket error, see here).
  • Added: HbbTV: Support for HbbTV-only channels without DVB video and/or audio, that only display HbbTV content from the internet. The channel search now recognizes such channels, includes them in the search results and appends “(Internet)” to the channel name. This triggers an HbbTV auto start, so that switching to the channel immediately activates the HbbTV content, particularly playback of HbbTV IPTV channels.
  • Updated: HbbTV: Default file HbbTV2.xml, that defines a user agent with lower HbbTV version number for URLs containing “hbbtv.zdf.de” in order to make the ZDF Mediathek work again. DVBViewer automatically updates the file in already existing installations with HbbTV add-on by downloading HbbTV2.xml from dvbviewer.tv.
  • Fix: HbbTV: Some issues with live streams started from HbbTV if DVBViewer timeshift was active:
    • Jumping in the broadcaster’s MPEG Dash timeshift buffer with HbbTV functions did not work correctly because DVBViewer reported the current position in its own timeshift recording to the HbbTV app and tried to apply the position change to the recording.
    • DVBViewer did not recognize a new live stream URL, that was supposed to start playback at a different position, as MPEG Dash stream.
    • In case of timeshifted playback, activated “Warning on timeshift termination” option and playback start of a video or live stream via HbbTV, the prompt for confirmation that timeshift shall be canceled terminated HbbTV. Due to the lack of a better solution DVBViewer currently avoids it by suppressing the prompt (only in this case).
  • 4 months later...
Change Log DVBViewer Pro 7.3.0.0
  • Added: Picture in Picture: The Picture in Picture window now remembers the last played channel and restores it when it is opened without specifying a particular channel, e.g. via TV/Radio → Picture in Picture. Previously it always played the same channel as the DVBViewer main window in this case. Now it only falls back to the main window channel if no tuner is available for the last PiP-channel.
  • Change: Picture in Picture: The mute function in the DVBViewer main window now also mutes Picture in Picture audio, if switched on. Previously the function had no effect on it.
  • Fix: Picture in Picture: When displaying Picture in Picture in a separate full screen video window, the video aspect ratio was not adjusted correctly, if the monitor aspect ratio differed from it, except when using the EVR Enhanced Video Renderer for PiP, which worked as intended.
  • Added: General: Command line parameters allowing to launch additional DVBViewer instances if DVBViewer is already running, thus enabling to play multiple channels at the same time, provided there are enough tuners available (see here). It is not necessary anymore to create additional program directories. The parameters can be added to a DVBViewer shortcut by appending it to the DVBViewer path (separated by a blank) in the shortcut properties. Each instance carries a unique instance number in the range from 1 to 8. Please note the following points:
    • There are two ways to start additional DVBViewer instances:
      • The command line parameter -new starts another DVBViewer instance additionally to already running instances. The instance number of the new one is the number of already running instances plus one.
      • The command line parameter -N (where N specifies the instance number, e.g. -2 or -3) starts an instance with this number. Using -N parameters should not be mixed with -new usage. Please note that an instance does not start, if an instance with the same instance number is already running.
    • Each additional instance automatically creates its own configuration folder, if it does not exist yet, copies missing configuration files from the original configuration folder (of the first instance) to the new folder and uses it henceforth. If the original configuration folder is named CMUV\DVBViewer, the one for the second instance is CMUV\DVBViewer_2, for the third instance CMUV\DVBViewer_3 and so on. Initially the configuration of additional instances equals the configuration of the first instance in every respect (settings, channel/favorites list, window size/position etc.), but can be changed separately and persistently. If an additional instance shall again adopt the original (first instance) configuration in CMUV\DVBViewer, this can be achieved by simply deleting the configuration folder CMUV\DVBViewer_N of the corresponding (number N) instance, while it is closed.
    • Add-ons and plugins (DLLs) may not cooperate correctly (or not at all) with additional DVBViewer instances, if they are not designed for it.
    • The Tweaker.exe and Resizer.exe tools, that are installed with DVBViewer, by default use the setup.xml of the first instance. However, it is possible to let the tools modify the setup.xml of other instances, either by launching them with the command line parameter -N, where N specifies the instance number, e.g. -2 or -3, or by dragging and dropping the file setup.xml from the configuration folder of the instance in question to the Tweaker or Resizer program icon.
    • Every starting new DVBViewer instance automatically mutes audio of already running instances (provided it does not start muted itself), thus avoiding multiple audio playing at the same time. Clicking the video area or the status bar with the middle mouse button lets an instance “grab” audio and play it exclusively by muting all other running instances. Please note that the middle mouse button click in the video area was assigned in former DVBViewer versions by default to an OSD function. So for achieving the desired effect on audio, Settings → Options → OSD Mouse → Middle Mouse Button Function has to be set to “None” first (see here). If Picture-in-Picture audio is switched on in an instance (e.g. by clicking the PiP window with the middle mouse button or switching it to full screen), it automatically mutes main window audio and all other running instances in the same way.
    • When running more than one DVBViewer instance, it is recommendable to use the DVBViewer Media Server for centralized DVB hardware management. It avoids conflicts, enables optimized hardware usage and allows to prioritize timer recordings. The Media Server Basic, that is free for DVBViewer Pro users, is sufficient for this purpose (see here).
    • It is not possible to run multiple instances of the free DVBViewer Demo version. The feature requires the full version.
  • Added: General: Basic support for VVC video (see here). Scanning channels with VVC video and recording them as TS works. Playing them may fail, because the support is not complete yet. Therefore playback of files/streams containing VVC video is delegated to the LAV source filter/splitter, if possible, even if DVBViewer is configured for playing a format with the DVBViewer Filter. Please note that there is no VVC video support in LAV filters before version 0.79.
  • Change: Playback Components: DVBViewer now checks if the graphics card and its driver support Overlay for video output. If not, the Overlay Mixer is not selectable as video renderer anymore and Desktop TV (that requires Overlay) is disabled in the View menu. If Overlay is available, DVBViewer automatically adds a registry entry that is needed on some PCs to make it work in an application. It requires a DVBViewer restart to take effect, however (see here).
  • Added: Desktop TV: Desktop TV (see View menu), that enables TV/Video as desktop background, is now available in all video renderer modes (previously only with the Overlay Mixer), provided the graphics card supports Overlay video. DVBViewer automatically switches to Overlay rendering for Desktop TV, which requires rebuilding the chain of playback components if some other video renderer is active. The same applies to switching Desktop TV off again. Please note:
    • It is recommendable to activate the DVBViewer tray icon on Options → General for controlling DVBViewer in Desktop TV mode, because its main window can’t be accessed. Right-clicking the tray icon opens the DVBViewer context menu. Left-clicking the icon restores the previous display mode.
    • Depending on the graphics card/chip and the video format the LAV video decoder may not be able to handle the old overlay rendering mode correctly. In this case you may want to try ffdshow as video decoder for the affected format.
  • Change/Fix: OSD: Several optimizations and fixes concerning the OSD handling if certain video renderers are used, e.g. flickering outside the OSD display area caused by the EVR Custom Video Renderer with activated DXVA scaling after reducing the OSD size in the OSD General options, or incorrect display of a video windows embedded in OSD pages in Overlay mode after resizing the DVBViewer Main Window.
  • Removed: OSD General Options: Checkbox “Use cut-out frame in Overlay mode”. This option is now always switched on, which means, the area surrounding the actual video is always painted black, thus covering the dark purple Overlay color. Additionally the black frame now also works in case of OSD size adjustments in the OSD General Options.
  • Added: OSD General Options: The slider for OSD transparency now also takes effect if the MPC Video Renderer or the EVR Enhanced Video Renderer (only with “Use OSD DirectShow filter” switched off) is used.
  • Fix: Channel Logos: Unnecessary checks if a channel logo image file with a hyphen (-) as name exists, causing channel logo processing to take too long (since 7.2.5.0, see here).
  • Fix: TTML/WebVTT Subtitles: Occasional timing issues caused by wrong handling of TTML timestamps. TTML subtitles are frequently used for MPEG Dash streams (particularly live streams provided via HbbTV). WebVTT subtitles were displayed in wrong order under certain timing conditions.
  • Added: Playback: If DVBViewer is operating as Sat>IP client, the “Options → General → Resume playback after sleep mode / hibernation” function now additionally ensures that playback does not resume until the Sat>IP server is reachable, checked by a ping once per second (see 7.2.5.0. changes).
  • Fix: Audio Visualizations: The visualizations did not work anymore on radio/audio playback, if the EVR Custom Video Renderer was selected on Settings → Options → Playback Components → Video (since 7.2.5.0, see here).
  • Fix: Channel Search: A missing Transponders subdirectory in the configuration directory was not recreated automatically. Since this subdirectory is usually created by the setup wizard on first DVBViewer installation, the bug only took effect in special cases.
  • Change/Fix: EPG: The EPG start/end time and duration are now stored non-rounded as they arrive, but are rounded to minutes later when being read from the EPG database, e.g. for displaying them somewhere. Previously they were already rounded on arrival. The change avoids issues with internet radio (shoutcast) metadata that is transformed internally to EPG data (see here).
  • Fix: Recorder: Under certain conditions transport stream packets with video filler data were not removed, though configured by the user and possible (see here).
  • Added: Universal Remote Plugin: Checkbox in the configuration window allowing to switch the plugin’s tray icon on and off. The plugin is included in DVBViewer standard installations.
  • Fix: Hardware: Increasing the DiSEqCCount default value for TBS DVB-S devices to 2 in version 7.2.5 (causing every DiSEqC command to be sent two times) proved to be unfavorable in case of Unicable (see here). Therefore DiSEqCCount is now decreased by 1 if (and only if) it is greater than 1 and Unicable DiSEqC commands have to be output with a TBS device.
  • Added: Installer: Checkbox for adding a firewall rule that allows DVBViewer to receive UDP data from the internet (particularly multicast TV like MagentaTV, see here). The same can be achieved by executing DVBViewer_IPTV_Firewall_Rules.bat from the DVBViewer program directory with administrator rights. Please note: Must only be used in a home network behind a router!
  • 7 months later...
Change Log DVBViewer Pro 7.3.1.0
  • Added/Change/Fix: Playback Components Options: General rework and several minor fixes, among them the following points:
    • Added: DVBViewer now allows to use audio formats in the Auto B Conditions input lines and also in the “Conditions” line of filter graph preset files (.fgp, see here). The new conditions are MP2, MP3, AC3, AAC, PCM. The mouse-over hints for the Auto B Conditions input lines have been updated accordingly.
    • Change: Special Video Renderer settings now only appear on the Video tab, not on the Audio tab anymore. The Auto B Conditions input lines now appear on all tabs, not only on the Video B / Audio B tabs
    • Change: For Windows 8 and later, the Microsoft DTV-DVD Video/Audio Decoders have been excluded from the MPEG2 Video and AC3 Audio decoder selection and also from DVD Decoder selection, except if DVBViewer detects that the Windows DVD Player is installed. If not, Windows 8 and later do not support decoding of these formats. Additionally Decoders have been excluded from the decoder selection for DVD playback, that actually don’t support DVD playback (MEDIATYPE_DVD_ENCRYPTED_PACK input).
    • Added: MP2 Audio Decoder selection for DVD playback (previously only the AC3 decoder was selectable). DVBViewer determines the audio format by checking the audio tracks of the first DVD title. If one or of them is not MP2, it uses the decoder selected for AC3, otherwise the one for MP2. Please note: The detected audio format only influences the used decoder on playback start, not later on audio track changes. Generally audio decoders suitable for DVD playback are expected to support all audio formats specified for Video DVDs (MP2, AC3, DTS, LPCM) and to be able to switch between them seamlessly.
    • Added: MP3 Audio Decoder selection for Picture in Picture, particularly for playback of internet radio streams.
  • Added/Change/Fix: Image Display: Enhancements for displaying still images (photos etc) in DVBViewer. Generally there are two ways of displaying images: Either as OSD Slideshow with optional animation effects. Or statically by using DirectShow components, as for other media files. The OSD slideshow takes over, if Options → Images → Play images as OSD Slideshow is switched on and more than one image is passed to the DVBViewer main window, either as selection of image files (via drag & drop or Playback → Open Media File) or as a folder containing image files (via drag & drop or OSD Main Menu → Media Center → Images). OSD Slideshows stop TV/video playback, but not radio/music playback, that continues in the background. Like other OS pages the slideshow can be switched off with OSD Menu (Esc key) or OSD Back (space key). In other cases than the ones mentioned above (single image, other sources) DVBViewer uses DirectShow playback and additionally its playlist for more than one image.
    • Change: DVBViewer now consistently uses the “Generate Still Video” source filter (provided by Windows) for displaying JPEG, GIF and BMP files via DirectShow. PNG images, that are not supported by “Generate Still Video”, have to be handled with the LAV source filter as “single picture video”, which may cause issues depending on the Video Renderer and its settings.
    • Added: Images offered by the UPnP window can now be displayed in the main window via DirectShow. Previously the Play button in the UPnP window did not take effect if an image was selected. The same applies to image URLs entered in the Playback → Open URL dialog. Images from these sources are downloaded first and stored in a temporary file, because “Generate Still Video” can’t process URLs.
    • Change: The OSD pause icon does not appear anymore in the main window while an image is displayed via DirectShow.
    • Added: The “Playback → Open Media File” dialog in the main window as well as the “Add Items” dialog in the playlist window offer to select “Image Files” as file type in the drop-down list at the right, for displaying only image files. Please note that both file dialogs support multi-selection in the usual Windows way.
    • Added: Image files in the DVBViewer Playlist are now automatically displayed one after the other. Options → Images → Display Duration specifies how long an image remains visible until the playlist switches over to the next item. Previously the switching had to be triggered manually for images. Thus the playlist can now also be used for slideshows, but without animation effects.
    • Fix: The OSD Slideshow could not process filenames containing Unicode characters that were not covered by the local character set. Items in the OSD Slideshow context menu (opened with OSD Blue) were not translated. If the EVR Custom Video Renderer was used and an OSD Slideshow already going on, starting another OSD Slideshow by dragging image files into the DVBViewer main window failed with an access violation.
  • Fix: General: Some UI elements were (almost) invisible in Windows dark / high contrast themes (see here), particularly transparent black-on-white toolbar icons in the Teletext Window, the Playlist Window and the Control Bar, and also captions in the Pages tree view of the Teletext Window. Black-on-white icons are now inverted to white-on-black if such a theme is active.
  • Fix: General: The mouse-over-hints of the small DVBViewer taskbar icons were not translated.
  • Change: General: The command line parameter -new for starting another DVBViewer instance additionally to already running instances now starts the instance with the first unoccupied instance number (beginning with 1). Previously the instance number was the number of already running instances plus one (see 7.3.0 changes and here).
  • Added: General: New action “New DVBViewer Instance” (see actions.ini in the DVBViewer Program Directory), allowing to assign a keyboard or remote key to it.
  • Added: Main Window: Tweak “Show ‘New DVBViewer Instance’ item in menus” (→ launch Tweaker.exe). It adds a “New DVBViewer Instance” item to the TV/Radio sub-menus in the main window for launching another DVBViewer instance by using the -new command line parameter (see here). Please note that the tweak is a “per instance” setting. If additional DVBViewer instances have already been used before, the tweak must be applied to each instance separately (e.g. by dragging and dropping its setup.xml on Tweaker.exe).
  • Fix: Main Window: Functions assigned to the horizontal mouse wheel (or tilting the mouse wheel) did not work if the support for visually impaired users was active (see here). A double middle mouse button click switched full screen on/off, which could cause unwanted switching when using the middle mouse button for other purpose. Now only the left mouse button switches full screen on/off.
  • Fix: Main Window: On a start with a command line parameter that triggered an OSD prompt DVBViewer got stuck while displaying the start screen. The OSD prompt could not be answered, because the main window was still invisible. Now DVBViewer displays a Windows message box in this case.
  • Change/Fix: Volume Control: The code for the DVBViewer volume control has been simplified and restructured in order to work more consistently, particularly with regard to Picture in Picture and multiple DVBViewer instances. Among others this entails the following points:
    • Fix: Unmuting a DVBViewer instance, either by turning up volume or clicking “Mute” again, did not mute other running instances.
    • Change: The volume can now be adjusted in playback off state before playback gets started.
    • Change/Fix: The volume slider in the control bar now also takes effect on Picture in Picture, if Picture in Picture audio is switched on, and is updated when Picture in Picture volume changes. Previously the control bar volume slider was set to 0 (indicating muted Main Window audio) when Picture in Picture audio was active. Moving it additionally turned Main Window audio on, which is presumably unwanted in most cases.
    • Change: Clicking the Main Window with the middle mouse button now switches the Main Window to muted state, if it is not muted (see here).
    • Fix: The Mute function muted Picture in Picture audio, if active (introduced in 7.3.0), but unmuting it turned Main Window audio on. In Main Window playback off state the Mute function was deactivated, thus not available for Picture in Picture.
    • Fix: Switching Picture in Picture in its context menu from “Separate Window” to “Embedded in Main Window” mode or back unintentionally switched Picture in Picture audio off and Main Windows audio on.
    • Change: Switching Picture in Picture as a separate window to full screen does only switch Main Window audio off and PiP audio on automatically, if both windows are located on the same monitor, so that PiP full screen covers the Main Window completely.
    • Change: If a scrollable OSD element is visible and Picture in Picture audio active, the mouse wheel is now used for scrolling the OSD element, not for PiP volume control anymore. Previously the mouse wheel had no effect on OSD elements in this case.
    • Removed: Checkboxes “Remember volume for each channel” and “Remember stereo/left/right for each channel” from the TV/Radio Options, since these options are presumably not needed anymore. The according values stored in the channel list are ignored (see here).
  • Change: Subtitles: A subtitles selection for a channel resulting from “Options → Subtitles → DVB Subtitles → Enable automatically if available in the following languages” is not stored in the TV database anymore. Any manual subtitles selection stored in the TV database has priority and will persist. This applies to the Main and Picture in Picture window (see below).
  • Added: Picture in Picture: Subtitles display and subtitles selection in the context menu of the PiP window, except if the VMR7 is used as video renderer. Subtitles facilitate to keep track of what is happening on a PiP channel without audio. As for the main window, DVBViewer stores the last subtitles selection for a channel in its TV database. The selection is restored automatically when the channel is tuned again in the PiP window. However, there are priority rules:
    • If subtitles for a certain channel have been activated in the main window before, the PiP window displays them also if this channel is tuned. They can be changed or switched off manually for the time this channel is displayed as PiP, though.
    • The main window ignores any subtitles selection stored in the TV database for the PiP window (which means, it will not display these subtitles, unless selected manually). A subtitles selection in the main window overwrites a TV database entry created by the PiP window for the particular channel.
  • Added: Picture in Picture/OSD: Subtitles menu item in the OSD context menu for Picture in Picture (opened with OSD Blue or F8). It opens another OSD menu for PiP subtitles selection.
  • Added: Picture in Picture: New option “Change Size with Main Window Size” in the context menu of the Picture in Picture window. It applies to the embedded (not separate) PiP Window and lets DVBViewer increase or decrease its size proportionally if the DVBViewer Main Window size changes. If this option is switched off, the size of the embedded PiP window remains unchanged, unless resized manually.
  • Added: Picture in Picture: Selection of a PiP channel by right-clicking it in the Favorites sub-menu of the main and context menu in DVBViewer main window. Please note that the Favorites menu does not indicate whether a channel is currently available for PiP. If not, the right-click remains without effect (see here).
  • Change: Picture in Picture: DVBViewer now also resumes PiP playback after sleep mode / hibernation, if Options → General → Resume playback after sleep mode / hibernation is switched on. Previously the Picture in Picture window remained closed.
  • Change: Picture in Picture: The functions Resize Window, Channel Plus / Minus and Favorite Plus / Minus, that can be assigned to the vertical / horizontal mouse wheel on Options → Mouse, are now applied to the Picture in Picture window if it is in “Separate Window” mode and has the input focus.
  • Fix: OSD: The removal of the Alarm Timer code caused an access violation in the Sleep Timer OSD plugin (since 7.2.4.3, see here).
  • Fix: OSD: The OSD weather page did not work anymore. It only displayed an error message “Error getting the weather data” (since 7.3.0).
  • Fix: OSD: When using the mouse wheel for scrolling in OSD list views, DVBViewer did not check correctly whether the mouse cursor is inside the list view. The list did not respond to the mouse wheel if the cursor was located in the bottom part, but still responded if the cursor was located above the list.
  • Added/ChangeFix: OSD / News: Numerous enhancements and fixes concerning the OSD News page (by default located in the OSD Main Menu → Media Center sub-menu) and the processing of RRS news feeds. This particularly includes as new feature the playback of video/audio content offered by RSS feeds (podcasts, lists of radio plays etc.).
    • Change: The InfoSat news feed, that was one of default feeds set up by the DVBViewer configuration wizard, is not available anymore and has been replaced by the German Digital Fernsehen news feed (https://www.digitalfernsehen.de/rss/rss91.xml). However, this only takes effect on new installations. In old installations the obsolete InfoSat entry has to be replaced or deleted manually on Options → News.
    • Added: Reading of media links contained in RSS XML files (image, video or audio, the latter typically used for RSS based podcasts). DVBViewer is now able to (dis)play such content. Previously it only recognized some image URLs. The presence of media is indicated by a <Video>, <Audio> or <Image> tag in the first line of the (long) news item description, including the video/audio duration. Selecting an already selected item by pressing OSD OK (return key) or a mouse click lets an image show up or starts playback of video/audio content (see here).
    • Added: The first line of the news item description now displays the date and time when the news item was published (if this information is present in the RSS XML file).
    • Added: The OSD Blue context menu contains a new item “Open in Browser”, that opens an internet page corresponding to the currently selected news item, if available. Usually it leads to a more extensive version of the RSS synopsis.
    • Change: The heading above the list of RSS feed items now primarily displays the title of the news channel, as given in the RSS XML file. If no title is available, it displays the description entered by the user on Options → News. If the description is empty, it displays the name entered by the user, as before.
    • Change: If the user does not specify an icon/image as URL or file path on Options → News, the icon specified by the RSS XML file is displayed. If no icon is specified, DVBViewer now displays a default RSS icon (previously none).
    • Fix: After a change on Options → News DVBViewer did not adjust the list of news feeds offered in the OSD, but appended the changed list to the previous one, so it became longer and longer, until DVBViewer was restarted.
    • Fix/Added: OSD Green (F6) did not switch to the next news channel, as stated in the help text for the News page. OSD Yellow (F7) now switches to the previous news channel.
    • Fix: Issues concerning the navigation with OSD left, OSD Right etc. (the arrow keys) between control elements on the News OSD page with the default OSD skin. Some elements could not be reached in this way, in certain situations no element was focused anymore, which disabled keyboard navigation.
    • Change: Help text updated.
    • Change/Added: The “Download feeds automatically” checkbox on Options → News has been renamed to “Always download RSS feed files (don’t read from cache)”. The functionality is the same, though. If checked, news feeds are kept as up-to-date as possible by downloading the XML RSS files again on each access. However, images associated with news are still read from the cache, if possible. The cache is located in the Images\Thumbs\News sub-directory of the DVBViewer configuration folder.
    • Added: New checkbox “Clear cache when DVBViewer closes” checkbox on Options → News → Cache Settings. If checked, it forces a complete update of RSS news feed files including images after the next DVBViewer start, because everything has to be downloaded again. The new “Clear Now” button enables clearing the cache manually.
    • Change: The list view containing the available news feeds on Options → News has been enlarged, so that more entries are visible at the same time. A new item is inserted at the currently selected position (previously always appended to the item list). If no item is selected, a new item is appended and automatically scrolled into view, if it is outside the visible area.
  • Added: Playlist Window: A new context menu item “Add RSS Podcast” opens a window for inputting a RSS Podcast URL, as it can be found on various sites in the internet. DVBViewer adds audio or video content enumerated in the RSS XML file to the playlist (mostly MP3 audio URLs, see here).
  • Added: Playlist Window: Adding playlist items with drag & drop into the playlist window, with the “Add Items” file dialog or “Add RSS Podcast” context menu item usually does not replace already present items, but appends new items without playing them immediately. However, if the Ctrl key is pressed while the operation takes place, the playlist window now clears the playlist before adding new items and starts playing them immediately.
  • Change: UPnP Server/Selection Window: Faster response if an entry of the UPnP folder tree view is expanded for the first time. Only data necessary for displaying the folder content is fetched from the server, no content of other nodes as before.
  • Fix: UPnP Server/Selection Window: UPnP server detection did not work under Linux/Wine because the method for enumerating local network adapters did not yield correct results. Now the UPnP code is based on the correctly working adapter enumeration method used for the Sat>IP server detection.
  • Fix: UPnP playback: Playing URLs containing an ampersand character could fail, because they were not XML-decoded (& is encoded as &amp;). This particularly applies to RTSP Sat>IP URLs received from Digital Devices OctopusNet servers.
  • Fix: DVD Playback: Under certain timing conditions DVDs were played with a wrong speed, particularly after restoring a DVD state for resuming playback at the last position where playback previously was stopped.
  • Change: DVD Playback: If a DVD structure is played from hard disk, DVBViewer now displays the name of the folder containing the structure as title instead of the filename VIDEO_TS.IFO.
  • Added: Media Server Client: If multiple Media Server instances are used on the same PC, DVBViewer now considers the instance number provided by DVBViewer Media Server 3.3.1.0 or later for checking whether it is “his” instance, in order to avoid useless attempts to connect to a stopped instance. Previously a (wrong) running instance could be mistaken for another (required, but stopped) instance. Please note that DVBViewer does not store a server instance number greater than 0 persistently, unless the Media Server instance is (re-)selected on Options → DVBViewer Media Server, or for Sat>IP in the settings of an RTSP Device on Options → Hardware, and the dialogs are finished with Apply/OK.
  • Fix: Media Server Client: DVBViewer did not detect the presence of a Media Server running as service on the same PC and did not connect to it anymore, if the localized name of the system account was not SYSTEM, as in some countries (since 7.3.0, see here).
  • Fix: Teletext Window: Even with disabled support for the visually impaired the textual teletext representation for the visually impaired could get the input focus, though it was completely covered by the graphical teletext representation. In this state the Pages tree view on the left did not respond to keyboard input until it was clicked or the tab key pressed.
  • Fix: Hardware: DVBViewer now disables input plugins before the PC enters sleep / hibernate mode and re-enables them after waking up, in order to prevent DVB devices with infrared receiver, that cannot cope with sleep mode while being active, from crashing.
  • Removed: Hardware: Support for the old DVB IPTV reception type, which is already integrated in the TS Stream branch since version 6.0.0. DVB IPTV channel list entries and INI imports are automatically converted to according TS Stream entries. Virtual DVB IPTV network devices are ignored when the device list is loaded and cannot be added to it anymore. If setting up the UDP/RTP interface IP address for receiving the streams is required, add a TS Stream device to the device list and select the interface in its settings.
  • Added: Hardware Options: The settings of virtual RTSP (Sat>IP) devices now allow to select the network interface (adapter IP address) that shall be used for receiving UDP streams from the Sat>IP server. The default is “Automatic”, which means, it is up to Windows to select a suitable network adapter. Selecting a specific one may be necessary if two or more network adapters are present, particularly virtual network adapters due to a VPN or virtual machine, and Windows selects the wrong one (see here).
  • Fix: Downloader: In certain cases the DVBViewer Pro Downloader reported a WinInet 12150 error (ERROR_HTTP_HEADER_NOT_FOUND) if the server response contained no content length indication in the HTTP header (see here).
  • Fix: EPG: The “preceding/following program” functions did not work properly if broadcasted EPG times contained fractions of whole minutes (e.g. 30 seconds), particularly when navigating in the OSD MiniEPG (since 7.3.0.0, see here).
  • Fix: Recorder: DVBViewer instances with activated Options → Recordings → Use Microsoft Task Scheduler mutually deleted scheduler entries created by other DVBViewer instances, because the timers did not exist in their own timer list. Furthermore the Task Scheduler always launched the first DVBViewer instance, not the one in which the recording was scheduled.
  • Fix: HbbTV: If active, HbbTV uselessly “consumed” the actions Channel Minus/Plus (-x8 / -x9 command parameters), so they could not be used for channel switching (see here).
  • Like 1
  • 7 months later...
DVBViewer Pro Beta 7.3.1.9
An installer for DVBViewer Pro Beta version 7.3.1.9 is available in the Members (Download) Area -> Beta Section.
Please note the following important change: The certificate that we have used to sign our software has expired. Unfortunately getting a new one has become much more expensive and complicated in the meantime, which is a problem for small software manufacturers like us. Therefore we are providing this release first as a self-signed beta version, until we have found a better solution.
Because Windows cannot verify the publisher, launching the beta installer downloaded by a browser will trigger misleading "Windows protected your PC" warnings, and you need to first click "More info" and then "Run anyway" to get it going (see here). Also anti-virus software may respond more suspiciously.
However, you can avoid this hassle by launching the signed DVBViewer Pro Downloader of the previous DVBViewer 7.3.1 version (see Windows start menu -> DVBViewer). After scrolling down to the bottom you will see a new "Applications" section, offering beta versions. Select what you want to install and let the downloader do its job. As long as you are using the original downloader (with Christian Hackbart verified as publisher in the Windows UAC screen) or a download from our members area, you can be sure that we are the publishers, despite any warnings.
Please also note that downloading and running the DVBViewer Media Server Beta 3.3.1.9 full version requires purchasing an additional Media Server license (if not yet done)! This does not apply to the restricted Basic version, though (see here).
Change Log DVBViewer Pro Beta 7.3.1.9
  • Added: RTSP (Sat>IP) Client: Support for TCP interleaved transport mode (also called RTP/AVP/TCP). It enables receiving video/audio and additional data from Sat>IP servers supporting this mode via a single TCP connection established by DVBViewer for sending commands (see here). The normal mode requires two additional UDP streams for data transport. Please note the following points:
    • TCP interleaved mode must be enabled in Options → Hardware → Settings for each virtual RTSP device in question by changing the protocol from UDP (default) to TCP. Previously this setting was only available if the RTSP device referred to a DVBViewer Media Server as source. In this case the setting activated a proprietary TCP transport mode only supported by applications from the DVBViewer family.
    • TCP interleaved mode is part of the RTSP standard, but not mentioned in the Sat>P specifications, so Sat>IP servers may not support it. If the server responds with an error, DVBViewer automatically falls back to UDP data transport and displays “TCP data transport not supported by the server” in the OSD. Known Sat>IP servers with TCP interleaved support are the DVBViewer Media Server version 3.3.1.9 and later, the Linux Sat>IP servers tvheadend and minisatip, and receivers equipped with sat>ip-axe firmware (which contains a customized minisatip version).
    • The advantages of TCP interleaved mode are dropout prevention (at the cost of more protocol overhead) and less firewall issues. Furthermore it may facilitate using Sat>IP via a VPN.
  • Added: RTSP (Sat>IP) Client: Measures to make Sat>IP connections using the UDP transport mode less susceptible to blocking by firewalls, particularly if the network connection is configured as public (see here).
  • Added: Hardware: Support for new Digital Devices PCIe cards and Sundtek SkyTV Ultimate 8 / Dual USB DVB-S devices (see here).
  • Change: TS Stream: If the network adapter selection for multicast IPTV in a virtual TS Stream device is set to “Automatic”, DVBViewer now checks if there is a single adapter with an IP address in the private 192.168… range, which is mostly used by routers. If yes, this adapter is used, otherwise the adapter selected by Windows as before (see here).
  • Change: TS Stream: The selected UDP/RTP Interface (IP address) in the settings of a virtual TS Stream Device on Options → Hardware now also applies to RTSP Streams that are received via this device. Previously this setting was only used for multicast UDP/RTP streams like MagentaTV.
  • Change: TS Stream: The HLS stream type detection order has been changed to prevent that an audio elementary stream is mistaken as transport stream, if the server HTTP response wrongly indicates video/MP2T as content-type (see here).
  • Fix: TS Stream: DVBViewer could not handle WebVTT subtitles for videos in HLS or MPEG Dash format, if the subtitles were provided as a single unsegmented .vtt file.
  • Fix: TS Stream: HLS or MPEG Dash streams with segmented MP4 could cause a crash, if the HEVC header data in the initialization segment contained more than 1024 bytes.
  • Added: TS Stream: DVBViewer now automatically adds the RTSP standard port 554 if the port is not specified in an RTSP URL processed as TS Stream (see here).
  • Added: Media Server Client: Multiple DVBViewer instances running on the same PC can now be remote-controlled individually via a DVBViewer Media Server, provided the new method for multiple instances introduced in version 7.3.0 is used. For registering itself as remote control client, DVBViewer appends instance numbers greater than 1 with a preceding # sign to the PC name.
  • Fix: Playback: M3U and PLS Playlist URLs entered via Playback → Open URL were not handled and caused an error message. Now the processing is delegated to the live stream playback branch, thus covering streams that DVBViewer can handle natively, particularly internet radio URLs (see here).
  • Change: OSD/Video Playback: The OSD message “Press "0" to start from the beginning” now disappears as soon as “0” or any other number key for a position change is pressed. Previously it remained on the screen until Options → Movies → Info-Timeout has elapsed.
  • Added: OSD/ Audio Playback: During playback of audio/music files the artist and title are displayed at the top of the video area in the same way as radio text (see next point), if Options → TV/Radio → Show radio text is switched on. If artist and title are not available, the filename is displayed.
  • Change: OSD/Radio Text: Radio text is not displayed anymore at the top of the video area while OSD pages are active, because it may overlap important parts. Exceptions to it are the OSD main menu, the “Mini-EPG” and the Media Window (displayed after pressing the Return key during file playback).
  • Change: OSD/File Playback: The OSD Media Window (displayed after pressing the Return key during file playback) now also triggers thumbnail creation, if possible, since it is supposed to display a video or audio (album cover) thumbnail. Previously the OSD Media Window only displayed a default image, unless a thumbnail had been created before while using the OSD pages Media Center → Movies or Music.
  • Fix: OSD: While an OSD dialog prompting to confirm channel switching was active (e.g. in case of timeshift playback), DVBViewer did not respond to received command parameters. Particularly -x plus action number parameters sent by the Media Server for remote-controlling DVBViewer were ignored, thus making the OSD dialog inoperable with these remote commands.
  • Fix: OSD: Navigation with the OSD Right action did not work correctly on some pages, particularly on the Movies, Music and Images page. Depending on the display mode of the content list (List View or Icons) it was not possible to navigate from the button column at the left to the list at the right (since 7.3.1, see here).
  • Fix: OSD: If video playback was started on an OSD page with an embedded video window, another video renderer than EVR Custom was used, and Options → OSD General → Close OSD on video and TV playback start was switched on, the OSD page remained on the screen in an inoperable state, and an action like Rebuild Playback or Pause/Play was necessary to make the video visible (since 7.3.1, see here).
  • Fix: OSD: If the tweak “Show Mini EPG in Timeshift mode” (→ launch Tweaker.exe) was switched off, the OSD main menu of the default OSD skin displayed channel logos twice in a displaced manner.
  • Fix: Plugins: Measures against access violations caused by OSD plugins (like the one installed with the Blufuzz OSD skin) in additionally running DVBViewer instances, particularly disabling channel switching in these instances altogether.
  • Fix/Change: Input Options: Some faults and inconsistencies particularly concerning the loading/saving of keyboard and remote control key assignments to DVBViewer actions in .remote files (see here )
    • The name of the currently edited file was not displayed. Now it is visible at the top right of the input options page. Please note that this is not necessarily the file currently used by DVBViewer. It can be a different one after using the Load or Save button. However, OK/Apply makes it the used file.
    • Key assignments in a loaded .remote file did not take effect after clicking OK/Apply, but only after a DVBViewer restart.
    • DVBViewer could not handle loading .remote files from other locations than the Remotes sub-directory of the configuration folder. On next DVBViewer start this caused the creation of a substitute file with the same name in the Remotes sub-directory, that only contained default key assignments. Now, after loading a file from other locations, OK/Apply saves the contained assignments to a file with the same name in the Remotes sub-directory (which means, it creates a copy there) and lets DVBViewer use this file.
    • The Save button did the same as OK/Apply (with the same bug, see second subitem above), which means, it changed the .remote file used by DVBViewer. Furthermore, if the current key assignments were saved to a location outside the Remotes sub-directory of the configuration folder, DVBViewer could not find it on next start and created a substitute in the Remotes sub-directory containing default assignments (also see third subitem above). Now the Save button does not change the file used by DVBViewer anymore. However, if the current assignments are saved to the Remotes sub-directory of the configuration folder, the file becomes the currently edited file displayed at the top, and only after OK/Apply the file used by DVBViewer.
    • The DEL key now deletes the currently selected item in the list of key assignments (previously it did not take effect). This only applies if the list has the input focus and learn mode is inactive.
  • Added: Radio Text: Radio text detection in the AAC frames of the German radio channels Antenne Bayern, Rock Antenne and Oldie Antenne on Astra 19.2° East, 12149 H. Previously the RDS parser could not find the data.
  • Fix: Recorder: When playing files from the internet (e.g. HbbTV content), downloading them by using the DVBViewer record function failed with an access violation if DVBViewer was configured as Media Server client with “Send timers to the server” switched on (since 7.2.2, see here).
  • Change: HbbTV: The browser component is not initialized on DVBViewer start anymore, but only if HbbTV content shall actually be displayed. This saves memory and avoids potential problems with this component, as long as HbbTV is not used.
  • Added: Command Line Parameters: New command line parameter -p for Picture in Picture channel switching. It works in the same way as -c for the DVBViewer main window (see here). -p without subsequent channel information closes the PiP window, if it is active. -p[channel number], -p[channel name], -p:[channel ID] open the PiP window, if not yet opened, and let it play the specified channel. If it is not possible, e.g. because there is no free tuner available for receiving the channel, the command takes no effect.
  • Fix: Command Line Parameters: -x.. command line parameters did not work anymore when passed to DVBViewer on start, except if DVBViewer was started without TV/Radio playback (additional -c parameter) or the parameters were passed to an already running DVBViewer instance (since 7.3.1, see here).
  • Fix: General: In new Windows 11 installations DVBViewer opened links in Edge, not in the default browser selected by the user (see here).
  • 4 months later...
DVBViewer Pro Beta 7.3.1.11
The DVBViewer beta version 7.3.1.9 has been replaced by beta version 7.3.1.11 in the Members (Download) Area -> Beta Section.
Because this version is unsigned again, the accordings hints given for version 7.3.1.9 (see previous post above) still apply. Therefore it is recommendable to let the signed DVBViewer Pro Downloader of a previous DVBViewer version (see Windows start menu -> DVBViewer) handle an update, in order to avoid misleading Windows warnings. After scrolling down to the bottom in the DVBViewer Pro Downloader Window, you will see an "Applications" section, offering beta versions. As long as you are using the original downloader (with Christian Hackbart verified as publisher in the Windows UAC screen) or a download from our members area, you can be sure that we are the publishers.
Please also note that downloading and running the DVBViewer Media Server Beta 3.3.1.11 full version requires purchasing an additional license (if not yet done)! This does not apply to the restricted Basic version, though (see here).
Change Log DVBViewer Pro Beta 7.3.1.11
  • Change: TS Stream: Stream formats, that can not be handled natively by the DVBViewer TS Stream framework, particularly Vorbis, FLAC or Opus radio streams, are now automatically delegated to the LAV Source Filter (or to another DirectShow source filter that can cope with it). Previously this had to be done manually by checking “Play as file” in the Channel Editor, which now happens automatically as well. This also works if the reception of TS Stream channels is delegated to a local DVBViewer Media Server 3.3.1.10 or later (see “Receive TS Stream via the local Media Server” tweak, default = on). Generally the detection and handling of such streams has been enhanced in different ways.
  • Added: TS Stream: Ability to process and play AC3 and EAC3 (Dolby Plus) (radio-)streams natively within the TS Stream framework.
  • Fix: Video Playback: Under certain circumstances the screen remained black when playing a video with the MPC Video Renderer, until the video was resized or Rebuild Playback performed (see here).
  • Change: Video Playback: DVBViewer now applies the tweak “Load XYSubFilter for subtitles” also to the MPC Video Renderer (previously only to the MadVR Video Renderer, see here).
  • Added: Audio Playback: Possibility to let two or more DVBViewer instances play audio at the same time by holding the Shift Key down while performing an action that would usually mute all other instances, particularly if another DVBViewer instance is launched or an already running muted instance is unmuted, e.g. by turning the volume up (see here).
  • Added: RSS Feeds: Support for playing media content in HLS and MPEG Dash format, that are contained in RSS Feeds as link. This applies to the OSD News page and the DVBViewer playlist (see 7.3.1 changes and here).
  • Fix/Added: OSD: Several issues fixed and facilities added in the OSD Favorites Editor:
    • Fix: Deleting favorites did not work at all.
    • Fix: In many cases added folders or favorites appeared outside the visible area of the favorites list and were not scrolled into view.
    • Fix: The editor channel and favorites list were not updated in case of changes outside the editor.
    • Fix: Missing functions in the default OSD skin (buttons for toggling between TV and radio channels, button for renaming favorite categories).
    • Added: Possibility to toggle the selected state of all channels within a channel list category by selecting the category name (e.g. for selecting all channels within a category and adding them to the favorites).
    • Added: Possibility to toggle between channel list display with or without audio tracks by selecting the TV button again if it is already selected (in case a certain audio track of a channel shall be added to the favorites).
  • Fix: OSD: Up/down buttons were not activated on mouse-over, and as a result, were not clickable in the OSD Sleep Timer plugin (see here). Furthermore the buttons were responding sluggishly to mouse movements (see here).
  • Fix: OSD: If the tweak “Show Mini EPG in Timeshift mode” (→ launch Tweaker.exe) was switched off, several OSD pages of the default OSD skin displayed channel logos twice in a displaced manner (not only in the OSD main menu, which has been fixed in 7.3.1.9). Additionally the OSD Duration Window showed “Timeshift” as title on normal file playback instead of the media title.
  • Change: OSD: Enhancements on the OSD UPnP page. It now shows the last selected folder / category content when opened again (previously it always showed the available servers) and collects more metadata like title, duration, artist, album, album covers etc. from the server, so it can be shown in the DVBViewer UI when an item is played.
  • Change: OSD: When using the Add (OSD Red) function on the OSD Music page for copying a music folder content to the playlist, it is not appended to the current playlist anymore, but replaces it. This unifies the handling with the Video and UPnP OSD pages. However, single items are still appended by the “Add” function.
  • Fix: OSD: The number of items that can be transferred from the Video / Music / UPnP OSD pages to the playlist at once is now limited to 1000. This avoids long freezing of DVBViewer after (erroneously) adding the root folder of a large music collection or UPnP server with several thousands of items.
  • Change: OSD: The OSD News page now remembers the last selected RSS channel when opened again, not anymore the first one from the list.
  • Fix/Change: HbbTV: Some fixes and minor enhancements concerning HbbTV (requires Add-On). Particularly HbbTV of the Swiss SRF/RTS/RSI channels works again (at least partly). For the German-language SRF channels another entry in the file hbbtv2.xml was sufficient, that also fixes it in previous DVBViewer versions. The French/Italian-language HbbTV for RTS/RSI channels required a change in the DVBViewer code, though.
  • Fix: Recorder: Timers with weekly repetition and execution only on a single day of week were not updated after a recording to the next recording date until midnight. During this time DVBViewer uselessly triggered timer list and recording list updates once per second (since 7.3.1.9, see here).
  • Fix: Recorder: Timers with weekly repetition, that were stopped prematurely (before their end time was reached), were re-started immediately, because DVBViewer erroneously backdated them after switching to the next execution date.
  • Change: RTSP (Sat>IP) Client: Measures for re-gaining sync with a Sat>IP server in TCP interleaved transport mode if it got lost due to missing data.
  • Fix: Hardware Options: When changing settings in the Sat>IP RTSP settings dialog without first clicking the respective server in the Servers list, DVBViewer reset the internal value indicating special server types like OctopusNet or the DVBViewer Media Server, so a special handling required for them was not applied anymore (see here).
  • Added: Media Server Client: Tweak “Max. EPG download rate from Media Server (kbps)” (→ launch Tweaker.exe). Specifies the maximum EPG download rate from the DVBViewer Media Server in kbps. 0 means unlimited. In case of insufficient network bandwidth downloading a large amount of EPG data after DVBViewer start may disturb a TV stream received simultaneously from the server. Limiting the download rate (e.g. to 1000 kbps = 1 MBit/s) decreases playback issues, but increases the download duration accordingly.
  • Change: Media Server Client: The EPG download from the DVBViewer Media Server is now delayed by 5 seconds on DVBViewer start, so that setting up a TV stream that shall be received from the Media Server does not happen simultaneously and is not disturbed by high network bandwidth occupation.
  • Added: Channel Editor: New import plugin “ImportLamedb.dll”, enabling to import lamedb files containing channel lists for Enigma2 receiver into the Channel Editor window by drag and drop (see here and here). Such channel lists are particularly offered by the cable provider Vodafone on its helpdesk internet pages. Please note: Enigma2 channel lists are only recognized if the filename is lamedb, contains lamedb as sub-string or if the filename extension is .ldb.
The DVBViewer beta version 7.3.1.11 has been replaced by hotfix beta version 7.3.1.12 in the Members (Download) Area -> Beta Section. Please take note of the hints in the previous posts concerning the unsigned installer!
Change Log DVBViewer Pro Beta 7.3.1.12
  • Fix: TS Stream: If a stream URL did nor indicate the stream format (e.g. by a filename extension like .ts), and DVBViewer had to retrieve it by reading the server’s HTTP response header, it was not handled correctly, thus disabling stream processing within the TS stream framework and letting DVBViewer use file playback with the LAV Source Filter as fallback (see here).
  • 5 months later...
DVBViewer Pro 7.3.2
Please note: We are using a self-signed certificate in version 7.3.2. Unfortunately an official certificate acknowledged by Windows has become much more expensive and complicated, which is a problem for small software manufacturers like us. Therefore we try to get along without it. But it causes consequences for DVBViewer users.
Because Windows cannot verify the publisher, launching the 7.3.2 installer downloaded by a browser triggers misleading "Windows protected your PC" warnings, and you need to first click "More info" and then "Run anyway" to get it going (see here).
However, when updating to DVBViewer 7.3.2, it can be avoided by launching the still officially signed DVBViewer Pro Downloader (see Windows start menu -> DVBViewer). Topmost you will see a "Main Application" section, offering version 7.3.2. Select what you want to install and let the downloader do its job. As long as you are using the original downloader (with Christian Hackbart verified as publisher in the Windows UAC screen) or a download from our members area, you can be sure that we are the publishers, despite any warnings.
Please also note that downloading the DVBViewer Media Server 3.3.2 full version with the DVBViewer Pro Downloader (see section Add-Ons) requires purchasing an additional Media Server license (if not yet done)! This does not apply to the restricted Basic version, though (see here).
Change Log DVBViewer Pro 7.3.2.0
  • Change: OSD / Mosaic View: Previously the Mosaic View only displayed continuously updated snapshots from TV channels broadcasted on the frequency (transponder) tuned by the DVBViewer main window. Now it also includes all unencrypted TV channels from the frequencies received by picture-in-picture and the recorder, up to the maximum number of tiles, which equals the squared configurable number of columns. Additionally the tiles now display the channel number and program title from the EPG. The Mosaic View is automatically switched off by a channel change, the start of file playback, or if no more DVB hardware is used by the main window, picture in picture and the recorder (see here).
  • Added: Picture in Picture / Mosaic Options: Checkbox “Use free tuners for additional channels” (default off). It allows the mosaic preview to occupy free tuners for displaying additional TV channels. If checked and if free tuners are available, the mosaic preferably displays the favorites from top to the bottom, assuming that the most popular channels are located at the top, until all tiles are filled. If there are no favorites or if they do not fill all tiles, the mosaic additionally searches the channel list for displayable channels. Among the functions using tuners (playback in the main or Picture in Picture window, recorder, scanner) the mosaic has the lowest priority. If a tuner is needed by another function, the mosaic releases it immediately. Please note that repeated tuning every few seconds for updating mosaic tiles may block the DVBViewer UI temporarily. This does not happen if the mosaic only uses frequencies that have already been tuned by other functions.
  • Added: Picture in Picture / Mosaic Options: Input field “Max. simultaneously created images”. It specifies the maximum number of tiles the mosaic is allowed to update simultaneously. A high number may speed up mosaic processing considerably, but also overstrain less powerful PCs, due to several video decoder and renderer instances running at the same time. The default is 2, the maximum 9. The value 1 causes the tiles to be updated one after the other. Please note: Only channels located on the same frequency (transponder) are processed simultaneously.
  • Added: Channel Editor: Holding the Ctrl key down while importing a channel list removes encrypted channels from the import (see here).
  • Added: Channel Editor: Newly entered YouTube stream URLs like https://www.youtube.com/watch… are automatically prefixed with a request to the yt-dlp Server Plugin (if present) on Add/Apply for retrieving a URL that enables playing the video/stream in DVBViewer. For more information please read the plugin Readme.
  • Added: Channel Editor: Automatic conversion of the #EXTVLCOPT:http-referrer=... M3U tag to a DVBViewer-specific URL appendix ?addhdr=Referer:… on M3U import (see here).
  • Change: Recorder / TS Stream: Measures against an unresponsive DVBViewer UI caused by repeated unsuccessful attempts to tune internet TV/radio channels in case of a non-responding server. Now the recorder repeats them only once per minute (previously as soon as possible) and deactivates the timer after a number of unsuccessful attempts, or switches timers with weekly repetition to the next date. The number is specified by the new tweak “Max. tune attempts on TS Stream timer recordings (default 3, → launch Tweaker.exe, see here).
  • Fix: TS Stream: Better handling of streams without Program Clock Reference (PCR , particularly YouTube). DVBViewer now automatically uses audio time stamps as time base in this case, so it has not to be forced by the “Remove clock reference” setting in the Channel Editor anymore.
  • Fix: TS Stream: HLS, MPEG Dash or transport streams could only be played once and not again, until the next DVBViewer start, if the URL pointed to a M3U or PLS playlist file containing the stream URL (see here).
  • Fix: TS Stream: If the base URL ended with a slash, relative URLs were not handled correctly. They were appended to the last but one slash, not the last one (see here).
  • Added/Change: File Playback: New tweak “Connection timeout for file playback (ms)” (→ launch Tweaker.exe). It applies to playback of files referenced by a URL with the DVBViewer Filter. The value specifies the time in milliseconds, after which a connection attempt is canceled, if the server does not reply. The default timeout is 10000 ms, now also for files delivered in HLS or MPEG Dash format (previously 5000 ms, too little particularly for YouTube files).
  • Added: Stream Playback: A user agent and/or referrer appended to a URL by means of a ‘addhdr’ query parameter is now used if files referenced by a URL are played with the DVBViewer Filter (particularly .ts files), or any stream with the LAV Source Filter. Previously addhdr was ignored in these cases. Please note that up-to-date LAV Filters are required, due to a new interface that was introduced in LAV Filters 0.80.
  • Added: Audio File Playback: Seamless playback of audio files from the DVBViewer playlist or channel list (when used as playlist), if the format can be played natively with the DVBViewer Filter (WAV, MP2, MP3, AAC,AC3). “Seamless” means playback without a gap between files, e.g. from an album They must be of of the same type and have the same sample rate and number of audio channels, so the transition can take place without stopping or re-configuring the playback components. Please note that there still may be small audible gaps of some milliseconds due to the frame structure of compressed formats like MP3, caused by padding the last frame with silence by the encoder.
  • Added: Video Playback: .vob filename extension to the default list of movie file extensions (see Options → Movies). It lets .vob files from DVD structuresappear in file selection dialogs and enables including them in playlists. However, it only takes effect on new DVBViewer installations, not on DVBViewer updates. Please add .vob manually to the list, if necessary.
  • Added: Video Playback: When playing a .vob file from a DVD structure with the DVBViewer Filter (e.g. VTS_01_1.VOB), DVBViewer automatically concatenates this file and the subsequent .vob files of the same title set (e.g. VTS_01_2.VOB, VTS_01_3.VOB etc.) to a single virtual file that is played seamlessly. This enables playing unencrypted DVDs without using the Microsoft DVD Navigator Component (particularly useful under Linux/Wine).
  • Removed: Stream/File Playback: The VOD Source Filter (VODSource.ax in the Filters sub-directory) is no more included in the DVBViewer setup. It was only needed for DRM protected WMV files (see below) and for requesting HbbTV content with a certain user agent from a server. The latter can now also be performed by using the LAV Source Filter (see below). Please note: Don’t just delete VODSource.ax from the Filters directory. It must be unregistered first, e.g. by using the Radlight Filter Manager with admin rights.
  • Removed: File Playback: Support for out-dated DRM protected Windows Media Video files (WMV, see here). Unprotected WMV files can still be played, though.
  • Fix: General: Several adjustments for DVBViewer running under Linux/Wine 11.0 Stable:
    • File playback with the LAV Source Filter/Splitter did not work, because the Wine DirectShow mechanisms were not able to detect it automatically as suitable playback component. Now the LAV Source Filter is preset as default if a file/stream must/shall be played with it and DVBViewer detects that it is running under Wine. This also means, that alternative file source filters (like the Haali Splitter) can only be used by means of a filter graph preset (.fgp file in the GraphPresets sub-directory of the configuration folder).
    • CD playback with the DVBViewer Filter did not work.
    • Playback of DVD file structures did not work, because the DVD Navigator provided by Wine seems to be just a dummy component. Now DVBViewer falls back in this case to playing the .vob files of the first title set in the DVD structure with the DVBViewer Filter. They are automatically played seamlessly as a virtual single file. This only works with unencrypted .vob files, not with encrypted commercial DVDs.
    • The Control Bar displayed the current position/duration of files / programs only partly or not at all, particularly if the text size was set to more than 100% with Resizer.exe.
    • Hints displaying items in full length, that were too long to be fully displayed in list views and tree views, did not vanish on mouse clicks, thus preventing the item underneath from being selected.
  • Change: Playlist: If video playback is started from the playlist, DVBViewer now considers the setting Options → Movies → Resume and ask, so playback continues at the position where it was stopped lastly. However, this does not apply to an automatic or manual switch-over to the next playlist item. Previously playback of items always started from the beginning (see here).
  • Change: RTSP (Sat>IP) Client: If a virtual RTSP device is associated with a local Media Server instance on the same PC, DVBViewer now additionally checks if this local Media Server instance is running. If not, Options → Hardware → Devices displays the according entry in red as not available, and it is not taken into account for usage.
  • Fix: Sleep Mode/Hibernate: If Options → General → Resume playback after sleep mode / hibernation was switched off (default on) and EVR Custom selected as video renderer on Options → Playback Components → Video (default), the OSD did not work anymore after waking the PC up until next video playback start and DVBViewer did not switch over to prebooked programs until it was restarted (see here).
  • Fix: EPG Window: If the splitter element above the Details panel was moved down to make it smaller, and its content exceeded its size, no vertical scrollbar was added (see here).
  • Added: EPG Window: It is now possible to navigate in the Timeline display by using the arrow keys, PgUp, PgDown, Home and End. Using the keys without Ctrl moves the EPG entry selection in the according direction. With Ctrl the display just scrolls in the according direction without changing the selection (see here).
  • Fix: General: DVBViewer did not consider the “Personalization → Taskbar → When using multiple displays, show taskbar apps on Taskbar where window is open” Windows setting. The taskbar icon always appeared on the primary monitor (see here).
Edited by Griga
Adjustemts to the changed order in the DVBViewer Pro Downloader
