Tuner and CI compatibility
Hello.
For DVBViewer I was thinking in buying the
https://digitaldevices.de/en/products/dvb-components/max-m4/
for this seems to be 2 possible CAM CI boards:
https://digitaldevices.de/en/products/dvb-components/octopus-duo-ci/
https://digitaldevices.de/en/products/dvb-components/duoflex-ci/
Is the DVBViewer aware of those CI? Or I need to install something from the boards supplier ?
So basically i  want to use that tuner with 4 encrypted channels(according to site on windows whould be possible to decrypt 4 simulatanous channels)
Thank you
vor 6 Minuten schrieb mradu:
Yes, if "Has CI Module" is checked for the DD tuners on Settings -> Options -> Hardware. An important step may be to configure the CI <-> Tuner assignment in the DD Control Center.
I'm using (older) Digital Devices cards with separate CI modules, and it's working pretty well.
