Vovven Posted March 9, 2022 Posted March 9, 2022 Hi, I'm running mediaserver 3.2.1.0. When selecting 'Timeline' in the webinterface and hoovering over a program, a description of the selected program used to popup, this is not the case in 3.2.1.0. If instead selecting 'TV Guide' the program description pops up as expected. I also have one instance of 3.1.2.1 still running. In this version the 'Timeline' interface works as expected. Is this a bug or on purpose? Regards, Vovven Quote
Griga Posted March 9, 2022 Posted March 9, 2022 Am 9.3.2022 um 16:11 schrieb Vovven: Is this a bug or on purpose? An unexpected side effect of a change in 3.2.0.0. Please replace C:\Program Files (x86)\DVBViewer\SVCweb\js\timeline.min.js by the attached file, force a complete timeline reload in the browser by pressing Ctrl + F5, and try... please let me know if you still encounter issues with this file version. timeline.min.zip Quote
Vovven Posted March 10, 2022 Author Posted March 10, 2022 Works fine with the new file. Thanks, Quote
shailen Posted March 23, 2022 Posted March 23, 2022 Hi, Is this identified as a bug, so will be fixed in next update? Loosing this feature is a show stopper for my family. Thanks for the .js to patch it in the mean time. Shailen. Quote
