morlook Posted April 24, 2022 Posted April 24, 2022 Hi all, I am now setting up a vm (windows 10), i sussessed to install dms, and it can get epg data. But it cannot start streamming nor recording. The vm didnt have a gpu, is the gpu needed for streamming or recording? I need to passthrough a gpu? Tks!! Morce Quote
Griga Posted April 24, 2022 Posted April 24, 2022 vor 3 Stunden schrieb morlook: is the gpu needed for streamming or recording? No. You may want to attach a support.zip for providing more insight in your setup. Quote
morlook Posted April 24, 2022 Author Posted April 24, 2022 Here is the support.zip, tks for yr help support.zip Quote
Griga Posted April 24, 2022 Posted April 24, 2022 I can see no errors in your svcdebug.log, except Zitat TDVBWebserver GetTemplate File not found: C:\Program Files (x86)\DVBViewer\SvcWeb\null\ which means, files that are necessary for delivering the web interface cannot be loaded. Any explanation for it from your side? Nevertheless the recorder creates 0 byte recordings. Possible reasons are The received data is encrypted. The channel can't be received. The Status page of the web interface would report 0% signal strength in this case. There is no data coming in from your RTSP (Sat>IP) server. Obviously the server is present and responds to the Media Server's attempt to establish a TCP connection for tuning. Otherwise there would be error messages in the log. However, TV data is sent via an extra (UDP) channel to the Media Server, that may be blocked for some reason. The Status page of the web interface would most likely also report 0% signal strength in this case, because the server sends it via another UDP channel to a neighbouring port. Quote
