vramor Posted April 26, 2022 Posted April 26, 2022 (edited) Sorry in advance, but I experienced an issue right now though could detect this earlier. DVBViewer cannot show video normally (freezing etc.) with PCTV 292e (driver version 5.2020.406.3825, Hauppauge) under Windows 10/11. In the same time I see excellent video using Preview in TransEdit. What a reason can be and how to fix it? Edited April 27, 2022 by Griga Corrected DVBViwer -> DVBViewer Quote
HaraldL Posted April 27, 2022 Posted April 27, 2022 You should post a support.zip, but be sure to follow the insctuctions to start DVBViewer from start menu entry with "Debug Mode" before. If forum software says you have not enough space to append the support.zip you can remove older, no longer needed attachments by clicking your user name top right and manage files/attachments from the menu that appears. Quote
Griga Posted April 27, 2022 Posted April 27, 2022 vor 7 Stunden schrieb vramor: In the same time I see excellent video using Preview in TransEdit. Try to use the same video decoder and renderer (usually the EVR Enhanced Video Renderer, not Custom) in DVBViewer - see Options -> Playback Components. Does it work? Quote
vramor Posted April 28, 2022 Author Posted April 28, 2022 It seems to me I found out the reason It is 292e's fault. This tuner turned out need to be initialized to start work. Both with DVBViewer, and TransEdit. The TransEdit>Analyze>Preview shows the normal video just after I run CrazyScan2. The same with DVBViewer. Unfortunately I noticed this too late. Switching to EVR Enhanced doesn't touch at all. Nevertheless I send my config. Sorry for my faulse alarm. support.zip Quote
