il diavolo epm Posted May 26, 2022 Share Posted May 26, 2022 HI! Is there any indicator of signal strength when the antenna moves west and east. Direct to see?. Thank you Quote Link to comment
Griga Posted May 26, 2022 Share Posted May 26, 2022 vor 59 Minuten schrieb il diavolo epm: Is there any indicator of signal strength when the antenna moves west and east. Yes. In the TransEdit Analyzer if it is tuned to a frequency of a satellite position while the antenna is moving. However, it will only show the signal on this frequency, not the general signal strength of a satellite position. I think it is better to use a satellite finder like this one. Quote Link to comment
il diavolo epm Posted May 27, 2022 Author Share Posted May 27, 2022 11 hours ago, Griga said: Ano. V TransEdit Analyzeru, pokud je naladěn na frekvenci satelitní pozice, když se anténa pohybuje. Zobrazí však pouze signál na této frekvenci, nikoli obecnou sílu signálu satelitní pozice. Myslím, že je lepší použít satelitní vyhledávač, jako je tento . Thank you Quote Link to comment
