Stream Sat TV to Smart TV
PerryM
Maybe a dumb question!
I want to stream Live TV from a computer with 4x Satellite tuners to an LG Smart TV over Ethernet (local network) The computer has DVBViewer Pro and Recording Service working fine. It also is set up as a Plex Media Server, which I was previously using to stream Live TV to the TV, which has a Plex client.
For some reason (I think Plex has changed the options) the Plex Server no longer recognises my tuners.
Is there any way I can do the same job using DVBViewer Media Server?
vor 14 Minuten schrieb PerryM:
I want to stream Live TV from a computer with 4x Satellite tuners to an LG Smart TV over Ethernet (local network). The computer has DVBViewer Pro and Recording Service working fine.
I don't know LG TVs, but the way to go seems to be UPnP/DLNA, e.g. see here. This would require to enable the UPnP server in the RS - see web interface -> configuration -> UPnP.
Am 16.6.2022 um 18:11 schrieb Griga:
Works fine with a Sony Bravia here - should also work with LG TV.
Thanks Griga, that works fine, except for occasional buffering. I am on Ethernet (both ends) so not quite sure what is causing that?
