Nealeb Posted July 6, 2022 Posted July 6, 2022 I recently installed a Hauppauge QuadTV PCIe tuner, to replace a very old and now unsupported Black Gold tuner in which one tuner channel had failed. However, I am getting poor quality video (both live and recorded) with a lot of pixellation on moving images. This happens on HD channels and, although not as bad, on SD channels. My local HD transmitter is about 3km away and I am using an external antenna, and I do not believe that it is a signal strength problem. My local HD stations are using H.264. I am using the latest version of DVBViewer and Media Server, downloaded today. I am using the latest LAV decoder (installed during installation of DVBViewer) with DXVA2 (native) selected. I am using the latest Hauppauge driver (1.59.37308), downloaded today. I am using an Nvidia GTX 750 Ti graphics card with the latest driver (516.59). I am surprised to see a very high GPU use (often 75%) when DVBViewer is running. One curious feature is that if I reboot my system, it seems to work reliably. However, if I "sleep" and then wake up again, I see the pixellation/picture break-up problem. This makes reliable scheduled recording difficult! I am not sure if this is a hardware problem on the tuner card, a PCI bus bandwidth issue, a filter/decoder problem, a GPU problem, or something else! I would be very grateful if someone could suggest things to investigate more deeply. I have attached a support.zip file. Many thanks, support.zip Quote
