globalist Posted August 12, 2022 Posted August 12, 2022 (edited) I've been using DVBViewer Recording service (v1.33.02.01) with my Kodi for years but today the Kodi client (19.1.0) is complaining that it requires DVBViewer Media Server v3 or above. I guess this means I need to ditch DVBV RS and start using DVBV MS, but I'm wondering can I just install DVBV MS and it will somehow pick up the settings from DVBV RS? Or do I need to uninstall DVBV RS and set up DVBV MS from scratch? Also, I've tried downgrading the Kodi client but this did not help with the error message (3.0.0.0 or above MS required), so I'm not really sure what is going on. Any light into this? Many thanks! Edited August 12, 2022 by globalist Quote
Griga Posted August 13, 2022 Posted August 13, 2022 11 hours ago, globalist said: I guess this means I need to ditch DVBV RS and start using DVBV MS Yes. Please note that the DMS full version requires an additional licence (currently 21,- €, more about it here and here). The restricted Media Server Basic, that is free for owners of a DVBViewer licence, will probably not meet your needs. However, you can try it first, if you just want to find out how it works. 11 hours ago, globalist said: but I'm wondering can I just install DVBV MS and it will somehow pick up the settings from DVBV RS? This is not tested anymore. Just try.... presumably most of the settings will be picked up. If it doesn't work out, you can still set it up from the scratch. Please note that DVBViewer must also be updated to the latest release. 11 hours ago, globalist said: Also, I've tried downgrading the Kodi client but this did not help with the error message (3.0.0.0 or above MS required), so I'm not really sure what is going on. It's the DVBViewer add-on for Kodi that must be downgraded. Looks like it is kept when installing an earlier Kodi version. Quote
globalist Posted August 13, 2022 Author Posted August 13, 2022 OK, I've installed the DMS Basic and it picked up the previous settings and seems to be working fine. What do you mean it might not meet my needs? Are there some important limitations? Also, yes it's the Kodi addon I've tried downgrading, to no avail here. But now it's prolly just a moot point. Thanks! Quote
Griga Posted August 13, 2022 Posted August 13, 2022 43 minutes ago, globalist said: Are there some important limitations? Follow the link in my post. Quote
HaraldL Posted August 13, 2022 Posted August 13, 2022 FYI: If you decide to buy the full DMS: By just entering the license data in the KeyTool the basic DMS does NOT(!) turn into full DMS. You then would have to download the full DMS setup (will appear in your members area after buying) and install it over the basic DMS to get all features. Quote
