EnoSat Posted September 21, 2022 Share Posted September 21, 2022 Is there a detailed description somewhere of descriptor 0x79 and 0x7e which are found in NIT for DVB-S2X transponders? Quote Link to comment
Griga Posted September 21, 2022 Share Posted September 21, 2022 Search for ETSI EN 300 468. It's a free PDF. The latest version is V1.16.1. See 6.1: descripor identification and location, 6.2: descriptor coding, 6.3: extended descriptor identification and location (those with descriptor tag = 0x7F), 6.4: extended descriptor coding. 0x7F / 0x17 is the S2X_satellite_delivery_system_descriptor. I have added it to the Analyzer, so all its data fields get displayed, but I can't remember when. Are you using the latest TransEdit 4.3.0 release? 1 Quote Link to comment
EnoSat Posted September 21, 2022 Author Share Posted September 21, 2022 (edited) 👍 4.3.0 show S2X extend PS: it is good ? 79 - MIS Flag = 1 7F - MIS Flag = 0 Edited September 21, 2022 by EnoSat Quote Link to comment
Griga Posted September 22, 2022 Share Posted September 22, 2022 20 hours ago, EnoSat said: PS: it is good ? 79 - MIS Flag = 1 7F - MIS Flag = 0 There are some differences: RollOff = 4 - a = 0.15 in the S2X Satellite Delivery System Descriptor, RollOff = 0 - a = 0.35 in the Satellite Delivery System Descriptor (0.15 can't be coded in this descriptor) FECInner = 0 - Not defined in the Satellite Delivery System Descriptor (should be FECInner = 1 - 1/2) MultipleInputStreamFlag = 1 in the S2 Satellite Delivery System Descriptor, MultipleInputStreamFlag = 0 in the S2X Satellite Delivery System Descriptor. The value 0 matches the decriptor length = 14 bytes. With MultipleInputStreamFlag = 1 the descriptor would be 1 byte longer, due to an additional input_stream_identifier byte (see specifications). Symbolrate = 31429 in the Satellite Delivery System Descriptor, Symbolrate = 314290 in the S2X Satellite Delivery System Descriptor. It looks like the symbolrate in the S2X descriptor is shifted 4 bits (one digit), which means, it does not start at the position given by the specifications. I've checked the Analyzer code for these descriptors and compared it with the specifications, but I can't find a bug. So I guess the descriptors on this frequency are coded wrongly. Quote Link to comment
